All problem were solved, so now is just a labor,
Just a quick remainder, I will run OS2 volvo pistons with Rsport rods first gen, they require cutting cyl sleeves a little, but could be done. I will use gt3071r and siemens 60 lbs injectors,
Let the gallery begin
This is what I started with 160k good running block from 1995 turbo wagon
After taking it apart
There was some sludge action ,but not to bed
New parts
OS2 pistons from volvo and unfamous rings this is correct part numer for all of you that want to use that set up
And finally assembly work started .
I all ready have matches up journal bearings and rod bearing , and this is machine work that was done couple weeks ago
fresh gaskets
tomorrow bottom end should be all together , and this weekend is a deadline for engine installation
I will keep you updated ,
