Volvospeed Forums: Custom Exhausts - What To Do - Volvospeed Forums
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Custom Exhausts - What To Do Rate Topic: -----
#1 User is offline   leroystew Icon
  • Level 1 Member
  • Icon
  • View gallery
  • Group: Lifetime Supporter
Posted 03 July 2009 - 05:12 PM
So on my S70 T5, I've got an EST DP and the IPD cat back stainless steel exhaust. I recently bought a Magnaflow muffler with tip for the car. Here is the problem, the IPD exhaust pipes are still in fantastic shape, but I want to remove the first muffler and just run the muffler at the end of the car. I checked a few shops around where I live, and no one does stainless steel pipe work (WTF).
For everyone else on here who is getting custom exhaust work done, are you using stainless steel pipes or just regular steel pipe? Since the IPD pipe is still in good shape I really hate to lose the stainless pipe. I guess I could just order a piece of stainless pipe long enough to fill the hole of the one muffler, but then need to find a shop that can work on stainless steel pipe.
What is everyone else doing?
Lee
1998 S70 T5M; 99.5k miles; IPD Stage I ECU; 16T with extra large angled flange; EST RIP; R manifold; EST 3" DP; IPD 2.5" exhaust with TME muffler; MSD coil; EST air intake; balanced crank with LGSpeed rods; 3 angle valve job; Stylin Motors silicone hoses; IPD HD TCV; VIVA CBV; Koni struts; IPD springs/IPD sway bars; 302mm rotors; SS brake lines; SPEC III clutch, 17" IPD Pegs; Sconeman short shifter; TurboSmart Eboost2;
----14.08 @ 105.89 mph
#2 User is offline   AaronD81 Icon
  • Level 2 Member
  • Icon
Posted 03 July 2009 - 05:36 PM
I also had trouble finding a muffler place to weld stainless, try a welding shop instead. What you want done is really easy for a pro welder, so the place doesn't need to have anything to do with cars.
98 V70 T5
PM me if you're local need codes checked, or service light on a 98 reset.
#3 User is offline   TIPSP Icon
  • Level 1 Member
  • Group: Members
  • Interests:Stuff
Posted 04 July 2009 - 02:50 AM
Where are you located?
91 745T: Modified.
82 244T: Bone Stock.
07 V70R: Bone Stock.
97 BMW 540i: Modified.
99 Camaro Z28: Rytek Projektz.
79 Pontiac TransAm: Some Mod.
http://www.volvolution.com/forum/
0
#4 User is online   sconeman Icon
  • Level 3 Member
  • Icon
  • Group: Vendor
  • Interests:family, cooking, making stuff, cars
Posted 04 July 2009 - 02:58 AM
I bet there's someone keep asking around. I found a shop that does stainless and works on Airplaines :huh: so you never know.
another option= find someone who can bend it and flare it for you then put it together with clamps.
850 and x70 SHORT SHIFT KITS available FOR SALE now!
0
#5 User is offline   TainterRacing Icon
  • Level 1 Member
  • View gallery
  • Group: Members
Posted 04 July 2009 - 11:11 AM
Might want to try some hot rod shops.
1999 V70 GLT all stock for now. Front IPD HD sway bar links Rear HD Springs and HD Bilstein
1996 850 Turbo Wagon Brothers car 215k+ Ported... Cly Head, Turbo both sides, manifolds port matched
larger Turbo intake pipe cone filter 2.5in Cat Back (Edlebrock RPM Muffler)
0
#6 User is offline   Mesoam Icon
  • Mr. Sarcastic Jackass
  • Icon
  • View blog
  • Group: Supporting Member
Posted 04 July 2009 - 01:33 PM
why are you replacing the TME muffler, its a very nice piece
96 854 R, CLICK ME
The Jeep
#7 User is offline   leroystew Icon
  • Level 1 Member
  • Icon
  • View gallery
Posted 04 July 2009 - 02:05 PM
I'm located in NW Indiana.
I'm impressed with the sound of the TME muffler at the end of the pipe so far (the EST DP really improved the sound 1000% compared to the stock POS), however, I want to get rid of the suitcase muffler in the middle of pipe closer to the CAT. Hoping the sound will get even better.
Alternatively, I also want to hear how the car sounds with the Magnaflow muffler bolted in place, compare the sound of the 2 mufflers, and keep the one I like best.
Lee
#8 User is offline   --Aaron-- Icon
  • MJ Is My Hero!
  • Icon
  • Gender:Not Telling
  • Interests:post whoring
Posted 04 July 2009 - 06:20 PM
I have a 3 in. DP > 3 in. high flow cat > IPD/TME catback....minus the resonator (first muffler) which I had straight piped and it sounds effing mean. You will get a little drone cruising on the highway but the sound is incredible. It sounds so pissed off when you romp on the gas. :lol:
1998 Volvo S70 GLT - 14xK - lots of fun stuff, half assed repaint.....DRIVEN DAILY!!
0
#9 User is offline   Naughty33W Icon
  • Level 2 Member
  • View gallery
  • Group: Members
  • Interests:workin on my S60 and building a rally car
Posted 04 July 2009 - 07:11 PM
hope this helps - http://www.thebluebo...yword=&qt=&pg=6
2003 Volvo S60 2.4T - custom intake , catless straightpipe exhaust , everything behind the front seats gutted , more mods to come
-planned final build- changed , will repost soon
0
#10 User is offline   leroystew Icon
  • Level 1 Member
  • Icon
  • View gallery
Posted 05 July 2009 - 10:17 PM
I was looking at the Borla exhaust systems and parts, and I guess I could buy a piece of stainless straight pipe and the band clamps and do it that way. My mechanic friend has a MIG welder for the welding needs, so perhaps its as easy as that. I'm really antsy to get that suitcase muffler off and hear the car.
Lee
#11 User is offline   Naughty33W Icon
  • Level 2 Member
  • View gallery
  • Group: Members
Posted 05 July 2009 - 10:39 PM
you could always ditch the cat , it will make for a really aggressive sound , use clamps after you remove it tho , that way you can bolt the cat back into place for emmisions testing :)
0
#12 User is offline   dublin14 Icon
  • Level 2 Member
  • View gallery
  • Group: Members
  • Interests:Racing Nasa HPDE
Posted 06 July 2009 - 12:03 PM
Find a fab shop. If there of any use will have a someone that can weld SS!
98 S70 T5SE 5-speed M56H-with short shifter /110k / Rica Tune / 18T Turbo with Cherry Turbos HD actuator / ES filter / ES Coil-kit / 3" DP & Magnaflow Racecat / Eurosport Catback / S60R Manifold / UR Pulley / IPD 14lb HD CBV spring / LSP MBC 18psi / Samco hoses / Stylin Motors Vac Lines / IPD Upper mount/ Eurosport CarbonFiber strut brace / Carbon Fiber Engine Cover /Autometer Turbo Gauge/ AEM AFR gauge/ QBM Trim Rings/ TME Springs / Pegasus Rims/ Dunlop Direzza DZ101/ 6000K HIDS / R Bumper / Clear Corners / Euro Side Markers / XC70 Grill/Piaa H1 fogs / Piaa Plate Leds/ Porsche 993 TT BBK & X drilled/slotted rears, Hawk HPS pads, IPD SS hoses / Precision FMIC. NA TB going on soon!
0
#13 User is offline   leroystew Icon
  • Level 1 Member
  • Icon
  • View gallery
Posted 06 July 2009 - 01:45 PM
My mechanic friend who rebuilt my motor should be able to weld the SS for me. He did welding on the EST DP for the AFR bung and the airpump bung, and based on what I saw this past Saturday, his MIG welder should be able to do the SS welding.
I love the sound of the TME muffler now, can't wait to hear it with out the suitcase. And then I have the Magnaflow muffler also to hear. The EST DP came with a race cat, and I think I am going leave the CAT in place since Indiana requires emission testing and how much am I really going to gain by removing the CAT anyways. Don't feel like messing with clamping it on and off.
Lee
#14 User is offline   NGB Icon
  • Level 5 Member
  • Icon
  • View gallery
  • Group: Vendor
Posted 06 July 2009 - 01:51 PM
Simply removing the cat isn't going to make the car sound that much better, all the while spewing more pollution into the air :)
You can certainly MIG stainless (make sure he's using stainless wire,) it just won't be as pretty as if someone TIG'd it for you. A lot of truck body places can weld stainless, might look into that.
Nick | 1998 S70 T5 SE | In the works: Compustar
Parting: 1998 V70R, 1998 V70R, 1999 V70R, 2000 S70 GLT SE
Poorboy's Sale
0
#15 User is offline   leroystew Icon
  • Level 1 Member
  • Icon
  • View gallery
Posted 06 July 2009 - 02:16 PM
I'm not sure I really need much welding for what I want to do. If I remove the suitcase muffler, and put a piece of SS pipe in its place with 2 band clamps I would think that would do the trick. As for the tipped muffler, if I replace the TME with the Magnaflow, the Magnaflow has a 3" inlet so I need a transition piece from 2.5" to 3" to fit the Magnaflow muffler.
Lee
#16 User is offline   Naughty33W Icon
  • Level 2 Member
  • View gallery
  • Group: Members
Posted 06 July 2009 - 06:49 PM
autozone for <$5 ... or if you want a nicer look and to have the exhaust resonate a bit better you can get a 2.5" pipe flared to 3"
i liked the sound difference after removing my cat , not to mention faster spool time , as for pollution , thats the least of my concerns , if its even on the list at all ahhahaha ;)
0
#17 User is offline   DonutsDemise Icon
  • Level 4 Member
  • Icon
  • View gallery
Posted 06 July 2009 - 07:42 PM
:rolleyes:
did you add 2 hp by doing that? you can get the same performance results by taking the spare tire out of your trunk, probably better results because there would be less weight behind your rear axle
just get a 3 inch high flow cat
Jake
1998 Volvo S70 T5M 170k
I have a new front wheel bearing for 99-00 S/V70s and 99-04 C70s - PM me
Want my Volans?
0
#18 User is offline   Naughty33W Icon
  • Level 2 Member
  • View gallery
  • Group: Members
Posted 06 July 2009 - 08:01 PM
View PostDonutsDemise, on 06 July 2009 - 11:42 AM, said:
:rolleyes:
hahaha , changed my hp and torque curve too
the cat is 30-40lbs , so that right there is equal to the weight of the spare tire , and then you have a less restrictive exhaust , and therefor faster spool times ect ect ect
but alot of it is preference , not everyone want the added noise ... and pollution ... ;)
race cats are worth the money if you have to worry about emmisions , i dont , and sense i dont worry about noise i run a straightpipe ... but we're getting off topic and starting to threadjack hahahahaha
0
#19 User is offline   EricF Icon
  • tbricks spy
  • Icon
  • Group: OH Moderator
  • Crew:LBC
Posted 06 July 2009 - 08:18 PM
Cat is not 30-40 pounds... It wasn't the last time you mentioned that and still isn't ;)
For the original poster, MIGing stainless is just fine. I do it with a crappy flux core welder and the welds are very durable... Most flanges are sold in stainless, most mandrel bends I work with are mild steel, I just welded the downpipe for my 850 the other day, welded some mild steel pipe to the rest of the SS downpipe, then on the other side welded a stainless flange to it. It works just fine...
1984 244 GLT - blue rat rod (cardomain)
1995 850 turbo - "She may not look like much, but she's got it where it counts kid"
"Pay no attention to what critics say. No statue has ever been put up to a critic." -Jean Sibelius
0
Page 1 of 1
