S60R Hg On A 2.3L
Posted 18 September 2009 - 01:35 AM
If it doesn't work what are the guys running 20 lbs + using for a Head Gasket?
Posted 18 September 2009 - 02:26 AM
Posted 18 September 2009 - 02:30 AM
Headgasket and holding more boost ?
I used stock headgasket, copper headgasket spray with arp head studs and held 21 psi in first and 2_ whatever psi i wanted in second, third, etc. . .
but then again i was probably the only one running a 16 psi wastegate (minimum boost) among everyone
FIRST TO PUT 20G ON AN 850R
Posted 18 September 2009 - 02:40 AM
Posted 18 September 2009 - 07:33 PM
1991 780TIC-RARE!-named "roxanne" by the GF.-more pressure-less restrictions-plenty of suspension bits to come!
Posted 18 September 2009 - 08:31 PM
randomdude, on 18 September 2009 - 07:33 PM, said:
Posted 18 September 2009 - 10:30 PM
1 of 1 - '97 427 854R - 110k
Posted 18 September 2009 - 10:45 PM
7 VII 7, on 18 September 2009 - 10:30 PM, said:
anyways I found this thread here and it basically explains the S60R is 3 ply so it will lower the CR = bad for performance. It will hold more performance wise since its 3 ply but I really only want this engine to last 6 months so i'll go the safe route and when I do my build I'll use the S60R gasket
Posted 18 September 2009 - 11:05 PM
and i think ozzi hit it on the head.
but either one is fine.
Posted 18 September 2009 - 11:10 PM
Posted 18 September 2009 - 11:39 PM
Black Betty, on 18 September 2009 - 11:10 PM, said:
Why not get the complete solid lifter head? Its what I have for my build.
1995 854 T5M Click for Mods
2005 S60 2.5 T
2010 XC60 T6 AWD
Posted 18 September 2009 - 11:53 PM
Volvospeed On Google+
#14
Posted 18 September 2009 - 11:56 PM
Che, on 18 September 2009 - 11:53 PM, said:
#15
Posted 19 September 2009 - 12:05 AM
#16
Posted 20 September 2009 - 12:05 AM
Che, on 19 September 2009 - 12:05 AM, said:
does anyone oring whiteblocks? i know the boosted e30 guys are real big on it.
JVC, on 13 March 2012 - 05:56 AM, said:
#17
Posted 20 September 2009 - 02:18 AM
mdlimy5, on 20 September 2009 - 12:05 AM, said:
I did.
#18
Posted 20 September 2009 - 03:01 AM
Che, on 20 September 2009 - 02:18 AM, said:
block and head or just the block? did you use an oem hg? pictures?
#19
Posted 20 September 2009 - 02:31 PM
mdlimy5, on 20 September 2009 - 03:01 AM, said:
Just the block. No point in doing th head also. Should be pics up if not I will dig some out.
#20
Posted 22 December 2010 - 11:52 AM
Chuck, what is your argument for the use of the newer R head gasket?
