Tb,water Pump,tensioner,and Pulleys Question?
37 replies to this topic
#1 SIXER
SIXER
  • 147 posts
Posted 06 May 2009 - 01:10 AM
So i going to get my waterpump,TB,Tensioner and pulleys done but i want to order them off of fcp because its cheaper then the dealership but i am worried about something breaking i don't no when the last time the pump pulleys or tensioner was done i no the tb was done at 114000KM in 03 and the car now has 250000KM in bay 13 it says change the TB every 70000miles or 5years is there any signs or symptoms i can look for on the belt and or any of the other parts i don't hear anything that sounds like a bad pulley only for a little whine that im pretty sure is the power steering pump so what do you guys think?
1998 S70 T5 SE
#2 DonutsDemise
DonutsDemise
  • 3,431 posts
Posted 06 May 2009 - 01:12 AM
I would go with all OEM parts for a critical service like this one. order from Darrell Waltrip Volvo they give us a nice discount.
also, unless you can pinpoint where the noise is coming from none of us will be able to tell you for sure it's not something with the timing belt. however, the whining is probably from something else like the serp belt a/c bearings power steering pump or something
Jake
1998 Volvo S70 T5M 183k
#3 Dave 54
Dave 54
    Old Man Crew Pledge
  • 4,902 posts
Posted 06 May 2009 - 01:22 AM
Change the belt, there not like the old red blocks that had non-interfering motors. If it breaks, it's way more costly to rebuild the engine than to change the belt.
But yes, look for shiney surface wear it rides on the pulley and look for dry root cracks, that's about it, but if you see those things i'd replace it ASAP.
DAVE
96' 850R
#4 SIXER
SIXER
  • 147 posts
Posted 06 May 2009 - 01:50 AM
QUOTE (vlvfreak @ May 6 2009, 01:22 AM) <{POST_SNAPBACK}>
so for this shiney stuff do i look on the smooth part of the belt?
1998 S70 T5 SE
#5 Falcone
Falcone
    Pvt. Douche Nozzle
  • 1,320 posts
  • Interests:Throwing rocks from my glass house, fire, speed and substances
Posted 06 May 2009 - 03:47 PM
Just keep an eye on the tb. If it looks like shat, change it. If you change it, change everything else down there. Tb is a bizsnatch to get off the crank and back on, and the tensioner pully is a kunt to get off due to t-45 and little space. I just did mine and the last time it was done on this particular car was in 02 at 144,xxxkms. Changed it at 330,xxx kms couple weeks ago. Just be smart about it and you will be fine. The noise most likley is the power steering pump pully. How's the serp belt?
Mike
K-Town Brick Militia______________94 854 The BBQ_________________97 Pewter T5 teh dd
I was us up all night with a rusty hammer trying to build a fence around these magic beans my dreams have gathered
#6 Matty Moo
Matty Moo
  • 1,456 posts
  • Interests:Getting Trim, 40's and Birdwatching.
Posted 06 May 2009 - 04:39 PM
There's huge thread that's fairly recent all about this. Take the time to read up on it, then find some others and read them.
Tensioner bolt can be a pain. Be prepared for it and it's not so hard.
The timing belt is a pain to get off, but goes on fairly easy. That's why you cut it off. You aren't reusing it.
The water pump is all by feel. I didn't have any problems, just be sure not to screw up the gasket. Don't reuse the bolts.
If it's time, then change it. Don't look for signs that it might fail.
Do it right. No second chances with it.
#7 SIXER
SIXER
  • 147 posts
Posted 07 May 2009 - 01:42 AM
QUOTE (Falcone @ May 6 2009, 04:47 PM) <{POST_SNAPBACK}>
Mike
yah i think i will pay someone to do it that is a sticky mess for me i don't want to fxxk anything up ill post some pics of it now in a few and tell me what you all think i don't think it looks that bad but i am goin to change it i just need a few weeks for the parts to get here but i am very nervous about something breaking . and the serp belt looks fine.
1998 S70 T5 SE
#8 7 VII 7
7 VII 7
  • 22,522 posts
Posted 07 May 2009 - 01:52 AM
EVERYTHING you need to know
the hard part is getting the ^ marks lined up exactly
1 of 1 - '97 427 854R - 110k
#9 SIXER
SIXER
  • 147 posts
Posted 07 May 2009 - 02:50 AM
QUOTE (SIXER @ May 7 2009, 01:42 AM) <{POST_SNAPBACK}>
ok here are some pics i just took them and its night so there not the best but tell me what you think<a href="http://s617.photobucket.com/albums/tt254/cabbott709/?action=view&current=carpics017.jpg" target="_blank"><img src="http://i617.photobucket.com/albums/tt254/cabbott709/carpics017.jpg" border="0" alt="Photobucket"></a>
1998 S70 T5 SE
#10 7 VII 7
7 VII 7
  • 22,522 posts
Posted 07 May 2009 - 02:51 AM
what are we looking for?
#11 SIXER
SIXER
  • 147 posts
Posted 07 May 2009 - 02:58 AM
QUOTE (7 VII 7 @ May 7 2009, 02:51 AM) <{POST_SNAPBACK}>
just to show the condition of the belt i don't no if this can help.
1998 S70 T5 SE
#12 7 VII 7
7 VII 7
  • 22,522 posts
Posted 07 May 2009 - 03:02 AM
these pictures are too fuzzy to make a good judgement
#13 SIXER
SIXER
  • 147 posts
Posted 07 May 2009 - 03:04 AM
QUOTE (7 VII 7 @ May 7 2009, 03:02 AM) <{POST_SNAPBACK}>
yah i thought that i will have to take some in the day.
1998 S70 T5 SE
#14 Matty Moo
Matty Moo
  • 1,456 posts
Posted 07 May 2009 - 03:07 AM
You already know that it needs to be replaced. Put your hand in your pants, find your nuts, then replace it. It's not that hard. I've changed worst and pulled through.
Your components have rust on them. How much salt do they dump on the roads up there? I thought Michigan was bad.
#15 SIXER
SIXER
  • 147 posts
Posted 07 May 2009 - 03:17 AM
QUOTE (fatty matty @ May 7 2009, 04:07 AM) <{POST_SNAPBACK}>
lol yah i am goin to change it just like i said before i just need a few weeks for the parts to come in so in the mean time i don't want it to break thats all and i thought someone could tell me if its too bad to drive on thats all and yah they use alot of salt and where surrounded by salt water it is newfoundland lol
1998 S70 T5 SE
#16 Matty Moo
Matty Moo
  • 1,456 posts
Posted 07 May 2009 - 03:41 AM
QUOTE (SIXER @ May 6 2009, 11:17 PM) <{POST_SNAPBACK}>
There wasn't a single punctuation mark in your whole response. Please type like a normal person. Use sentences, proper grammar and punctuation. Everybody on this site attended school.
#17 SIXER
SIXER
  • 147 posts
Posted 07 May 2009 - 09:06 PM
QUOTE (fatty matty @ May 7 2009, 03:41 AM) <{POST_SNAPBACK}>
i didn't no this was an english test look man if got nothing to say about the post don't say nothing at all i don't want your 2 cents.
1998 S70 T5 SE
#18 7 VII 7
7 VII 7
  • 22,522 posts
Posted 07 May 2009 - 09:09 PM
QUOTE (SIXER @ May 7 2009, 05:06 PM) <{POST_SNAPBACK}>
fatty matty is a ***... just take better pictures of your belt.. but it sounds like you need to do it because of time
#19 SIXER
SIXER
  • 147 posts
Posted 07 May 2009 - 09:13 PM
QUOTE (7 VII 7 @ May 7 2009, 09:09 PM) <{POST_SNAPBACK}>
Yeah i'm goin to its a shitty day here now so ill have to wait untill the weekend...and yah i agree with you he is but anyway. thanks for the help.
1998 S70 T5 SE
#20 wheelsup
wheelsup
  • 371 posts
Posted 07 May 2009 - 09:18 PM
FYI punctuation and grammar help people understand you better and you'll probably get more responses from the more experienced people around here if you sound more educated and like an adult, not a 16 year old. Just my $0.02. Not sayin' anything just a suggestion.
Oh and I wouldn't buy from FCP, they sell aftermarket parts in their kit. If you do buy it from them I would call them directly and place your order. Also my dealer in NC is cheaper than FCP on most of their Volvo branded stuff.
1995 850 GLT w/ 145,000 miles
