Volvospeed Forums: Project Blackt5 - Volvospeed Forums
  • (18 Pages)
  • 1
  • 2
  • 3
  • Last »
Project Blackt5
#1 User is offline   BlackT5 Icon
  • NWC Rod Bender
  • Icon
  • Group: Supporting Member
Posted 25 November 2006 - 01:04 AM
Well, i figure I should start a theard about my car.. so here it is.
Many of you know, i bent several rods with the 19T. This was back in 2004. I ended up having the motor built locally which was quite the experience for me. VMS pistons & rods were used, the head was ported/polished, arp head studs blah blah blah..
The car..
a few pics from the build..
I ran the new motor with the 19T for almost a couple years now. Over that time, i've been slowly buying parts.
The setup:
B5234T3
Eagle rods
Ross pistons
Balanced rotating assembly
Arp headstuds
Ported/polished head
3 angle valve job
NA cams
Spec stage 3 clutch
S60R exhaust manifold
GT35R (.63/.70 A/R)
Precision 600hp intercooler
NA throttlebody
2.5" intercooler piping
3" turbo back exhaust
Siemens 630cc injectors (saturated)
Walbro 255lph
Tial 40mm wastegate
Tial 50mm blow off valve
Nira i3+ EMS
I will run on 10-12psi for the first year or so because I am still using the dualmass flywheel with the Spec stage 3 clutch. After that, I plan to drop in a singlemass flywheel, Quaife LSD and a stonger clutch at which point I can turn the boost up smile.gif
19T was the first to come off, as was the stock IC and the BSR exhaust.
19T and GT35R:
Precision intercooler mocked up:
S60R manifold and new turbo mocked up. The turbo will end up sitting higher as I only had 8mm studs to mount it and the hole in the turbine flange and a fair size larger.
It's close to the mount, but like i said, it will sit a bit higher after final install.
I had originally planned on having a tubular exhuast manifold made, but ended up using the S60R manifold to save myself some headaches. I still wanted to run the external wastegate so I switched over to a 5 bolt turbine.
4 bolt:
5 bolt:
Installed the Innovate WB02 and XD16 gauge:
Siemens 630cc injectors:
New coolant lines and fittings:
GT install kit. I'm hoping I will luck out and be able to use the stock return line, but we'll see.
Oil feed setup:
Next step is to run the IC piping and drop in the NA cams. The 3" exhaust/external wastegate setup is being fabbed locally after I get all this other stuff done.
Tuning.. yes I know someone's going to ask... is still up in the air. Nira is a possibility if the budget permits.
I currently have a dualmass flywheel and spec stage III clutch installed. I have purchased a T5R singlemass flywheel but am still on the hunt for a good clutch. I will stick with the dualmass for a while and just keep the boost down until I can find a clutch and get my hands on a LSD. That way, it can all be done at once and then I can crank the boost up.
That's about all I got right now.
Pics of the motor build can be seen through the link in my sig.
Mark
I also want to thank Joseph (JHEIII874T5M) for hooking me up with great deals on a lot of these parts. If you guys need quality stuff, this is the man to talk to. Great guy to do business with.
This post has been edited by BlackT5: 15 March 2007 - 06:19 PM
1998 S70 T5M
Built motor, Nira i3+ EMS, GT35R, FMIC, 630cc injectors, 3" exhaust..blah blah..
0
#2 User is offline   the underlørd Icon
  • Pretty Boy Racing
  • Icon
  • View blog
  • Group: Moderator
  • Interests:www.metropolitanmotors.com
Posted 25 November 2006 - 01:06 AM
Kevin: 07.5. Chevrolet. 3500HD SRW. LMM. LT. CC. 4x4. 6K HID. Linex. MBRP 4" DPF Back.Banks 6 Gun. 495bhp. 895torque. Victory Red.
0
#3 User is offline   Volvoson Icon
  • Baby On Board Racing
  • Icon
  • View blog
  • View gallery
  • Group: OH Moderator
  • Interests:Taking pictures, taking more pictures, and posting once in a while...
Posted 25 November 2006 - 01:11 AM
I'm scared...
04 S60R - Passion Red/Gobi Sand - 6-speed MT - 64K
1
#4 User is offline   OrEo931 Icon
  • Whaambulence Paramedic
  • Icon
  • View gallery
  • Gender:Not Telling
  • Interests:Engine swaps, Bending rods, Thermostat gaskets
Posted 25 November 2006 - 01:12 AM
wow, that is rediculous, it looks awesome. how much hp are you hoping to make?
good luck
M56H Swap ETA - 27 Days
My Garage///CarDomain
TKi Motorsport
0
#5 User is offline   Mesoam Icon
  • Mr. Sarcastic Jackass
  • Icon
  • View blog
looks good mark but please do not use those cheapy "AN look" clamps
What are you doing for a winter ride?
96 854 R, CLICK ME
The Jeep
#6 User is offline   550 Icon
  • someone please talk to me
  • Icon
  • View blog
  • Interests:Girls, cars, girls, computers, girls, girls
Posted 25 November 2006 - 01:38 AM
Mark, I feel like you are my brother in some way haha.
QUOTE
That guy is such a tool, he may as well be sold by Snap-On! - Me.
Pee. Ess. Eye.
1998 S70 GLT (160k)
Joe@volvospeed.com
0
#7 User is offline   NGB Icon
  • Level 5 Member
  • Icon
  • View gallery
  • Group: Vendor
Posted 25 November 2006 - 02:26 AM
Wow, quite a project indeed!
Keep taking pix the whole way and keep us updated.
Nick | 1998 S70 T5 SE | In the works: Compustar
Parting: 1998 V70R, 1998 V70R, 1999 V70R, 2000 S70 GLT SE
Poorboy's Sale
0
#8 User is offline   DARKSIDE Icon
  • Level 3 Member
  • Icon
  • Group: Lifetime Supporter
  • Interests:CARS, CARS, CARS...GIRLS, GIRLS, GIRLS
Posted 25 November 2006 - 04:02 AM
QUOTE('95R @ Nov 24 2006, 08:11 PM) View Post
I'm scared...
Ur not the only one, can't wait to see what type of numbers this beast puts out after the install...
-Omar
98' S70 GLT - Many Mods...but still a long way to go...
If I have to change this again, I'm going to spank you!
MY CAR GOT HIT - DO U HAVE THESE PARTS?
0
#9 Guest_S7013g_*
  • Group: Guests
Posted 25 November 2006 - 04:22 AM
WOW, hope it turns out great for you.
0
#10 User is offline   8G5L0T Icon
  • Level 2 Member
  • View gallery
  • Group: Members
  • Interests:cars, hiking, biking, running.... outside activities
Posted 25 November 2006 - 05:53 AM
damn your car is going to be some peoples dream cars here. best of luck with the installs and everything.
This post has been edited by 8G5L0T: 03 December 2006 - 09:31 PM
kn air filter, mtx amp, pioneer sub, polk audio components and rear door speakers, 15g on 13psi, upsolute chip, koni adjustables, est springs, 17"canistos, mbc, new starter, black samcos, 15% tint
0
#11 User is offline   JHEIII874T5M Icon
  • Level 6 Senior Member
  • Icon
  • View blog
  • View gallery
  • Group: Vendor
  • Interests:Making volvos go fast while still on stock ecu ;)
Posted 25 November 2006 - 06:08 AM
Ah, one of, if not the biggest reasons I got the black T5M is now going to convert itself into a beast. Mark, best of luck with everything! Looking good, big man, looking good.
Joseph H. Essaye III
Dealer for Samco, Forge, KW Suspension, Aquamist, Quaife Differentials, Autometer, MSD, and more!
PM me or email me at jessaye@gmail.com if interested
0
#12 User is offline   B00STWAG1N Icon
  • Level 4 Member
  • Icon
Posted 25 November 2006 - 06:21 AM
all this stuff in a volvo. such a sleeper. good luck with the front wheel drive traction.
-Matt
0
#13 User is offline   leurven Icon
  • Level 3 Member
  • Icon
Posted 25 November 2006 - 03:15 PM
QUOTE('95R @ Nov 24 2006, 09:11 PM) View Post
I'm scared...
Me too. That turbo is fricking awesome. My buddy just put it on his maxima and it hauls ass. Wow!! Good luck man. Can't wait to see the final and the dyno results.
Golden Gate VCOA Club Secretary
www.SharpHID.com - plug & play HID conversion kits - PRICES LOWER THAN EVER!!
'00 V70R - totaled :(
2002 Audi Allroad 2.7T (daily driver) - 1986 BMW 325es (daily driver) - 1984 VW Rabbit GTI(race car?)
0
#14 User is offline   martz0r Icon
  • Level 1 Member
  • Group: Members
Posted 25 November 2006 - 04:27 PM
Damn dude, congrats on doing what a lot of us dream about. Haha... I want to see her in action later down the road.
'98S70GLT-172k and counting
| 2.5'' Magnaflow | APS Intake | Boost Controller | 15% |
NOW FOR SALE! PARTS OR REPAIR.
0
#15 User is offline   BlackT5 Icon
  • NWC Rod Bender
  • Icon
Posted 25 November 2006 - 04:47 PM
QUOTE(Mesoam @ Nov 24 2006, 05:12 PM) View Post
The collar/clamps look alright if done correctly. It's either just a hose clamp, or i put the collar on.. i'm going to put the collar on.
winter ride is a Honda crx
1998 S70 T5M
0
#16 User is offline   narxs70 Icon
  • Level 3 Member
  • View gallery
  • Group: Members
Posted 25 November 2006 - 07:17 PM
i just made a sticky mess in my clean underoos! wow, this will be awesome. That car sould be good for like 450 hp? maybe more, enlighten us, oh great one that i am envious of! good luck and i'm glad to see alot of people stepping out with different turbos.
Michael - 1999 S70 AWD
2.5" FMIC, 2.5" Catback, Filter-on-a-stick.
0
#17 User is offline   pocket penguins Icon
  • Level 2 Member
  • Group: Members
Posted 26 November 2006 - 06:20 AM
wow that turbo scares the SH*T out of me
0
#18 User is offline   Johann Icon
  • "THE MAN"
  • Icon
  • View blog
  • View gallery
Posted 26 November 2006 - 09:46 AM
Wow!
Great project Mark.
Wish you all the luck with it!
#19 User is offline   Geevs Icon
  • Level 3 Member
  • Icon
  • View gallery
Posted 27 November 2006 - 02:21 AM
Awesome project Mark. Hope to see it at the Mission track next year.
Falken ZE-512 | H&R springs & spacers | Koni Yellows |OMP Brace | QBM Links | Samco & HTS hoses | EST short shifter & cat-back | K&N panel filter | Momo Anatomico | E-code corners
R front bumper, sway bars and springs | Monroe Sensa-Tracs | Falken ZE-512 | H&R spacers | HTS hoses | K&N panel filter
0
#20 User is offline   550 Icon
  • Icon
  • View blog
Posted 28 November 2006 - 11:04 PM
hey mark what did you mount the intercooler to? I'm thinking the aluminum bumper piece but not sure if thats the way I want to go... let me know what you figured out... I may be getting creative haha
QUOTE
Pee. Ess. Eye.
1998 S70 GLT (160k)
Joe@volvospeed.com
0
  • (18 Pages)
  • 1
  • 2
  • 3
  • Last »
