Na Cams And Throttle Body For Turbos
Posted 25 August 2009 - 02:35 PM
I've been seriously contemplating switching my T5 exhaust side cam for the NA cam, and for years thought about getting a bigger throttle body. Are the benefits worth it, or is it only worth it for a really built motor like the Peril or others putting out over 450hp?
Posted 25 August 2009 - 03:43 PM
For the TB, it is 68mm instead of the 58mm turbo one. I used the larger NA one so it wouldn't be a bottle neck with the 2.5" turbo outlet and 2.5" IC piping.
Posted 25 August 2009 - 04:50 PM
Posted 25 August 2009 - 04:52 PM
Posted 25 August 2009 - 05:05 PM
leroystew, on 25 August 2009 - 04:52 PM, said:
this topic has been beaten to death, no one has a real definite solid answers as to how much gain and what exact gain you get out of cams, or whether or not to use one or both cams.
We are waiting for a before and after dyno with tune tweaking specific to the cams, i will be doing this when my motor is complete but it wont be for a few months.
Posted 25 August 2009 - 05:11 PM
Posted 26 August 2009 - 04:06 AM
the n/a cams give you kill low end and give a little top end
someone correct me if i have heard wrong
Posted 26 August 2009 - 04:14 PM
Posted 26 August 2009 - 04:41 PM
Posted 27 August 2009 - 01:18 PM
So are the throttle bodies different between a manual and auto tranny (assuming so since they are specified as manual or auto)? And I'm assuming I will need an IC transition hose to mount the IC to the new, bigger throttle body. Would I need a 2.25" to 2.5" transition hose piece.
johnloves850's, on 27 August 2009 - 04:31 AM, said:
Posted 28 August 2009 - 02:49 AM
leroystew, on 27 August 2009 - 01:18 PM, said:
So are the throttle bodies different between a manual and auto tranny? And I'm assuming I will need an IC transition hose to mount the IC to the new, bigger throttle body. Would I need a 2.25" to 2.5" transition hose piece.
Posted 28 August 2009 - 03:42 AM
Also, the intake needs to be bored out to utilize the bigger throttle body, unless you want to make a spacer.
#14
Posted 02 September 2009 - 04:33 AM
So are the throttle bodies different between a manual and auto tranny (assuming so since they are specified as manual or auto)? And I'm assuming I will need an intercooler transition hose to mount the intercooler to the new, bigger throttle body. Would I need a 2.25" to 2.5" transition hose piece.
no difference between auto and manual
you'll need a bigger hose, or some kind of modded coupler to incorporate the tps
there was a group buy a while ago, but idk what became of that
60 bucks iirc, not too shabby for saving yourself some man hours trying to make one haha
#15
Posted 02 September 2009 - 01:32 PM
Let me know how the cams go though, I have been sitting on a set of NA cams for a while now.
1997 850 R, 1998 S70 GLT, 1998 S70 NA (parts car), 1999 S70 NA, 1998 V70 NA, 1969 MGC.
#16
Posted 03 September 2009 - 11:39 AM
Ok, how is it a mustang gets 10-15 hp with just a bigger TB but we from what being said. not much? I have a NA TB with a 960 plate waiting to go on but now i dont know if its worth it. I love my car, but hate that there so hard to make decent power.
#17
Posted 03 September 2009 - 01:39 PM
dublin14, on 03 September 2009 - 11:39 AM, said:
I don't know about Mustangs. Maybe they are like the K&N filter that gives you 14 Hp.
It is not brain surgery to install so give it a try,
#18
Posted 03 September 2009 - 02:25 PM
If what you say is true, it makes me wonder if its worth the hassle?
#19
Posted 03 September 2009 - 02:33 PM
There are also different characteristics to the intake manifold and head.
95' 850 T5,Eibach Koni FSD,Strut Bar,Adj. Endlinks,ST@17psi,FMIC,
3" DP,2.5" Cust. Cat Back Sys,EST Intake,8k HID,Silcone Everything
04' S2K, Coil Overs, HKS Exhaust, Injen Inkake, Cust. 3 Piece Wheels
98' V70 bone stock
#20
Posted 03 September 2009 - 02:40 PM
Please explain...what in the turbo TB are you boreing?
