Pcv Or Timing Belt Replacement Which is more difficult???
Posted 29 June 2009 - 11:20 AM
1995 850 GLT (normally aspirated)
Posted 29 June 2009 - 12:02 PM
Posted 29 June 2009 - 03:30 PM
Posted 30 June 2009 - 08:33 AM
Modus, on 29 June 2009 - 11:05 PM, said:
this is important, and do it very fluidly. dont "turn, let sit, turn, let sit" etc, just turn it consistently and very very slowly
98 C70 HPT M
Posted 30 June 2009 - 02:59 PM
Posted 30 June 2009 - 04:10 PM
OH and make sure you get all the gasket off the water pump if you do the water pump.. nothing is worse than having a leak and doing it over again
Posted 30 June 2009 - 05:46 PM
For PCV job, impact wrench is not needed and just take your time to unscrew all the screws. Then everything should be fine.
Ching-Ho Cheng
2005 530i, PPP, CWP, Nav, Xeon, Rear SunShade, Steptronics, Blue Light Door Sills, Wide Angle Driver Side Mirror, M5 iDrive Knob, White LED License Plate Light
Posted 30 June 2009 - 05:57 PM
Mike
Posted 30 June 2009 - 07:31 PM
bergmjs, on 30 June 2009 - 03:17 PM, said:
I saw posts in the forum regarding the TB replacement, the crankcase pulley would have to come off because there is a cover under that pulley. This makes the new belt going in with difficulty. That pulley is difficult to remove with a impact wrench !! Also, timing mark is very difficult to see on the cams.
Bay13 did not mention how to line up the timing mark before or after the new belt is on. Do we need to hand turn these cam gears to line up the mark or else ?
These are the concerns that I have such that I still don't have the gut to do the TB change. If I mess up the timing mark, engine will be damage !!
Ching-Ho Cheng
Posted 30 June 2009 - 09:50 PM
lcc014, on 30 June 2009 - 03:31 PM, said:
Hard to get belt off (so cut it). Not so hard to get belt back on.
[quote]
[\quote]
Paint them with white-out / correction fluid to see them better. Measure the distance between the marks before you start and write it down. You could use a cam-locking tool, but that'd be cheating.
[quote]
[\quote]
Line up marks before taking off the old belt.
Stage Zero
#14
Posted 01 July 2009 - 05:15 PM
sure the stakes are higher but if you take your time it's not that bad.
i swear i could do a TB in an hour now
$240 headache! hey the body and interior is mint though!
#15
Posted 01 July 2009 - 05:28 PM
How bad was it to do and how long did it take for you to do your headgasket?
#16
Posted 01 July 2009 - 07:02 PM
Ching-Ho Cheng
Bay13 described how you use a socket on the crank gear to turn the engine over until all the marks line up. The lines should line up with the notches on the timing belt cover. The only difficult part of getting the new belt on is getting past the retaining notch behind the serpentine crank pulley (Bay13 says how to do it) and then keeping the marks all lined up when you pull the belt over the cams.
Youre looking at this right?
http://volvospeed.co.../timingbelt.php
198k````````````````````180k
#17
Posted 01 July 2009 - 08:34 PM
1998 Volvo S70 T5M 170k
I have a new front wheel bearing for 99-00 S/V70s and 99-04 C70s - PM me
Want my Volans?
#18
Posted 01 July 2009 - 08:37 PM
DonutsDemise, on 01 July 2009 - 04:34 PM, said:
I have never done any TB job before, so this is very challenge to me. If I miss 1 or 2 teeth, then the whole engine will be toasted !!!
Ching-Ho Cheng
#19
Posted 01 July 2009 - 08:51 PM
lcc014, on 01 July 2009 - 04:37 PM, said:
Ching-Ho Cheng
just line up everything to the timing markings with the crank at top dead center, and for added measure i marked the cam sprockets and the timing belt with a sharpie and counted teeth between the markings. make sure everything is the same when you put it back together. the engine won't be toast if it's off by a tooth it just won't run well and you'll get a check engine light probably.
Want my Volans?
#20
Posted 01 July 2009 - 08:56 PM
Ching-Ho Cheng
Sign In
Register
Help
Start a new topic
Add Reply
MultiQuote
