1995 855 Turbo-M
68 replies to this topic
#1 prasamin
    Bipedal Magnaflux
  • 16,149 posts
Posted 21 August 2009 - 12:28 PM
PRICE LOWERED TO $16,000, AND I AM ALSO OPEN TO WORKING OUT A TRADE DEAL FOR AN 04 OR NEWER S60R AUTOMATIC WITH LOW MILES. I WILL ALSO ENTERTAIN TRADE OFFERS FOR OTHER CARS, NOT NECESSARILY VOLVOS ONLY.
Um. If I can get $17,000 for it, then it's yours. You get all the crap laying in the garage too...some HID's and other stuff...nothing major left.
Car is a beast...runs PERFECTLY. There are no leaks or noises or anything wrong at all. It comes with Turbo Tuner ready for you to tune, along with all the other ridiculous mods I've done. The body work alone is worth the price of the car, and maybe even slightly more.
You know what you're getting. The only bad about it is that I haven't got the speedometer working...should be a simple wiring fix...or you can swap in my original 1995 harness and plug it into the speed sensor and call it a day.
The car has 160k miles on it, but the engine was rebuilt completely about 2.5 years ago. The engine has about 3k miles on it...it hasn't been driven much. M56H shifts like butter.....all OEM Volvo replacement parts....not much old stuff left on it....sensors sans knocks are brand new.
I'll post more details in the next 24 hours. The car is located in Dallas, TX, and it garaged. I wouldn't hesitate driving it cross country. It won't give you any issues...unless you're a retard.
Engine: 1995 HPT 2.3L I-5 turbo fully rebuilt with forged china rods, wiseco os1 pistons with coated skirts and valve reliefs, arp rod bolts, arp head stud kit....custom oil galley windows in block, rebuilt head with slight porting and polishing, green 465cc Volvo injectors...all new sensors except the knocks...all Volvo sensors for the most part....new RMS, etc complete rebuild...new oil pump, seals, water pump, t-belt, serp etc. Garrett GT35R turbo with 4" anti-surge inlet and Tial external wastegate. Racelab Fabrications Downpipe, custom Racelab oil and water lines, custom intake with proper piping, custom RIP kit. 3" A-tech clone intercooler, Forge dual piston bov....S60R manifold ceramic coated and ported and polished. custom bored intake manifold to mate the 3" NA throttle body to....powdered black....the valve cover for the head is painted black....Champion RC7YC coppers properly gapped, with Kingsborne wires...all new rotor, cap, dist, etc...
Transmission: 1995 M56H...shifts as smooth as butter...new bearings, Quaife LSD installed....basically a refurbished M56H with LSD and speed sensor....Euro Spec 850R clutch kit...all new bolts for flywheel and clutch....carries OEM Volvo gearbox oil
Interior: Custom unisuede perforated seat inserts with unisuede headliner and matching trim from a 2000 V70R. Extremely clean interior...new 850 OEM floor mats...no stains....just the normal slight cracking on the door handle trim, and of course the rattle associated with these 850's....Euro 850 Yazaki speedo with QBM trim rings and red LED lighting.
Gauges and monitoring: 3 pod a-pillar with Autometer Cobalt D-pic, electronic vac/boost with MAP, and wideband. Greddy Spec B II electronic boost controller, Greddy turbo timer that needs rewiring i think...not sure.
ICE: 7" in dash DVD/mp3/XM Jensen unit works beautifully....11" overhead XOvision monitor with separate built in DVD player and IR headphone capability...front can watch something separately than the rear, or everyone can enjoy the same thing from the front player or overhead...many options, and still an input left for a gaming console or something. front doors have infinity Kappa 5.25" and the rest are stock...the 7" in dash has a toggle switch for the DVD player also...all wiring is Knuconceptz...there is a distribution thing under the panels in the trunk...
Body: customized completely....red 601 paint which is great condition, but if you look closely, you'll find some chips and peels....prep wasn't as good as I wanted, but it looks great and I'm really picky. shaved doors with poppers on all 4...trunk still has key hole in case of emergency. custom welded "flat" hood....Erebuni side skirts and rear custom molded and fabbed. Widened fenders. custom V70R front bumper to fit the 850...fits like stock with OEM grilles and fogs....I have the 850 projectors in there right now. HOVA black jewels and corners with custom E55 hella projector retrofit ala Mike. rear 855 wing with brake light...painted black. black painted roof rails with cross bars. black painted trim handle on the trunk...i want to finish off the black accents, but I don't have the time now....custom fender cutouts with mesh grill...non functional, but cool....SAM sidemarkers not wired, but can be easily done
Suspension: KW V2 coilovers with QBM endlinks, IPD front and rear sways and delrin bushings....newer control arms, spring seats, bearings. OMP red strut brace....good design
Brakes: StopTech front brakes with SS lines....I have OEM brakes in the rear
Wheels: OEM Volvo BBS Nebula 18x8 wheels in great shape with no bends or repairs...very minimal rash if at all....fronts are spaced out 10mm and rears are spaced out 25mm..fronts have wheel stud kit. Current tires are Ceat Tornado 225/40/18...have over 50% tread left all around.
Exhaust: Racelab Fabrications downpipe 3", Magnaflow race cat, and custom dual exhaust with Magnaflow Race Series mufflers at the end...sounds MEAN and runs great although the right gets less fume than the left....design fault obviously.
ECU: Turbo Tuner....comes with stock manual map and "performance" manual map...both run great....you have a USB port under the dash on the passenger side to connect your laptop to and tune....pretty darn easy
Other: Brand new evap core, compressor, accumulator, and A/C sensors....A/C blows cold thanks to Aaron at Racelab Fabrications....20% tint all around...17" Mille miglia spare wheel and tire in the trunk...clears the BBK IIRC...but if not the spacers are there anyway....will throw in a brand new low profile aluminum race jack by US General
The Bad: speedo doesn't work....you can swap back my original 95 harness and plug it into the speed sensor, or you can wire something up to get it going again...no big deal...my 95 harness is already pinned for manual swap...so just swap it in if you desire. rattles because of the suspension, small paint chips here and there...front bumper can use a repaint
Mechanically the car is great....drive it anywhere.
I'm sure I'm forgetting something, but you can look at my project thread for alot of what this car went through...believe me, $17000 is a steal....shit you can part it out and make money on it...i don't care lol.
I've lowered the asking price to $16,000.
I will entertain very reasonable offers! I need the car gone by July.
Edited by prasamin, 22 June 2010 - 08:07 AM.
#2 TFIVEM
  • 1,924 posts
  • Interests:Design, R&D
Posted 21 August 2009 - 01:04 PM
Whats next pras? and whats this car looking like now and days?
Posted Image.
/// Sam
98 T5-MR Estate: not stock, The PLAY
04 V70 2.5T TE: VST CF lip, R Bumper, Medusas The DD
#3 Getspooled
  • 126 posts
  • Interests:Fishing, Turbo Volvos
Posted 21 August 2009 - 04:40 PM
Yeah, pics please!
1997 850 GLT 16T 'Olive'
2003 V70 NA
1994 854 Turbo - Sold
#4 Distort
  • 438 posts
Posted 21 August 2009 - 07:39 PM
This
dumpt 1990 765
#5 flyfishing3
    100% Vegan
  • 12,437 posts
Posted 21 August 2009 - 08:02 PM
that car deserves to be on the road, not sitting in a garage.
GL with the sale. somebody is going to get a great car.
Double R garage
i was so drunk last night, i thought the toothpaste was astronaut food.
#6 prasamin
    Bipedal Magnaflux
  • 16,149 posts
Posted 22 August 2009 - 11:44 AM
edited to include mods
#7 turbor850
    i am the new pegs
  • 4,188 posts
Posted 22 August 2009 - 01:36 PM
A lot of work, reminds me of my old one. Whats the whp that thing is putting down ?
FIRST TO PUT 20G ON AN 850R
#8 BtownVolvo
    Gay For Beiber
  • 7,999 posts
Posted 22 August 2009 - 02:07 PM
What. The. Fuck. Pras?
Reid | 1998 V70 T5
#9 prasamin
    Bipedal Magnaflux
  • 16,149 posts
Posted 23 August 2009 - 06:29 AM
I haven't tuned and dyno, so I really couldn't tell you. And it would be unfair to estimate. I can tell you that with the performance tune from TT, it RIPS...AFR's are good up to about 18psi of boost...that's as far as I've gone....and there is definitely still room for boost because the AFR's were running a little rich up there.
#10 SaffC70
  • 195 posts
Posted 24 August 2009 - 05:59 PM
1....why the hell are you selling it?? and 2...pics please
i am now volvoless
View PostTRACStar, on 24 September 2010 - 11:28 PM, said:
Question: Whats wrong with this pic?
Answer: Your doing 65 MPH and taking a picture of the steering wheel alignment.
#11 dublin14
  • 2,518 posts
  • Interests:Track events in NASA/ProAutoSports and dumping money into old Vulva. And one of the VS mods on here put that comment above. Dam kids these days lol
Posted 25 August 2009 - 11:59 AM
pics?
Attached Image: engine and shop pics 074.JPG
#12 Boost_Junky
  • 2,008 posts
  • Interests:shiny objects and things that make noise
Posted 25 August 2009 - 02:31 PM
nOObz
Project Pras
95' 850 T5,Eibach Koni FSD,Strut Bar,Adj. Endlinks,ST@17psi,FMIC,
3" DP,2.5" Cust. Cat Back Sys,EST Intake,8k HID,Silcone Everything
04' S2K, Coil Overs, HKS Exhaust, Injen Inkake, Cust. 3 Piece Wheels
98' V70 bone stock
#13 HayaCruza
  • 138 posts
Posted 26 August 2009 - 02:22 AM
Okay I will help.
Pras, I am guessing you kept your front bumper and hood....
Does the front bumper still have the special touch up paint?
#14 prasamin
    Bipedal Magnaflux
  • 16,149 posts
Posted 27 August 2009 - 08:08 AM
Sure does. I am really busy between 6AM and 11PM daily here in India, so I don't really have time right now to sort through pics and post, but as soon as I do, I will!
The kiss was touched up by my dad, and it needed to be repainted. I have neither the time nor money to fix anything on the car now, and I really need the money for my years of dental school. The car sits in a garage 10 months out of the year, and the next 3 years it's not going to be driven at all. It needs to be driven, and it needs to be tuned and completed. I want to see someone with the time and enthusiasm to finish it and make it what it should be. There is absolutely nothing wrong with the car. It's just my priorities have changed. Make a very reasonable offer, but remember, you can make your money back, and alot more if you pay asking price. And for that reason, it's going to be really difficult to negotiate with me. Guys, this is not just a built motor, fast car. The is completely customized from ground up, front to rear, inside out.
#15 MattS70T5
  • 147 posts
Posted 27 August 2009 - 12:22 PM
Damn those nebs are hot! If it was RHD pras I'd ask you to put her on a ship over here :P
'96 850R M59
#16 Austin H
  • 2,346 posts
Posted 27 August 2009 - 01:02 PM
Wish I could afford it.  If you finance it for me consider it sold   :lol:
I'll give you $150 a month for 10 years.  You'll make more than 15k.
View Postprasamin, on 08 June 2009 - 03:31 PM, said:
mine's at 155k, and will probably never hit 200k....although mine's completely rebuilt.
I was a little concearned about this at first though.  I thought you meant there's something wrong and it can't hit 200k then after reading your posts I realized you just can't drive it that much.
#17 Pops Racer
    Old Man Crew Leader
  • 4,687 posts
  • Interests:Playing my violin around fires
Posted 27 August 2009 - 01:14 PM
OOOOH. That car gives chubby. It's a beut.
"Property is the fruit of labor...property is desirable...is a positive good in the world. That some should be rich shows that others may become rich, and hence is just encouragement to industry and enterprise. Let not him who is houseless pull down the house of another; but let him labor diligently and build one for himself, thus by example assuring that his own shall be safe from violence when built." - Abe Lincoln
#18 Black Betty
  • 6,899 posts
Posted 27 August 2009 - 01:44 PM
Since I've always oogled over this car
#19 SeeSevenTea
  • 94 posts
Posted 27 August 2009 - 02:40 PM
How the hell do you open it?
Intake--System--Flashed
#20 flyfishing3
    100% Vegan
  • 12,437 posts
Posted 27 August 2009 - 02:43 PM
quoted from above.
its a button on the remote you hit to release door.
Double R garage
IPD
