Volvospeed Forums: 19T Boost Fade. - Volvospeed Forums
  • (2 Pages)
  • 1
  • 2
  • You cannot start a new topic
  • You cannot reply to this topic
19T Boost Fade. Rate Topic: -----
#1 User is offline   Autotechnica Icon
  • Level 2 Member
  • Icon
  • Group: Supporting Member
  • Interests:European cars, track racing, auto cross, driving school, etc.
Posted 27 June 2009 - 02:39 PM
Hey guys, finally my car is running reliably and properly with the 19T setup. My AFRs are good and the car boots. I just have some questions about boost fade. I've seen that this is quite common with all the volvo/mitsu turbos. I got fade when I had my 15G, I get fade now with the 19T. Is it because of the internal wastegate or actuator? Does the stock one only hold around 15psi of boost? What happens is I get 20psi of boost when I first hit WOT in 3rd or 4th gear (I have a 5 speed), then after 4800-5000RPM it slowly drops to 15-16psi and stays there. I'm using the AVC-R and no amount of fiddling with higher rev duty cycles seem to fix the problem. Are there upgrades I can get to fix this? Everyone says to get the S60R mani, but from people I've talked to who have done this, this does jack for boost fade. It really seems more like the factory wastegate isn't holding the boost. Any help much apprecaited, I really love the 19T and it's making great results right now, just wish I could hold at least 18psi to redline. I've read something a while ago about someone modding a Garett actuator to fit?
BTW some basic mods as follows...
19T angle flanged, green injectors, RICA tune, walbro 255 pump, AEM AFPR, Apexi AVCR, M56L w/ bully modified R pressure plate and carbon kevlar clutch disc, 3" d/p, 2.5" exhaust, FMIC, EST RIP, TurboXS BOV, etc etc...
thanks guys,
Bry
1996 Pewter Silver Volvo 850 19T Turbo (301.2WHP/353.3lbs*ft TRQ @ 18.5PSI, DynaPak) - Dyno'd 7/11/09
2006 SAAB 9-3 Aero 6spd BSR Tuned
0
#2 User is offline   turbor850 Icon
  • i am the new pegs
  • Icon
  • View blog
Posted 27 June 2009 - 02:43 PM
get rid of that BOV for one, or take it out and see if you can get higher boost in the higher gears, report back . . .
The Old Sold 850R - Dyno Tuned To ~ 430+HP 480+TQ @ 22.5 psi - 20G - AUTO - Mustang Dyno - EPL #1 Cheerleader
FIRST TO PUT 20G ON AN 850R
#3 User is offline   B Mac Icon
  • Ginger Beater
  • Icon
  • View gallery
Posted 27 June 2009 - 02:45 PM
An R manifold will definitely help smooth the flow out. Do you have n/a cams or anything too? I'm having the same problem with my 15g (n/a cams, 3" exhaust, R mani) so I think the only thing left I can do is get it tuned to add some timing in the top end. Have you talked to RICA about it at all??
BENNNNNN : 213k mile 95 854- m56, 3" turbo->tip exhaust, S60R ex. mani., n/a cams, 16t, Garret 11psi wg, fmic, 350cc inj., oil cooler, Greddy Profec B Spec II, bilstein HD, EST springs, 302mm brakes, IPD strut tower/25mm rear...242whp, 310wtq on a mustang dyno <not for long
matt b: :rolleyes: ....Like he said, you can take the boy out of TB but you can't take TB out of the boy... :P
#4 User is offline   Autotechnica Icon
  • Level 2 Member
  • Icon
Posted 27 June 2009 - 02:58 PM
Getting a good tune from RICA is like playing the lottery. I'm just glad I finally have my tuning issues sorted out. The RICA tune was tunned too rich at low revs but too lean at high revs. I honestly don't know how cars are running around with 19T's that have tunes like that!
Anyways, I have N/A cams sitting in my basement, do they help at all?
Why would the BOV cause it to fade? I can tighten the spring so it barely vents, but it still does the same thing. BTW, I don't think the stock CBV likes seeing that much boost. I hate putting in the stock CBV, it's always death....
0
#5 User is offline   dublin14 Icon
  • Level 2 Member
  • View gallery
  • Group: Members
  • Interests:Racing Nasa HPDE
Posted 27 June 2009 - 03:03 PM
As soon as i put on my R mani, my car felt smoother and better up top! I have a cracked intercooler, but could still feel the difference. I have to yet install my Precision FMIC. I think your crazy not to have an R-mani with your current set-up! More HP, smoother, and lower EGTs with the better flow... the last piece of the puzzle! I bought mine at "Cookstown auto wreckers" for $150, in perfect condition... try them!
98 S70 T5SE 5-speed M56H-with short shifter /110k / Rica Tune / 18T Turbo with Cherry Turbos HD actuator / ES filter / ES Coil-kit / 3" DP & Magnaflow Racecat / Eurosport Catback / S60R Manifold / UR Pulley / IPD 14lb HD CBV spring / LSP MBC 18psi / Samco hoses / Stylin Motors Vac Lines / IPD Upper mount/ Eurosport CarbonFiber strut brace / Carbon Fiber Engine Cover /Autometer Turbo Gauge/ AEM AFR gauge/ QBM Trim Rings/ TME Springs / Pegasus Rims/ Dunlop Direzza DZ101/ 6000K HIDS / R Bumper / Clear Corners / Euro Side Markers / XC70 Grill/Piaa H1 fogs / Piaa Plate Leds/ Porsche 993 TT BBK & X drilled/slotted rears, Hawk HPS pads, IPD SS hoses / Precision FMIC. NA TB going on soon!
-1
#6 User is offline   Autotechnica Icon
  • Level 2 Member
  • Icon
Posted 27 June 2009 - 03:05 PM
STEAL!!!! Do they have anymore? Maybe they have some tranny's too
BTW, do you ever get out to meets or even the track? I'd love to see your car. We can discuss all the things wrong with the RICA tune and the 19T.. lol
0
#7 User is offline   dublin14 Icon
  • Level 2 Member
  • View gallery
  • Group: Members
Posted 27 June 2009 - 03:16 PM
I bought mine early this year! But call them if they have "any" Volvo 2.5T 04+ manifolds, with the last two numbers ending in "2 1" thats what you want. Mine came of an XC90, there all the same for the 2.5T engine!
0
#8 User is offline   dublin14 Icon
  • Level 2 Member
  • View gallery
  • Group: Members
Posted 27 June 2009 - 03:39 PM
I have only been out on the track in my Volvo a few times. Most of the time i spend on the track is in the US racing in the NASA with a great friend of mine who trusts me in his 600HP C6 Z06 track built! He actually just had a World challenge Katech C6R built for him, 660hp and 2600lbs and no expense spared... she well be finest car i have driven yet. Next spring if my i beat this last ticket i will be picking up my own C6 Z06 for the street and track, if not i wait one more year :angry: I have more plans for the Volvo, in the next while put on my UR pulley, NA TB,and the FMIC. Then Porsche brakes, and Konis/IPD sway bars and then i will spend more time at the track. Shes in for paint as we speak!
-2
#9 User is offline   turbor850 Icon
  • i am the new pegs
  • Icon
  • View blog
turboxs bov have washers to tighten them if iirc ? what spring ?
#10 User is offline   Autotechnica Icon
  • Level 2 Member
  • Icon
Posted 27 June 2009 - 05:44 PM
The whole point of adding washers is to tighten the tension of the spring. I assumed you already knew how a BOV worked and I didn't need to explain adding washers. Theoretically you're just tightening the spring. Add enough washers and the BOV won't vent and you just get compressor surge. I've already ruled out the possiblity of a leaking BOV. Anyways, I've seen on every single 19T video or even in person that there is boost fade past mid ranged RPM's. I just wanted to know if there were actuator upgrades available. I still see fade on my friends 19T w/ S60R manifold and CBV, so I assume it has to do with the actuator. As per my understanding, people normally get BOV's to run higher boost when the stock diaphrams max out and tear.
0
#11 User is offline   Autotechnica Icon
  • Level 2 Member
  • Icon
Posted 27 June 2009 - 05:52 PM
Sweet, is the N/A TB larger? Just out of curiousity do you know where I can score a pulley to replace the A/C compressor?
0
#12 User is offline   dublin14 Icon
  • Level 2 Member
  • View gallery
  • Group: Members
Posted 27 June 2009 - 06:31 PM
Its a NA TB modified with a 960 plate! Bigger and better flow! Not sure about the pulley?
0
#13 User is offline   RZT5 Icon
  • Level 3 Member
  • Icon
  • View gallery
Posted 27 June 2009 - 07:54 PM
Your boost fade is happening because of the combination of a small turbine housing relative to the amount of air you are trying to flow, the wastegate flapper's diameter, and the actuators ability to hold the wastegate closed. Out of this list the only one you can modify without changing turbos is the actuator.
I would try modding a stronger actuator to fit, or get a custom built one from forge for example. The 19T actuators are meant to control boost effectively at around 12 psi on a volvo whiteblock. the pressures inside the turbine housing required to make 18psi at redline on our motors multiplied by the area of the wastegate flapper and the length of the flapper arm is simply more than the amount a force the actuator can produce which is why its opening.
95 850 Turbo M sold for parts | 98 V70 T5 M rear ended and totaled | 98 S70 T5 M now Cassie's
98 C70 HPT M
3
#14 User is offline   EricF Icon
  • tbricks spy
  • Icon
  • Group: OH Moderator
  • Crew:LBC
Posted 27 June 2009 - 09:28 PM
Good post. That said, the 300/70 19T actuator should be more than sufficient if it's in good shape. Given how much travel these actuator springs need to do, I wonder if they ever start to get tired?
My 19T/manual setup was absolutely dead rock solid with just a bleed type manual boost controller, even to 23-24 psi it would hold the target boost level until redline.
I would try messing with actuator arm preload, less preload should be less spiking. Aside from that, maybe try a new or different actuator. The 300/70 worked perfectly fine for me, but maybe not for others.
As an aside, on my blue car currently (B21FT with nice-flowing head and decent cam), I spike 24-25 psi and fade to 19-21. This is with the angle outlet housing and the wastegate flapper essentially wired shut. With a ported conical housing and the same setup otherwise, the fade was to 16-17 psi by redline. I think now it may be the exhaust limiting it, or it could just be the turbine wheel itself though based on my past experiences with the 19T I'm inclined to try other things before accepting that possibility.
1984 244 GLT - blue rat rod (cardomain)
1995 850 turbo - "She may not look like much, but she's got it where it counts kid"
"Pay no attention to what critics say. No statue has ever been put up to a critic." -Jean Sibelius
0
#15 User is online   TorqueSteer Icon
  • Pretty Boy Racing
  • Icon
Posted 27 June 2009 - 10:29 PM
Im leading towards the small turbine housing. On my Td05 housing, I have zero fade on stock manifold, stock heads etc.. The wastegate is also very strong. Maybe you can order one from Hahn and retrofit it on there.
1995 850 Turbo | Hahn Racecraft Td05-Super 16g Turbo | 3" turboback exhaust | Water/ Methanol Injection | Custom FMIC | HKS SSQV BOV | Civinco Piggyback EMS | Walbro 255 LPH Fuel Pump | Innovate LM-1 A/F Meter | Koni Coilovers | QBM Endlinks | IPD Sway Bars | Profec B EBC | Bi-xenon Projector Retrofit
0
#16 User is offline   turbor850 Icon
  • i am the new pegs
  • Icon
  • View blog
Posted 27 June 2009 - 11:13 PM
my auto when I had a 19T would fade a bit in 1st and second and stay rock solid 20 psi in third . . . maybe you need a new boost controller
wastegate from Hahn is 10X stronger then any td04 wastegate, Fiore has one on his td04-super60-turbzilla and his is just hold any boost anytime, no fade
#17 User is offline   lookforjoe Icon
  • Level 4 Member
  • Icon
  • Group: Lifetime Supporter
Posted 28 June 2009 - 01:43 AM
I only had about 2psi fade on my 19T using the stock CBV (shimmed for 20psi) - and a LSP MBC.
1998 V70 XC M66 Hahn 20g Built T5M Motor TurboTuner coming! My Build Thread
VOLVOSPEED SEARCH
0
#18 Guest_duke of cruel_*
  • Group: Guests
Posted 01 July 2009 - 10:26 AM
16-17 psi of boost at max rev is about what the 19T can deliver and with a good ignition and fuelmap its about the 350 hp the 19t is good fore. You have more boost in the midrange because the engine demands less air, and therefore the turbo can make higher boost. With glt cams you can only produce about 0.9 bar of boost (13 psi) at high rpm and get the same 340-350 hp because thats the amount of air the turbo will deliver. If you want more power, get rid of parasitic losses cat, aircon, intake heat, exhaustmanifold heat etc etc.
DoC
1
#19 User is offline   JCviggen Icon
  • Level 3 Member
  • Icon
Posted 01 July 2009 - 11:00 AM
Why does it only go to 5500rpm? It's at 6-6.5 that the 19T really drops off, no surprise at 5.5K :)
0
#20 User is offline   TBM Icon
  • Level 4 Member
  • Icon
  • Crew:ECC
Posted 01 July 2009 - 02:18 PM
I get the same exact behavior from my 16T. I thought it was related to a small boost leak somewhere (even though I've done Stage 0), but after reading your post, I'm almost convinced it's something else.
1998 S70 T5M (85k)
- Comets - R Bumper - RICA Tune - OBX Turboback - FMIC - EST Intake - HKS SSQV - IPD HD TCV - Koni FSDs - IPD Springs - OMP Strut Bar -
- AEM UEGO - Prosport BG & EGT - ABM Projectors - 6000k HID Lows & Fogs - LED Sidemarkers - Custom XC Grille - R Panels - 2 Baby Seats -
14.2 @ 101.4mph (Fall '08)
0
  • (2 Pages)
  • 1
  • 2
