Pcv System Completed But Having Crappy Idle
Posted 03 May 2009 - 02:53 PM
'91 240 Sedan- Sold 4/21/09
Posted 03 May 2009 - 03:17 PM
Same shit happened to me, after working on that thing for 6 1/2 hours. It ended up being the vacuum line that plugs into the left side of the intake manifold. Thing popped out on me, was a pain in the ass to get back in once the manifold was on.
dumpt 1990 765
Posted 03 May 2009 - 03:25 PM
Posted 03 May 2009 - 07:50 PM
Posted 03 May 2009 - 08:49 PM
Posted 03 May 2009 - 11:48 PM
Posted 04 May 2009 - 01:19 AM
Posted 04 May 2009 - 01:54 AM
An unlit propane torch will also raise the idle at any vacuum leaks. I've found it to be a better indicator than the carb cleaner but either one does work.
80 242, 92 944T, 93 245, 98 S70 GLT
Plus many other wheeled devices
Posted 04 May 2009 - 02:30 AM
Posted 04 May 2009 - 03:55 AM
Okay, thanks for your input regarding the intake manifold gasket. I'll pick one up at the dealer tomorrow or the next day- I did use a FCPG one
Posted 04 May 2009 - 04:36 AM
I used the fcp kind for our V70 NA and my previous 94 855T, and didn't have any issue.
I do have the green oem gasket now waiting for install on my T5M when I service the pcv.
Posted 04 May 2009 - 06:10 PM
Are you not supposed to reuse them? I did, seems to run fine.
Posted 04 May 2009 - 11:26 PM
Suppose you could but why ?
#14
Posted 05 May 2009 - 12:23 AM
#15
Posted 05 May 2009 - 12:40 AM
#16
Posted 05 May 2009 - 03:31 AM
Are they known for being bad "out of the box"? I used one when I did my PCV system and I have had no problems after about 100 miles. This was my first time doing the PCV system also.
#17
Posted 05 May 2009 - 04:21 AM
#18
Posted 05 May 2009 - 09:57 AM
FCP manifold gasket worked okay for me – I ran into a problem with the little bracket on the bottom right manifold bolt which gave me a similar but much worse rough idle than the condition you describe. The bracket ended up between the manifold and the block, an easy oversight for a n00b like me. The manifold bolt threads through it and it needs to be held away from the block while reinstalling the manifold.
Also just wondering, did you torque the manifold bolts when you reinstalled them to 14 foot lbs?
#19
Posted 05 May 2009 - 02:10 PM
Because you'll end up like MIJ...
#20
Posted 05 May 2009 - 02:49 PM
Personally, I won't settle for less than a genuine Volvo bidet from Waltrip in an official blue box with the Volvo logo on it. I always order the one with the latte in it.
-JH
Minneapolis, MN
