Bolt On Garrett Actuator Upgrade For Td04Hl Turbos
Posted 01 September 2009 - 07:58 PM
The actuator can be installed with the turbo in the car. Due to the addition strength of the internal spring, I highly recommend using a manual boost controller with it.
Price shipped with USPS priority is $108 via paypal or $105 via personal check/money order.
Posted 01 September 2009 - 11:17 PM
1991 780TIC-RARE!-named "roxanne" by the GF.-more pressure-less restrictions-plenty of suspension bits to come!
Posted 01 September 2009 - 11:31 PM
Underhill, VT 2002 S60 T5 5 speed. 2000 Honda CBR 929RR
Posted 01 September 2009 - 11:55 PM
All wastegate actuator do is to control the boost level via opening and closing a flapper. It does not make a turbo more or less efficient.
Posted 02 September 2009 - 01:07 AM
Posted 02 September 2009 - 01:26 AM
is the issue using stock BCS not releasing the WG? being ME7 means no MBC for me, and EBC at a price not worth it right now
Posted 02 September 2009 - 04:05 AM
850 Project
SHORT SHIFT KITS---------- TURBO INTAKES---------- SHIFTER CABLE BUSHINGS
Posted 02 September 2009 - 11:13 PM
rbodor3, on 02 September 2009 - 01:26 AM, said:
My car is 94 855 turbo, so I can only speak from experience using what I have.
When I used the Garrett actuator with my tune ecu, the boost level went 4psi-6psi higher than expected. I put a MBC in there and the issue went away and boost level is solid. I never used the Garrett actuator with my stock ECU.
sconeman, on 02 September 2009 - 04:05 AM, said:
Not sure how I can describe "used" other than they are used but in great condition. Hold vacuum like they should. No specific miles on any of them.
Here are the pictures I have. I have one last bracket that is this style, when it is sold, I will use a different type of bracket.
Posted 03 September 2009 - 06:24 PM
1996 Volvo 850 Platinum Edition"R" Exhaust Manifold, Garrett Stage III 54 Trim T3/T4 Hybrid Turbo, 550cc @ 3bar Injectors, Racelab Intake Manifold, 3" Full SS Exhaust, TurboTuner, CAI, BOV, Custom FMIC Setup, Crane Ignition, 5spd Swap, Walbro Fuel Pump, KONI FSD & Eibach Springs, IPD Sway Bar Kit, IPD BBK,
Posted 05 September 2009 - 03:54 AM
95 854 T5-M
Posted 30 November 2009 - 08:50 PM
#14
Posted 30 November 2009 - 11:12 PM
#16
Posted 01 December 2009 - 08:34 PM
the actuator is sick!
Boost builds really fast (so be conservative first time you run it... fyi).
Expect higher boost levels also. I was seeing over 20psi (on accident) while using this. Can't remember what psi the actuator opens at, but its significantly higher than stock. Amazing how huge of a difference the Garrett WG actuator makes.
#17
Posted 03 December 2009 - 10:54 PM
#18
Posted 04 December 2009 - 05:04 PM
96' 850R
#19
Posted 04 December 2009 - 05:20 PM
#20
Posted 04 December 2009 - 06:40 PM
rbodor3, on 04 December 2009 - 05:20 PM, said:
96' 850R
