Any Way To Get More Power At The Lower End?
23 replies to this topic
#1 Nick the stick
  • 100 posts
Posted 24 April 2009 - 10:38 PM
Volvos are obviously known for not being to fast off the line due to fwd, wheel spin etc etc... But is there any way to increase throttle response, turbo lag and gaining some more power at the lower rpms?
#2 Cal3thousand
  • 2,065 posts
Posted 24 April 2009 - 11:05 PM
QUOTE (Nick the stick @ Apr 24 2009, 03:38 PM) <{POST_SNAPBACK}>
There's a sticky for that: http://volvospeed.com/vs_forum/index.php?showtopic=86240
But I think you're looking for a Manual Boost Controller MBC... actually, read up on getting an electronic one.
1994 854 Turbo
#3 PyROTech
  • 5,305 posts
Posted 24 April 2009 - 11:07 PM
v8 solves that problem pretty well.
#4 Hoosier Daddy
  • 618 posts
Posted 25 April 2009 - 12:58 AM
QUOTE (Nick the stick @ Apr 24 2009, 05:38 PM) <{POST_SNAPBACK}>
But is there any way to increase turbo lag?
haha!
1996 855R
#5 ozzimark
  • 4,295 posts
Posted 25 April 2009 - 01:33 AM
Run a sequential turbo setup, with one really small turbo that can be fully spooled by like 1200rpm, provide enough flow to spool up a second, larger turbo by around 3000rpm that will hold to redline.
#6 jdlc
  • 1,503 posts
Posted 25 April 2009 - 04:41 PM
QUOTE (Nick the stick @ Apr 24 2009, 06:38 PM) <{POST_SNAPBACK}>
You can try play with timing - QBM used to sell that tool but no more, I think.
Wait I have one you can 'loan' wink.gif PM me if interested.
* SOLD - Joy.D - 98 S70 T5M Blk/Blk, B&G springs/Bilstein HD/TC, ipd TCV, 17psi ST tune, Volans, est short shifter, Forge BOV, SAMCO ic hoses, R-mani, 3" dp/obx exhaust, SAS delete
#7 turbor850
    i am the new pegs
  • 4,188 posts
Posted 25 April 2009 - 05:38 PM
you think you have lag with a stock turbo, anything bigger then the td04 series and then your really thinking of getting some more power at the lower rpms . . . with stock turbo that thing spoools really quick
you can change cam timing for a tad more lower end, but a boost controller on, or get a smaller turbo that spools faster laugh.gif
FIRST TO PUT 20G ON AN 850R
#8 TryingBe
  • 345 posts
Posted 25 April 2009 - 05:43 PM
Torque brake.
#9 sconeman
  • 3,953 posts
  • Interests:family, cooking, making stuff, cars
Posted 25 April 2009 - 06:12 PM
QUOTE (TryingBe @ Apr 25 2009, 06:43 PM) <{POST_SNAPBACK}>
Torque brake.
3" DP, good tune up, premium gas, open exhaust and mbc have all helped my car. there is significant turbo lag regardless.
#10 Fudge_Brownie
    Hippie Exterminator
  • 8,068 posts
Posted 26 April 2009 - 12:34 AM
I really don't think you are experiencing much for 'turbo lag' if your car is running up to par.
I think the answer is simply a lower compression engine compared to most people's NA's.
86 Kawasaki Gpz900R Ninja
#11 J0E
  • 2,025 posts
Posted 26 April 2009 - 08:57 AM
QUOTE (ozzimark @ Apr 24 2009, 06:33 PM) <{POST_SNAPBACK}>
Exactly. This is the best way.
#12 sconeman
  • 3,953 posts
Posted 27 April 2009 - 02:35 AM
QUOTE (J0E @ Apr 26 2009, 08:57 AM) <{POST_SNAPBACK}>
yeah and so easy to do
#13 FastWagon95
  • 1,423 posts
Posted 27 April 2009 - 02:58 AM
QUOTE (sconeman @ Apr 26 2009, 10:35 PM) <{POST_SNAPBACK}>
Maybe you didn't sense his sarcasm.
'95 855 T5M Shaved is better
#14 JVC
  • 6,678 posts
Posted 27 April 2009 - 05:24 PM
How about a Supercharger?
\Posted Image
#15 TryingBe
  • 345 posts
Posted 27 April 2009 - 06:12 PM
After market ECU.
#16 cr854r
  • 894 posts
  • Interests:Club Racing, Auto X, Volvo
Posted 27 April 2009 - 06:17 PM
Projekt R
-Megasquirt
, 18t, 3in turbo back, kw v2 coilovers, M56H, fmic, 16 point roll cage, corbeau seat/harness, gutted to hell, *solid bushings, *F/R sways, walbro 255, 450cc injectors, NA cams, willwood brakes, port/polished head, *rsi rods, *R mani, adjustable control arms, adjustable strut top mounts, adjustable sway bar links... etc etc
#17 shanehutton
  • 947 posts
Posted 27 April 2009 - 07:16 PM
It also had 2 turbos. That car was silly.
'00 S70 SE (slow/sold)
#18 sconeman
  • 3,953 posts
Posted 27 April 2009 - 09:52 PM
QUOTE (FastWagon95 @ Apr 27 2009, 02:58 AM) <{POST_SNAPBACK}>
LOL now it all makes sense
#19 beckzach05
  • 183 posts
  • Crew:SCC
Posted 27 April 2009 - 10:06 PM
QUOTE (cr854r @ Apr 27 2009, 02:17 PM) <{POST_SNAPBACK}>
Doug Strickland ftw!
'98 S70 GLT, T5 ecu, Forge bov, 15G, 13psi
Che_Moderator said:
Oh my bad. I did not know you had invoked the double post death clause.
#20 J0E
  • 2,025 posts
Posted 28 April 2009 - 03:49 AM
QUOTE (JVC @ Apr 27 2009, 10:24 AM) <{POST_SNAPBACK}>
For sure...a custome positive-displacement supercharger setup would be awesome for low-end, too! On top of that, throw in a stroker kit and the car wil fly!
Do it!!
IPD
