Bsr Top Speed Reduction
Posted 09 July 2009 - 02:02 AM
Thought i'd pick your brains on a problem that Ive been facing for many months now. I own a 2009 Volvo S80 2.5t and a 2007 Focus ST.
On the Focus ST i own 3 Stage 1 tunes - BSR/Bluefin/Dreamscience. All these tunes produce pretty much the same performance in rolling acceleration comparisons and feel significantly faster than the stock tune. The problem lies with the BSR tune, which happens to be my favourite in terms of delivery, as my car can only achieve a top speed of 225km/h. On the stock map i have achieved 245km/h and on Dreamscience and Bluefin I have done 250km/h+. (all this measured via GPS)
The strange thing about the whole issue is that i have done some timed runs between BSR and the stock map and the BSR is definitely faster through the gears and up to 225kmh. The problem is that it stops accelerating completely thereafter and can go no faster no matter how much road i have. It has been brought to my attention that some people in Sweden are also facing the same speed limiter on BSR tunes up to Stage 3. (Focus ST has no built in electronic speed cuts)
I have contacted BSR but they refuse to get one of their technicians to speak to me on the phone and getting to them via the local dealer and also the online support chat has been going on for 6 months with no solution in sight despite them recognizing that it is indeed a problem on many cars. I have read posts on Saab forums about reduced top speeds after BSR tuning as well.
Does anybody here have a technical explanation that can perhaps give me some direction before i give up and demand a refund?
Cheers guys.
Posted 09 July 2009 - 02:17 AM
that just sounds unsafe and a good way to get a ticket.
Posted 09 July 2009 - 02:25 AM
Because maybe he lives in a foreign country where there are no speed limits on certain highways...
1974 Porsche 914-4 - Tastefully modded
2004 Volvo V70 2.5T Titanium Edition18" Pegs/BFG KDW2's
Posted 09 July 2009 - 02:32 AM
1337-850, on 08 July 2009 - 10:25 PM, said:
he lives in Vermont.
but, it doesn't really matter why he wants to go that fast...
yes, its a bad idea, and a great way to end up in jail,
but the fact of the matter is that he's getting screwed with a lowered top speed.
Posted 09 July 2009 - 03:34 AM
I live in Singapore and only drive at that speed on the Malaysian highways and also on the Sepang F1 race track.
The reason iam concerned with this issue is not so much because I have to drive above 225km/h, but rather that it could be an indication of a fault with the tune, perhaps elevated temps that are causing the ECU to back off the power. These issues could potentially result in a damaged turbo or cracked seals so id like to be assured of the reliability of a tune before i run it long term. Here in Singapore a focus ST costs USD$70k and the S80 costs USD$110k and we only have the right to own it for 10 years before it has to be scrapped. I would like assurance from BSR that these tunes are safe to use before i continue running my ST on it and perhaps remap the S80 as well.
Cheers
Posted 09 July 2009 - 04:47 AM
Bsr creates really good base maps, however they don't do custom mapping here in the states, afaik.
Get some gauges, Afr, egt, and boost gauge
Posted 09 July 2009 - 05:04 AM
'00 S70 SE (slow/sold)
Posted 09 July 2009 - 06:05 AM
Iam sure this is the same BSR map that everyone uses around the world. I have it updated constantly via the PPC connection link on their server...
I do agree though that the tune feels very good. It is the best that i have tried and I would be happy running it long term if not for the fear of runninng a faulty map. Are there similar instances of problems on any of the volvos here running the BSR stage 1 maps?
Posted 09 July 2009 - 07:11 AM
Just one possible explanation...
98 C70 HPT M
Posted 09 July 2009 - 08:12 AM
I think your explanation makes sense. We did a few rolling runs and noticed that after 200kmh, the stock car actually started to close in on the Stage 1 car. I certainly did not expect a big company like BSR to create such a bad tune if this was indeed the case.
Thanks for you input. I will probably ask for a refund if they can't sort it out.
Posted 09 July 2009 - 12:59 PM
2002 s60 t5
#14
#15
Posted 09 July 2009 - 03:05 PM
°°KOLBAS°°, on 09 July 2009 - 08:59 PM, said:
Thanks for the warm welcome mate. Ill certainly check on the speed limiter issue with BSR. They did say before that there was no limiter on the map though, but i guess ill check again just to be sure. HKS might be an option though iam not sure it will agree with our sort of ECU. There is a HKS Technical Factory here in Singapore and GTR's, Evo's and STI's are so common you see 1 every hour!
#16
Posted 09 July 2009 - 03:20 PM
IPD Stage 2 MT, m56H, 16T-7cm2, R mani, 350cc whites, FMIC, Meth/WI, Forge BOV, Greddy EBC, 3" TBE, CAI, Koni/IPD susp., IPD sways, OBX v2 strut bar, 17" ADR RS, SS brake lines
#17
Posted 09 July 2009 - 10:07 PM
T5Manual850, on 10 July 2009 - 02:20 AM, said:
No worries Trip, i'm addicted to VS like Justin is too dropping his ballsacks, you'll learn later, lol, Definitely, its says they can increase the speed on some models by upping the RPM cutout but they are actually updating their maps to remove the limiter altogether on some models and it's actually already available on some models.
2002 s60 t5
#18
Posted 10 July 2009 - 12:44 AM
BSR has responded saying that they will look to sort it out when they get a chance and its been 6 months with them refusing to give me a timeline... not good.
#19
Posted 10 July 2009 - 01:53 AM
2002 s60 t5
#20
Posted 10 July 2009 - 02:57 AM
°°KOLBAS°°, on 10 July 2009 - 09:53 AM, said:
I dont have the ECU spacer. Purchased a ProAlloy Intercooler sometime ago and it has not solved this problem...
Sign In
Register
Help
MultiQuote
