So far, all i know is that i need to somehow connect into the Reverse lights, Speed Sensor, and PNP switch, but really have no idea where to do this. I'm not very good at wiring or reading wiring diagrams, so any help w this would be greatly appreciated.
Also, what do you guys do about the old automatic harness sheath? The molded plastic case on the harness is shapped to fit and attach to the old automatic... Although with the manual trans in there, it seems to rub against the gear selector switch. It also looks like it is very close to the slave cylinder and throwout fork. I'm wondering if these will cut into over time.
What do you guys do about the harness? Whats the best way to route it?
Here's where it hits the shifter arm
And where it hits the throwout fork.
For the wiring, what do these connect to? I think this is the trans speed sensor.
Thanks!
