Additives To Combat Ethanol
28 replies to this topic
#1 decker
  • 162 posts
  • Interests:Cow Tipping
Posted 15 May 2009 - 04:47 PM
Anyone had issue's with 10% ? It's about to get worse.
15% is on the way mad.gif http://www.businessweek.com/lifestyl...=rss_lifestyle
http://www.fuel-testers.com/review_g..._products.html
QUOTE (decker @ May 15 2009, 11:46 AM) <{POST_SNAPBACK}>
sorry... http://www.businessweek.com/lifestyle/cont...d=rss_lifestyle
"yes dear... we're getting a station wagon"
#2 GeraldJ
    Professional Cow Fister
  • 1,496 posts
Posted 15 May 2009 - 04:51 PM
QUOTE (decker @ May 15 2009, 11:47 AM) <{POST_SNAPBACK}>
I run e85 in my wag. No problems. If I get out somewhere they dont have e85 I can top it off with 87 if I have more then a half a tank.
Besides its only $1.37 2 blocks from my house.
'96 855, Koni yellows, ipd springs, TT-USB
Eagle H-beams, Weisco pistons, custom cams
GT3071R, 60lb/hr injectors, Ported R Mani, W2A intercooler
m56h, 707 clutch, P&P'd head, CAI,
#3 Che'_Moderator
    Monkey Master
  • Admin
  • 23,936 posts
Posted 15 May 2009 - 05:05 PM
And 15% is not going to hurt anything. Most of you guys are so pig rich anyways a little ethanol will dry the fuel and get your AFRs in check
#4 randomdude
  • 2,383 posts
  • Gender:Not Telling
Posted 15 May 2009 - 06:32 PM
^bwahaha. to true, lol.
i cant wait for an e85 tune, lol.
my 854T5 with a nice list of mods was totaled by a dumb girl driver :(
1991 780TIC-RARE!-named "roxanne" by the GF.-more pressure-less restrictions-plenty of suspension bits to come!
#5 GeraldJ
  • 1,496 posts
Posted 15 May 2009 - 06:34 PM
QUOTE (Che'_Moderator @ May 15 2009, 12:05 PM) <{POST_SNAPBACK}>
Stock? Where have you been?
I have a 50trim garrett, r manifold, 410cc injectors, MTE tune (JCViggen's), NA cams, and the list goes on and on and on
#6 Che'_Moderator
    Monkey Master
  • Admin
  • 23,936 posts
Posted 15 May 2009 - 06:52 PM
QUOTE (GeraldJ @ May 15 2009, 01:34 PM) <{POST_SNAPBACK}>
#7 cr854r
  • 894 posts
  • Interests:Club Racing, Auto X, Volvo
Posted 15 May 2009 - 07:17 PM
sounds stock to me lol
Projekt R
-Megasquirt
, 18t, 3in turbo back, kw v2 coilovers, M56H, fmic, 16 point roll cage, corbeau seat/harness, gutted to hell, *solid bushings, *F/R sways, walbro 255, 450cc injectors, NA cams, willwood brakes, port/polished head, *rsi rods, *R mani, adjustable control arms, adjustable strut top mounts, adjustable sway bar links... etc etc
#8 Tightmopedman9
  • 1,034 posts
Posted 15 May 2009 - 08:27 PM
QUOTE (cr854r @ May 15 2009, 01:17 PM) <{POST_SNAPBACK}>
You need to build the engine to safe(ish)ly run e85, if the tolerances aren't tight enough you'll get e85 in your oil along with other problems.
96 855T Now with 232WHP and 292WTQ
White, M56H, Black TDR 1.2's, Kilen Springs, KYB shocks, Bilstein HD struts, Precision FMIC
3" DP to 2.5" EST cat back
And yes I like mopeds, can't argue with 240 MPG
#9 Che'_Moderator
    Monkey Master
  • Admin
  • 23,936 posts
Posted 15 May 2009 - 09:35 PM
Thats kinda what I was getting at. A/F will be way out of whack on top of the fact you will see massive piston wipe unless you have the correct rings, or run a topend lube/ethanol safe oil. Methanol/Ethanol engines have been around decades. Nothing new here, but you do need to take basic precautions.
#10 RZT5
  • 3,334 posts
Posted 15 May 2009 - 10:31 PM
QUOTE (Che'_Moderator @ May 15 2009, 05:35 PM) <{POST_SNAPBACK}>
how about corrosion issues?
and how are rings intended for use with ethanol different from normal rings?
98 C70 HPT M
98 S70 T5 M - sold | 98 V70 T5 M - rear ended and totaled | 95 850 Turbo M - sold
#11 L8 APEKS
  • 760 posts
  • Interests:I LIKE TO RIP PEOPLE OFF.
    http://volvospeed.com/vs_forum/index.php/topic/135080-wheres-l8-apeks/
  • Crew:LBC
Posted 15 May 2009 - 10:54 PM
QUOTE (RZT5 @ May 15 2009, 10:31 PM) <{POST_SNAPBACK}>
They aren't.
#12 turbor850
    i am the new pegs
  • 4,188 posts
Posted 15 May 2009 - 10:55 PM
QUOTE (GeraldJ @ May 15 2009, 02:34 PM) <{POST_SNAPBACK}>
whats that good for, 315 whp ?
FIRST TO PUT 20G ON AN 850R
#13 Che'_Moderator
    Monkey Master
  • Admin
  • 23,936 posts
Posted 15 May 2009 - 11:26 PM
QUOTE (L8 APEKS @ May 15 2009, 05:54 PM) <{POST_SNAPBACK}>
They aren't.
They run a different top ring and are much less gap. They are usually built out of a more corrosive resistant metal also since the alcohol tends to collect in the ring lands. But thanks for playing.
#14 MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 16 May 2009 - 12:11 AM
QUOTE (Che'_Moderator @ May 15 2009, 01:05 PM) <{POST_SNAPBACK}>
I am convinced that the 10 to 15% does do catalyst damage in certain circumstances, proving it is a different story though. I do agree on a fat running modded car it won't hurt a thing.
"SMOKE TROUT NOT CRACK"
#15 Che'_Moderator
    Monkey Master
  • Admin
  • 23,936 posts
Posted 16 May 2009 - 02:20 AM
QUOTE (MrWinkey @ May 15 2009, 07:11 PM) <{POST_SNAPBACK}>
Cars have been running E10 every winter since the 70s, nothing new here.
#16 GeraldJ
  • 1,496 posts
Posted 16 May 2009 - 02:45 AM
QUOTE (turbor850 @ May 15 2009, 05:55 PM) <{POST_SNAPBACK}>
Whats it good for or what does it currently have?
#17 MrWinkey
  • 4,759 posts
Posted 16 May 2009 - 07:16 PM
QUOTE (Che'_Moderator @ May 15 2009, 10:20 PM) <{POST_SNAPBACK}>
Yes but the mixture is fatter in the winter as well
#18 johnloves850's
  • 2,431 posts
Posted 16 May 2009 - 11:14 PM
i'm pretty sure you'll kill your fuel system as well
alcohol will rust out your fuel lines
and that is also something i do not want to deal with
they don't even have e85 around my area yet for whatever reason
1993 960 wagon. Most awesome car evar.
#19 JESSEXC
    Voice of Reason's Son
  • 3,249 posts
Posted 17 May 2009 - 12:00 AM
In the marine industry I have seen it break down fuel lines which then clog up the injectors. We have also had problems with water forming in fuel tanks. I have a 1982 K5 Blazer and the first couple of tank fulls of 10% ethanol loosened up any debris that was in my fuel lines and fuel tank then clogged the the fuel filter. Carb was removed twice in order to clean jets. wink.gif
http://www.boattest.com/Resources/view_news.aspx?NewsID=3345
QUOTE
There are 18 million boats currently in operation in the U.S., and none of them have been designed, certified or warrantied to run on anything above E10.
QUOTE
Ethanol is a solvent
2002 XC Ocean Race # 377 of 650 Mods: Volvo rear center seat cooler,Back up Camera
#20 Che'_Moderator
    Monkey Master
  • Admin
  • 23,936 posts
Posted 17 May 2009 - 01:31 AM
QUOTE (JESSEXC @ May 16 2009, 07:00 PM) <{POST_SNAPBACK}>
QUOTE
So is petrol..... so is water....
IPD
