Manual Swap. Installing Pedals
Posted 10 December 2008 - 09:08 PM
JVC, on 13 March 2012 - 05:56 AM, said:
Posted 10 December 2008 - 10:13 PM
You don't need to replace the bracket - just remove the top pivot bolt & swap out brake pedal/install the clutch pedal...
Posted 10 December 2008 - 11:14 PM
so i just use the factory bracket and leave it bolted to the car? makes sense, i just got confused bc the pedel set i got with my swap had the bracket on it.
Posted 11 December 2008 - 12:52 AM
one other quetion, im not replacing the clutch at the moment since it is in good condition and i need to get this thing going quick, so i dont have a alignment tool, i cant find one ANYWHERE just got back from ipd and had a long discussion and they couldnt find one either, any sugestions? i know there is no pilot bearing but is there a bushing for the flywheel? the center of the flywheel is bigger than the splines on the clutch disc so i dont see how a tool would fit in and align it.
Posted 11 December 2008 - 02:13 AM
1996 855R~ 287/304 at 18 psi~tuned by English Racing "BATLWGN"
2006 Evo 9 MR built for SCCA STU SOLO #13 #33 Sponsored by English Racing "BATLSDN"
2002 BMW Z3 M coupe "BATLCPE"
Posted 11 December 2008 - 03:03 AM
Posted 11 December 2008 - 04:10 AM
mucho thanks to both of you! not looking forward to putting this thing in tonight. had a long day here at the shop doing a clutch on a vw and headgaskets on a land rover, blahhh.
Posted 11 December 2008 - 05:17 AM
1995 Turbo motor, M56l swap, ST 17psi, Ported 16T, silicone, Koni Yellows, IPD Springs, S-Drives, stage 0, etc etc
Posted 12 December 2008 - 08:48 AM
Posted 12 December 2008 - 12:50 PM
You can strip out everything back to the ECU box - if you so desire, but there's no actual need to do so.
I itemized the wiring in my garage M66 conversion link, if you haven't bookmarked one of the main conversion threads.
Didn't have to deal w/ crank sensor, so can't help on that.
Posted 12 December 2008 - 02:11 PM
95' 850 T5,Eibach Koni FSD,Strut Bar,Adj. Endlinks,ST@17psi,FMIC,
3" DP,2.5" Cust. Cat Back Sys,EST Intake,8k HID,Silcone Everything
04' S2K, Coil Overs, HKS Exhaust, Injen Inkake, Cust. 3 Piece Wheels
98' V70 bone stock
Posted 12 December 2008 - 02:47 PM
That's what I mean by splicing - cutting them out of the trans plug, and connecting them together
You can see in my second photo where the green connects to the starter.
Hey, 2K posts
Posted 12 December 2008 - 03:06 PM
Sonic Shenanigans
#14
Posted 12 December 2008 - 04:18 PM
amd what wires/harness is the reverse light pigtail?
#15
Posted 12 December 2008 - 04:20 PM
part of the trans connector. I'm pretty sure I gave the exact pin #'s, since there's more than one blue wire...
This topic is locked
