Air Intake
Posted 03 July 2009 - 06:17 PM
highflow in stock location - http://www.eurosport..._Code=VL-850-en
personally i would make my own , you can get just as good a setup or better by fabricating it yourself
-planned final build- changed , will repost soon
Posted 03 July 2009 - 06:19 PM
Siscos850Turbo, on 03 July 2009 - 07:11 PM, said:
if you want performance, just get a K&N panel filter. The stock air box is a very good design, pulls cold air from the front of the car. If you want the turbo whistle sound, you can get a kit from IPD or EST. They are open air cone filters with heatshields, no performance gain, just sound.
IPD Stage 2 manual, 16T big angle, white Injectors, FMIC, R manifold, OBX 3" angled downpipe, 3" exhaust, magnaflow hi-flow cat, 2.75" turbo inlet tube, custom 3" CAI, T3 10 lbs. wastegate, Kingsborne 8.5mm wires, M56H swap w/ R clutch, Koni Yellow struts/shocks, IPD springs, IPD front/rear sway bars, HD end-links, OBX v2 strut bar, 17" ADR RS Limited Wheels- 17 lbs, Stainless brake lines,
Installing Soon: Coolingmist Water Injection, Greddy Profec B Spec 2 EBC,
Posted 03 July 2009 - 06:36 PM
T5Manual850, on 03 July 2009 - 10:19 AM, said:
i have a pipe that runs to the stock location with a highflow cone on it (i like the sound
(thepvc or flex being the cold air draw)
Posted 03 July 2009 - 10:22 PM
1/4mile 14.013 @ 97.96mph
Posted 04 July 2009 - 02:53 AM
Siscos850Turbo, on 03 July 2009 - 03:21 PM, said:
Yes, Get an SRT4 BOV plate. Mounts inbetween the CBV and the turbo.
Block it of and get a really one. Or just get a cone filter and you will be able to hear it. Custom CAI is the way to do it. ~$50 for a good setup.
82 244T: Bone Stock.
07 V70R: Bone Stock.
97 BMW 540i: Modified.
99 Camaro Z28: Rytek Projektz.
79 Pontiac TransAm: Some Mod.
http://www.volvolution.com/forum/
Posted 04 July 2009 - 03:01 AM
uhm it's a little more than $50 but yeah that's the way to go.
Posted 04 July 2009 - 03:08 AM
sconeman, on 03 July 2009 - 08:01 PM, said:
All depends on which filter you buy and how many parts you use....
I did mine on my 745T for $50. Spectre filter ($25) and two 3" pipes from Spectre ($24). a clamp and some heater hose for a bumper setup. Free heat shield (made form crap in the garage).
Cheap, but works great!
Here is a recent photo:
Posted 04 July 2009 - 08:36 PM
true true. mine kept adding up more than expected. Your's is a little shorter too looks good: ) custom is best. To the OP, make sure you remove that restrictive pipe after the maf.
Posted 04 July 2009 - 11:39 PM
sconeman, on 04 July 2009 - 01:36 PM, said:
Yours looks nice, where is the filter? it looks like it is in a box..... or is out side the engine bay?
OP: this is a good site for silicone and stuff.... http://www.siliconeintakes.com/
pipes can be found at any autozone or pepboys...
#14
Posted 05 July 2009 - 01:33 AM
the filter is in a bucket LOL with the bottom cut out. I was trying to keep large amounts of water from hitting it through the bumper grill at highway speeds.
#15
Posted 06 July 2009 - 05:23 PM
1995 volvo 854 T5-a few mods. 200,000+ miles and still reamin'
i love it more everyday :)
#16
Posted 07 July 2009 - 01:50 PM
Does anyone make a kit that replaces the tubing between the MAF sensor the turbo to be used with a cone filter?
Thanks.
#17
Posted 07 July 2009 - 02:07 PM
Thanks.
no you gotta make it yourself or you could try sending a pm to "lookforjoe" he may build one for you.
#18
Fast Reply
Toggle shoutbox Shoutbox
Sign In
Register
Help
Add Reply
MultiQuote
