Manual Swap Underway
39 replies to this topic
#1 Ludeless
Ludeless
  • 443 posts
Posted 15 December 2008 - 04:26 AM
The swap is well underway now...got a bunch of work done today...got the old auto shifter out finally, took the front seat out to give myself some working room
The Shifter Cables in... Didn''t put the new shifter housing in yet...was having a hell of a time making the cables fit. Is there a trick to that? I know they gotta slide through the holes and get clipped in but there''s like no slack on those suckers.. Do i need to pull the cables through the firewall pass thorough more?
Also needed to get some stuff to grease up the shifter ball joints. Theres a ton of dirt and stuff on the new shifter, so i wanna clean that up before putting it together.
Got the old brake pedal and bracket out....that thing was a major pain in the ALL GLORY TO THE HYPNOTOAD. Had to disconnect the steering column and pull it almost all the way out to get the stupid bracket off.
New Pedals ready to go in...need to order a new first...
Took me FOREVER to figure out how to get that firewall grommet pushed in. Originally i had the cables going on the left side, in front of the steering rack... Finally figured out they were supposed to go in behind it instead.
Replaced the rubber bushings on the shifter ends w/ brass bushings too.
#2 Ludeless
Ludeless
  • 443 posts
Posted 15 December 2008 - 04:29 AM
QUOTE (Ludeless @ Dec 14 2008, 11:26 PM) <{POST_SNAPBACK}>
Hehe, it censored a$S ?
#3 magicaljake
magicaljake
  • 4,455 posts
  • Interests:woman, booze, karaoke, volvos, fresh nikes,
WOW nice work!
im pretty sure you will have the only 5 speed yellow wagon in the USA
long live vanessa 2.0!
#4 Markymark
Markymark
  • 489 posts
Posted 15 December 2008 - 04:32 AM
Looks good russ if you need a hand let me know im free tues. wed. thurs. during the day. Good luck with it!
-Mark
95' 850 T5M
#5 Ludeless
Ludeless
  • 443 posts
Posted 15 December 2008 - 05:52 AM
Can i reuse the bolts i had on my flexplate for the flywheel?
#6 Tightmopedman9
Tightmopedman9
  • 1,049 posts
Posted 15 December 2008 - 06:18 AM
hey whered you get the brass bushings from? I was told QBM went out of business.
96 855T Now with 232WHP and 292WTQ
White, M56H, Black TDR 1.2's, Kilen Springs, KYB shocks, Bilstein HD struts, Precision FMIC
3" DP to 2.5" EST cat back
And yes I like mopeds, can't argue with 240 MPG
#7 johnloves850's
johnloves850's
  • 2,439 posts
Posted 15 December 2008 - 06:27 AM
WHERE IS EVERYONE GETTING THESE YELLOW T5R'S FROM!!!!!!!?????????!!!!!!
sorry i needed to vent
i'm considering painting my car yellow and passing it off like it wuddin nuddin
1993 960 wagon. Most awesome car evar.
#8 Markymark
Markymark
  • 489 posts
Posted 15 December 2008 - 07:14 AM
QUOTE (Ludeless @ Dec 15 2008, 05:52 AM) <{POST_SNAPBACK}>
I reused mine... haven't had any problems.
95' 850 T5M
#9 Hanks
Hanks
  • 3,374 posts
Posted 15 December 2008 - 07:25 AM
QUOTE (Tightmopedman9 @ Dec 14 2008, 10:18 PM) <{POST_SNAPBACK}>
lookup MR2 shifter bushings. there is a link somewhere on the forums.
#10 Boost3237
Boost3237
    Went Full Retard
  • 2,331 posts
Posted 15 December 2008 - 12:22 PM
QUOTE (850 lpt = GTI eater @ Dec 15 2008, 01:27 AM) <{POST_SNAPBACK}>
they are kept in a magic wardrobe in england
Engine build is still up for sale PM me for details.
#11 lookforjoe
lookforjoe
  • 8,304 posts
  • Interests:Making Stuff
Posted 15 December 2008 - 01:18 PM
QUOTE (Ludeless @ Dec 15 2008, 12:52 AM) <{POST_SNAPBACK}>
Not the same - the flywheel has a lot more mass - I would recommend you buy new bolts intended for a manual flywheel.
#12 jnderr
jnderr
  • 2,355 posts
Posted 15 December 2008 - 04:07 PM
Looks good, started mine this weekend too. Its been educational to say the least.
Did you have any trouble getting the shift cables mounted, mine don't want to line up and sit flush with the firewall so I can bolt them in.
98' S70 T5+M 18Xk Miles
00' V70 NA 15XK Miles
84' 242 shell at the moment
#13 Ludeless
Ludeless
  • 443 posts
Posted 15 December 2008 - 04:13 PM
QUOTE (jnderr @ Dec 15 2008, 11:07 AM) <{POST_SNAPBACK}>
YES!!! I fought with this for close to 90 minutes before i figured it out. Feed them through from the inside of the car, and make sure they go behind the power steering rack. I didn't have anyone helping me so they went on the wrong side of the steering input shaft at first and i could not get that grommet/firewall bracket to line up until i dropped the steering rack and repositioned the wires... the bracket popped right in after that.
Look at the pic of the engine bay...this shows how they should be positioned (inbetween the firewall and steering rack)
QUOTE (Tightmopedman9 @ Dec 15 2008, 01:18 AM) <{POST_SNAPBACK}>
Ebay....searched for MR2 Bushings... (as in Toyota MR2). I wasn't sure if they were the right ones since they were made for the toyota but they fit perfectly. There were several auctions that had them. Mine were 10 bucks for the set of 2.
#14 jnderr
jnderr
  • 2,355 posts
QUOTE (Ludeless @ Dec 15 2008, 11:11 AM) <{POST_SNAPBACK}>
Thanks, I'm on hiatus until next weekend but that was giving me fits!, I might follow your lead removing the front seat as getting the brake pedal and bolt out was trying enough lol
#15 Ludeless
Ludeless
  • 443 posts
Posted 15 December 2008 - 04:16 PM
This may be a dumb question...but does the manual trans also connect to the transmission fluid cooler? I haven't looked at my manual trans closely yet and when i was asking a co-worker if i should flush my trans cooler before putting the manual in, he said that most manual's don't need a cooler. I wanted to flush it to make sure no metal shavings gets in the new trans...if indeed it is connected to the cooler...
What kind of Fluid do i use for this...is it regular ATF fluid, or a different 'gear oil'?
#16 JHEIII874T5M
JHEIII874T5M
    Level 6 Senior Member
  • 14,845 posts
Posted 15 December 2008 - 04:48 PM
Volvo manual gearbox fluid works great. No tranny cooler on the manuals.
Joseph H. Essaye III
#17 Ludeless
Ludeless
  • 443 posts
Posted 15 December 2008 - 05:51 PM
QUOTE (JHEIII874T5M @ Dec 15 2008, 11:48 AM) <{POST_SNAPBACK}>
So just plug up the holes on the old trans cooler then?
#18 lookforjoe
lookforjoe
  • 8,304 posts
Posted 15 December 2008 - 06:15 PM
QUOTE (Ludeless @ Dec 15 2008, 12:51 PM) <{POST_SNAPBACK}>
no need.
#19 Chilled Man
Chilled Man
    MILFSPEED
  • 30,084 posts
  • Gender:Not Telling
Posted 15 December 2008 - 06:16 PM
dont really need to you can , I just left mine open
#20 Tightmopedman9
Tightmopedman9
  • 1,049 posts
Posted 15 December 2008 - 06:59 PM
QUOTE (Ludeless @ Dec 15 2008, 09:13 AM) <{POST_SNAPBACK}>
Do i need to grab new clips too, or are there ones on the automatic I can just reuse?
