Volvos 2 New Diesel Engines
23 replies to this topic
#1 Che'_Moderator
    Monkey Master
  • Admin
  • 23,936 posts
Posted 17 February 2009 - 04:33 PM
Two new five-cylinder diesels from Volvo: More power and less fuel consumption
Volvo Cars sharpens the company's diesel offer. Two entirely new five-cylinder, 2.4-litre turbo diesels give the customers the attractive possibility to combine more power with class-leading fuel consumption and CO2-emissions:
* The high-performance, twin-turbo D5 with 205 hp and 420 Nm of torque.
* The medium-performance, single-turbo 2.4D with 175 hp and 420 Nm of torque.
Both engines are available in the Volvo S80, Volvo V70, Volvo XC60 and Volvo XC70 from the spring of 2009.
"This is yet another step in our determination to reduce the combustion engine's environmental impact, at the same time as we give customers truly quiet and sophisticated engines with excellent performance," says Derek Crabb, Vice President, Powertrain Engineering at Volvo Cars.
The high-performance D5-engine has already been introduced in the Volvo S80 and it will be available in the Volvo V70, Volvo XC60 and Volvo XC70 from the spring of 2009.
The performance and driveability requirements in the high-performance D5-engine have been solved with twin turbochargers of different sizes that operate in sequence to provide added power within a broader rev range. The result is alert response and rapid acceleration at all speeds, with very smooth power delivery between the turbo ranges.
This twin-turbo technology in the D5 has also made it possible to introduce higher levels of exhaust gas recirculation (EGR) across a wider rev range than before. This harnesses the two turbochargers' different properties optimally to deliver a combination of high performance and low fuel consumption that is bidding for the title of best in class.
The advanced fuel injection technology uses piezoelectric fuel injectors. This provides precise distribution of the atomised fuel in the combustion chamber, resulting in efficient combustion and low emissions. At the same time, this technology and the efficient combustion create a pleasant sound bearing a closer resemblance to the elegant note of a six-cylinder petrol engine.
Together, the high-tech solutions contribute to the excellent fuel consumption (EU Combined) figures:
6.2 litres/100 km (164 g/km) in the S80.
6.4 litres/100 km (169 g/km) in the V70.
7.0 litres/100 km (185 g/km) in the XC60 (preliminary).
7.0 litres/100 km (185 g/km) in the XC70 (preliminary).
The single-turbo 2.4D - focus on fuel economy
The single-turbo 2.4D will be available in the Volvo S80 and Volvo V70 as well as in front-wheel-drive versions of the Volvo XC60 and Volvo XC70 from the spring of 2009.
The engine has been optimised with low fuel consumption in sharp focus. The injection system features another type of piezoelectric fuel injectors than in the D5, aiming to cut fuel consumption through extremely rapid and precise injection sequences. The high injection pressure results in particularly effective combustion.
To promote the drivability, the single turbocharger has been optimised to produce high torque from low revs.
The upgraded single-turbo 2.4D-engine gives a fuel consumption (EU Combined)of:
* 5.8 litres/100 km (154 g/km) in the S80 (preliminary).
* 5.9 litres/100 km (157 g/km) in the V70 (preliminary).
* 6.0 litres/100 km (159 g/km) in the XC60.
* 6.0 litres/100 km (159 g/km) in the XC70.
Mutual technology
The two new diesel engines share a number of technology solutions. The engines have lower compression, more efficient combustion and the latest generation of engine management. Volvo Cars' powertrain experts have reduced internal friction and pump losses in the diesel engines. The pressure drop in the intake and exhaust system has also been significantly reduced.
The new turbo diesels have also been equipped with ceramic glow plugs, a high-tech solution that delivers excellent starting properties owing to very quick warming up. They reach a temperature of 1,000 degrees Celsius in just two seconds, making the engine easy to start and cutting emissions. In certain driving conditions, such as at really low revs, the ceramic glow-plugs can also be used to increase the temperature in the cylinders, further improving combustion efficiency.
#2 matt b
    Earth day- Every day
  • 14,092 posts
Posted 17 February 2009 - 08:05 PM
Any hope that these would ever find their way into the US versions ?
MY97 855 Manual swap, Porsche Brakes, 16T on LPT block and plenty of IPD parts
#3 Boost Laggin
  • 399 posts
  • Crew:LBC
Posted 17 February 2009 - 10:08 PM
205hp from a twin turbo? that doesn't really seem high performance...
-Andrew-
-1998 S70 T5.(Color #427)-
-My Mods
VTEC YO!
QUOTE (Che'_Moderator @ Feb 4 2009, 08:41 AM) <{POST_SNAPBACK}>
Do you really think you drink unicorn milk for breakfast? You'r pulling on the bulls dick man and thats not milk. Wake up and open your eyes.
lolz
#4 Fudge_Brownie
    Hippie Exterminator
  • 8,063 posts
Posted 17 February 2009 - 10:11 PM
QUOTE (SactoS70 @ Feb 17 2009, 05:08 PM) <{POST_SNAPBACK}>
Agreed, I'm a little confused why they'd use two turbos rather than a single. It is still 300lb/fts of torque though.
86 Kawasaki Gpz900R Ninja
#5 Young Burnsy
  • 2,506 posts
Posted 17 February 2009 - 10:14 PM
I wonder what kind of chip gains that would be had with these engines.
2001 S60 2.4t / 137k mi / stock / 6k HID
View Post96850_R, on 16 August 2009 - 11:23 PM, said:
its some sort of home boy ghetto mesh shit
#6 Boost Laggin
  • 399 posts
  • Crew:LBC
Posted 17 February 2009 - 10:22 PM
QUOTE (Fudge_Brownie @ Feb 17 2009, 02:11 PM) <{POST_SNAPBACK}>
it may be a good chunk of torque but you'd think that you'd get more hp out of a twin turbo'd diesel that a single turbo combustion engine.
-Andrew-
-My Mods
VTEC YO!
lolz
#7 Fudge_Brownie
    Hippie Exterminator
  • 8,063 posts
Posted 17 February 2009 - 10:34 PM
QUOTE (SactoS70 @ Feb 17 2009, 05:22 PM) <{POST_SNAPBACK}>
2 turbos are not always greater than 1.
We don't know how big (or small) these turbos are either. Or if its sequential set up versus (I forget the other method name).
Diesel motors aren't designed to produce hp, but low end torque instead. Because hp is a function of tq and rpm, you can see why they aren't "horsepower" machines.
#8 Mesoam
  • 18,303 posts
Posted 17 February 2009 - 11:04 PM
didn't someone post a pic of the TT setup on the diesel...its a smaller turbo going into a larger as opposed to the older TT 13b setup...
should be interesting once one of the swedes gets their hands on one....
96 854 R, CLICK ME
The Jeep
#9 ErikS
    99.9%
  • 4,918 posts
Posted 18 February 2009 - 12:00 AM
QUOTE (Mesoam @ Feb 17 2009, 05:04 PM) <{POST_SNAPBACK}>
Aaron posted this a week ago, maybe the threads can be merged.
http://volvospeed.com/vs_forum/index.php?showtopic=111871
1995 854 T5M Click for Mods
2005 S60 2.5 T
2010 XC60 T6 AWD
#10 Zappo
    The One Upper
  • 15,044 posts
Posted 18 February 2009 - 12:51 AM
Apparently you didn't read very well because it was all explained. smile.gif
"with twin turbochargers of different sizes that operate in sequence to provide added power within a broader rev range"
#11 Zappo
    The One Upper
  • 15,044 posts
Posted 18 February 2009 - 12:59 AM
QUOTE (SactoS70 @ Feb 17 2009, 02:08 PM) <{POST_SNAPBACK}>
It is relative to what you are talking about. Of the 2 engines, the twin turbo is the high performance one.
Keep in mind these engines are more about fuel economy and cleaner emissions than smokey burnouts.
#12 ErikS
    99.9%
  • 4,918 posts
Posted 18 February 2009 - 01:15 AM
QUOTE (Zappo @ Feb 17 2009, 06:59 PM) <{POST_SNAPBACK}>
How Un-American ... wait, what?
2005 S60 2.5 T
2010 XC60 T6 AWD
#13 Fudge_Brownie
    Hippie Exterminator
  • 8,063 posts
Posted 18 February 2009 - 02:19 AM
QUOTE (Zappo @ Feb 17 2009, 07:51 PM) <{POST_SNAPBACK}>
laugh.gif You are correct, I did not.
I'll drop the excuse that I was at work reading it between doing stuff, but I don't expect that to hold much water.
#14 Zappo
    The One Upper
  • 15,044 posts
Posted 18 February 2009 - 03:29 AM
QUOTE (Fudge_Brownie @ Feb 17 2009, 06:19 PM) <{POST_SNAPBACK}>
It might. Today I said "caliper rebuild" on the phone when I meant to say "internet explorer". laugh.gif
#15 Jack8745
  • 1,127 posts
  • Interests:not facebook
Posted 18 February 2009 - 03:50 AM
QUOTE (Zappo @ Feb 17 2009, 07:29 PM) <{POST_SNAPBACK}>
i just had another baby a week ago and i been saying weird stuff since...
im so happy volvo inst going crap hybrid bs...
deisel engine usualy have low hp and high trq
K.I.S.S. - Keep It Simple Stupid
'97 854 GLT | 16T | ARD Green | OBX full exhaust | R Mani | NA TB | Unorthodox Racing Underdrive Pulley | etc...
#16 Jack8745
  • 1,127 posts
Posted 18 February 2009 - 03:53 AM
would be nice if the rods/ pistons / crank fit the old 2.4s - get some high perfomance parts second hand
#17 Dave 54
    Old Man Crew Pledge
  • 4,902 posts
Posted 18 February 2009 - 04:07 AM
QUOTE (Fudge_Brownie @ Feb 17 2009, 11:11 PM) <{POST_SNAPBACK}>
DAVE
96' 850R
#18 NoodleKnight
  • 608 posts
Posted 18 February 2009 - 05:09 AM
They're diesel engines, their limited rev range yields lower HP figures. Doesn't matter since the high torque output is what matters.
EDIT: nevermind, I should have bothered to read the other posts, lol.
1997 White 850R wagon (137,312k miles) - blown engine.
#19 Cal3thousand
  • 2,065 posts
Posted 27 February 2009 - 10:23 PM
QUOTE (Jack8745 @ Feb 17 2009, 07:50 PM) <{POST_SNAPBACK}>
Congrats!
Back on topic, what about the trannies? I see that they said they improved frictional and pump losses, but what about gearing? are these trannies strong enough to handle to the 420Nm? are they geared to take advantage of the low end torque?
1994 854 Turbo
#20 Spanky
    Has a boner for Adam's Dad
  • 1,533 posts
Posted 27 February 2009 - 11:54 PM
QUOTE (matt b @ Feb 17 2009, 12:05 PM) <{POST_SNAPBACK}>
They are aiming for 2010-2012
Contact me for turbos, turbo parts and rebuild kits
IPD
