2001 Volvo S60 - Service Key Not Working
28 replies to this topic
#1 VS Legend
  • 6,790 posts
  • Interests:Volvo Cars, Technology, Photography, Film, Web Design, Guitar, Hiking, Skiing, Biking, and occasionally video games.
Posted 01 October 2008 - 08:22 PM
My little brother locked his S60's main key in his trunk. He only has the service key. The service key won't open the trunk. The service key also isn't starting the car, giving the usual "start failed" or whatever the message is when you have a bad antenna ring for the immobilizer.
Is there any easy way with the back seats locked to get into the trunk?
Alternatively, is there any easy way to pull a fuse or such to disable the start inhibitor so he can start the engine at least?
PM me if you don't want to post "here's how to disable the inhibitor" on a public forum, which would be nice of you since I don't think Chuck wants it posted on his site and to start leading a Volvo theft ring.
TYIA for any help.
2007 Volvo XC70 Daily Driver Steel Cargo Barrier (+50HP), Cargo Cover (+30HP), Bluetooth (+5HP), iPod Dock (To Be Installed, +15HP)
1995 Volvo 850 T-5R Currently in Storage RWD Conversion, 8-Speed Automatic Conversion, Quadruple Turbo w/ Supercharger and NOx
#2 vegasjetskier
  • 210 posts
Posted 01 October 2008 - 10:49 PM
The service key should start the car. Maybe it hasn't been programmed to his car?
You could try to pull down the seatbacks. Maybe they aren't locked in tight and will come forward. Also, you can try pulling the armrest backer down. It might be loose enough to come forward. You would then have a small opening to the trunk and could try to fish the keys with a stick, broom, wire, parts retriever, or some such. Or maybe you can get ahold of the emergency trunk release and pull it. Or maybe you can pull one of the seatback releases, fold down the seat, then crawl in to get the keys. Or use a saw to cut a hole in the armrest backer, then get a replacement from an auto recycler.
Only other alternative I can think of is to have the car towed to a Volvo dealership and have them make you a new key. That would be expensive. sad.gif
Let us know how you work it out.
2001 S80 T6
#3 vegasjetskier
  • 210 posts
Posted 01 October 2008 - 11:12 PM
I just tried this on my S80 - it might work on your brother's car if the design is similar.
Fold down the backseat armrest. The latch for the armrest backer is at the top center of the backer. Pull the edge of the plastic down at the top center of the backer. Insert a hard metal object (I used a key, but a screwdriver would work) and push back on the latch about 1/2" until it releases. Fold the backer down and you now have access to the trunk with no damage done. This will leave an 8" X 8" opening to fish for the keys through. On my car the latches for the seatbacks are just outside the armrest opening at the top of the seats. I can reach them through the armrest opening, but I couldn't disengage them by pulling on the cables. However, I didn't pull very hard because I didn't want to break anything.
I also discovered that there is no emergency release in my trunk! huh.gif Must be something that was added to later models. If someone forces me into my trunk, I guess I'll have to escape through the back seats into the front on the car.
2001 S80 T6
#4 vegasjetskier
  • 210 posts
Posted 01 October 2008 - 11:16 PM
P.S. I can post some pix of the above procedure if you need to see them.
2001 S80 T6
#5 VS Legend
  • 6,790 posts
Posted 01 October 2008 - 11:30 PM
Thanks Vegas, I'll see if that passthru trick works for him.
PS - Yes, the emergency release pulls for the trunk were added in later models.
I think the first car they were in was the 2004.5 S40s, but it might have also been in other 2004 or 2003 models.
#6 Chilled Man
    MILFSPEED
  • 29,897 posts
  • Gender:Not Telling
Posted 01 October 2008 - 11:40 PM
Flop the seats down and crawl in ?
#7 VS Legend
  • 6,790 posts
Posted 01 October 2008 - 11:41 PM
QUOTE (Lil-Bo-Peep @ Oct 1 2008, 07:40 PM) <{POST_SNAPBACK}>
They're locked.
#8 Chilled Man
    MILFSPEED
  • 29,897 posts
Posted 01 October 2008 - 11:43 PM
QUOTE (VS Legend @ Oct 1 2008, 07:41 PM) <{POST_SNAPBACK}>
They're locked.
how ? if you can unlock the doors should you just click the little taps at the top corners of the seats to flop them down ?
I dont have a S60 so a bit confused on this since your able to do this on all the other volvos I have owned
#9 VS Legend
  • 6,790 posts
Posted 01 October 2008 - 11:50 PM
QUOTE (Lil-Bo-Peep @ Oct 1 2008, 07:43 PM) <{POST_SNAPBACK}>
On the S60 (at least the 2001) you need to pull a latch in the trunk to unlock the seats before they can be folded down.
#10 vegasjetskier
  • 210 posts
The releases are in the trunk.
2001 S80 T6
#11 Dmsee
  • 6,579 posts
Posted 02 October 2008 - 12:22 AM
#12 vegasjetskier
  • 210 posts
Posted 02 October 2008 - 12:28 AM
QUOTE (Dmsee @ Oct 1 2008, 08:22 PM) <{POST_SNAPBACK}>
Yeah, it's on the keyfob that's IN THE TRUNK.
2001 S80 T6
#13 Dmsee
  • 6,579 posts
Posted 02 October 2008 - 12:39 AM
QUOTE (vegasjetskier @ Oct 2 2008, 01:28 AM) <{POST_SNAPBACK}>
#14 Chilled Man
    MILFSPEED
  • 29,897 posts
Posted 02 October 2008 - 12:41 AM
QUOTE (Dmsee @ Oct 1 2008, 08:39 PM) <{POST_SNAPBACK}>
#15 vegasjetskier
  • 210 posts
Posted 02 October 2008 - 12:43 AM
That one LOCKS the trunk, but does not UNLOCK it.
2001 S80 T6
#16 Dmsee
  • 6,579 posts
Posted 02 October 2008 - 12:45 AM
QUOTE (vegasjetskier @ Oct 2 2008, 01:43 AM) <{POST_SNAPBACK}>
WHat? huh.gif Ill test it in a few minutes
#17 vegasjetskier
  • 210 posts
Posted 02 October 2008 - 12:46 AM
QUOTE (Dmsee @ Oct 1 2008, 08:45 PM) <{POST_SNAPBACK}>
"Trunk lock" function
Pressing this switch locks the trunk, even if the
doors are unlocked. The trunk will remain locked even if the doors are locked/unlocked using the master key or the remote control.
To use this function:
· Turn the master key to position II.
· Press the "trunk lock" button. An LED in the button will light up and a message will be displayed in the text window to indicate that this function is activated.
· The function can be turned off (deactivated) by turning the ignition key to position II and pressing the "trunk lock" button again (the LED in the button will go out).
* The position of this button may vary, depending on the specifications of your car.
2001 S80 T6
#18 Young Burnsy
  • 2,506 posts
Posted 02 October 2008 - 12:59 AM
if the car is unlocked.
the button above the license plate should work no?
2001 S60 2.4t / 137k mi / stock / 6k HID
View Post96850_R, on 16 August 2009 - 11:23 PM, said:
its some sort of home boy ghetto mesh shit
#19 Dmsee
  • 6,579 posts
Posted 02 October 2008 - 01:02 AM
What would happen if you unlock the car with the key and then press the key button inside (lock unlock) I do that and it opens my trunk
#20 TurboS60
  • 792 posts
Posted 02 October 2008 - 03:27 AM
QUOTE (Dmsee @ Oct 1 2008, 09:02 PM) <{POST_SNAPBACK}>
Yea if you unlock the car by pressing the unlock button twice my trunk will unlock too. LoL
01 S60 2.4T
| Rica | EST | Koni | Eibach | General | Apexcone |
IPD
