Lowering My Rear End With Kw V2 its not low???
Posted 02 July 2009 - 05:30 AM
18t, 3 Inch Turboback, KW V2 Coilovers, FMIC, IPD Short Ram Intake, IPD Stage 1 Tune, MBC, QBM EndLinks,
6 Point Rollcage, Corbeau Seat/ Harness, Full Weight Reduction -600lbs, Custom Dash ( 12.9 at 110mph)(SOON- MOMO STEERING WHEEL)
Posted 02 July 2009 - 05:34 AM
kw coilovers are only adjustable in the front iirc ? would it be possible to use another front set in the rear ???
-planned final build- changed , will repost soon
Posted 02 July 2009 - 05:37 AM
Posted 02 July 2009 - 05:45 AM
coilovers for the front and springs for the rear i mean
Posted 02 July 2009 - 07:44 AM
Also how much weight did you lose, and are you running 16's or 17's lol.
Posted 02 July 2009 - 11:54 AM
Naughty33W, on 02 July 2009 - 01:45 AM, said:
If he's going for handling on the track, a better solution would be to find a shorter set of stiff springs, not softer springs so that the car sits lower. Minimizing body roll and decreasing suspension "response time" (think back to your system dynamics classes) is typically the goal here.
CR, which springs have you got in there now?
Posted 02 July 2009 - 03:14 PM
Chilled Man, on 02 July 2009 - 02:30 PM, said:
That will get you lower.
The tourings are a too soft though to get the most out of these springs and I think they may be why my wagon sits lower in the rear than I've seen on others cars with IPD springs.
Posted 02 July 2009 - 03:23 PM
Posted 02 July 2009 - 05:18 PM
RIP Joe Ng 02/29/56-08/18/05...
Posted 02 July 2009 - 06:06 PM
well the bottom spring seat i have screwed all the way DOWN, should it be up?... i lost about 600lbs, an i have 17" volans
Posted 02 July 2009 - 06:56 PM
cr854r, on 02 July 2009 - 11:06 AM, said:
At most, settling will give you another 1/4". Sounds like your weight reduction is causing the rear to sit higher. Either buy a shorter spring or cut a coil from the top of the KW spring. Also, since you are already at the bottom of the adjustment, removing the adjustable perch and securing the bottom of the spring in the factory cup may get you down slightly more.
1998 V70 T5
Chrome 19" Niche Rhine Wheels
Posted 02 July 2009 - 08:04 PM
Thats with my KWs adjusted all the way up.IPD is not lower
If you driving it, I drove it. If you got it, cause I sold it
#14
Posted 02 July 2009 - 08:08 PM
#15
Posted 02 July 2009 - 08:11 PM
there is no way the weight reduction causes the rake.
make sure you installed the springs properly, make sure you have KW springs
Like John mentioned, you can remove the lower adjustable perch completely and use the stock bolt down to hold the springs in....that'll get you pretty low.
and IPD springs are not lower than KW....not even the new ones....i've had them in my car.
#17
Posted 02 July 2009 - 08:16 PM
Che, on 03 July 2009 - 01:42 AM, said:
removing all the seats, your gas tank, and every piece of trim, the dash, and the headliner, and maybe some bolts holding stuff together could get you 600lbs lighter. i wouldn't put it past anyone on here.
but 600lbs lighter is usually going to be coming off from the front of the car (most of it)....in the rear, all I can think of removing in a sedan is the rear seat and the spare tire that has any significant weight.
#18
Posted 02 July 2009 - 08:20 PM
The cage will add ~110 pounds I guess which will make the rear come down a bit.
You could cut one coil from the top of the spring like I did,
Everything at the lowest setting. Empty trunk, no lower seat in the rear.
#19
Posted 02 July 2009 - 08:33 PM
Sign In
Register
Help
MultiQuote
