My Dyno Charts
40 replies to this topic
#1 Snabb T5M
  • 8,278 posts
  • Interests:Drag racing; beating up on rice burners; rugby; traveling the world
Posted 21 September 2009 - 04:07 PM
Ok, so here's the dyno charts from last Friday. The dyno was a Dynapack Dyno. Max Torque was 308 lb/ft, and HP was 285.3 whp. Thought it would have been more. :( Is the ups and downs in the torque and boost normal?
boost levels
torque and HP
Lee 1998 S70 T5M; 113K+ miles; IPD Stage III ECU; 18T turbo @18.5psi; Precision FMIC; R manifold; EST 3" DP; balanced crank with LGSpeed rods; 3 angle valve job; SPEC III clutch; ALL of Sconeman's "go fast" parts; KW2 coilovers; TurboSmart Eboost2 EBC ---13.605 @ 105.39 mph ---
#2 7 VII 7
  • 22,324 posts
Posted 21 September 2009 - 04:10 PM
Those are not bad numbers for running a IPD tune, R mani, exhaust and IPD TCV
1 of 1 - '97 427 854R - 105k
#3 rbodor3
  • 958 posts
  • Gender:Not Telling
Posted 21 September 2009 - 04:13 PM
those are pretty good numbers, great for the 16t
#4 Snabb T5M
  • 8,278 posts
Posted 21 September 2009 - 04:15 PM
Perhaps, just need to find the solution for the torque and boost ups and downs. Shouldn't the torque and boost rise to a crest and then hold at a steady level and not fall up and down? :huh:
#5 turbor850
    i am the new pegs
  • 4,188 posts
Posted 21 September 2009 - 04:58 PM
good numbers
try a different dyno with a/f next time
FIRST TO PUT 20G ON AN 850R
#6 Boost3237
    Went Full Retard
  • 2,322 posts
Posted 21 September 2009 - 05:05 PM
Yes those are good numbers
and
I second Turbor's recommendation
Engine build is still up for sale PM me for details.
#7 Snabb T5M
  • 8,278 posts
Posted 21 September 2009 - 05:07 PM
They ran the A/F ratio.
View Postturbor850, on 21 September 2009 - 04:58 PM, said:
good numbers
#8 socal850tuner
  • 1,238 posts
  • Interests:cars....
  • Crew:SCC
Posted 21 September 2009 - 05:10 PM
Knowing the AFR's would help determine the cause of the ups and downs. honestly ive seen a lot worse variations. Maybe check and make sure all of the clamps are tight, the boost seems to drop at about the same level each time so maybe a clamp is a little loose and lets boost drop once there is an opening created by the pressure. Or try putting in a MBC or EBC. Even with the quality IPD TCV, a MBC or EBC should give a much more even boost curve.
'97 850 T5; K&N cone filter, IPD Sway Bars, Powerslot Slotted Discs, Strut Brace, IPD Poly upper engine mount, Voodoo mbc, MSD Blaster SS, Magnecor Spark plug Wires, Autometer Boost gauge on A-pillar, Pioneer Head unit, pioneer 5 1/4" up front and pioneer 6"x9" in the back, Rockford 450w amp, ~600 MTX 10" Sub, pioneer back door speakers, and 3.5"clarions in the dash
projects: Porsche 2.8 race, Porsche 2.0 race(complete), Porsche 3.2 street (complete), Porsche 3.4TT street(complete), Porsche 3.0 street (complete), Porsche 3L twin-plugged carbed street rocket(complete)
2K Motorsports
#9 Snabb T5M
  • 8,278 posts
Posted 21 September 2009 - 05:17 PM
I'm checking with the shop now for the AFR's, they ran it because they hooked into my bung on the DP. Additionally, I'm looking to get the HKS EVC V boost controller to help with the boost stability. Will also check the clamps again.
#10 Fake-R
    Rarest Member Ever
  • 2,124 posts
  • Interests:Pushing envelopes.
Posted 21 September 2009 - 05:21 PM
Expecting more? Jeeze. Those numbers are great for a 16T. The TQ is a little lower than expected, but the HP is very nice.
-1996 850 Turbo
-2007 XC90 V8
#11 Snabb T5M
  • 8,278 posts
Posted 21 September 2009 - 05:25 PM
For some reason I was hoping for around 300hp. Call me overly ambitious. Guess if I want 300hp need the 18T then. Time to call DW.
#12 Fake-R
    Rarest Member Ever
  • 2,124 posts
Posted 21 September 2009 - 05:29 PM
For the best efficency, and numbers, look into getting a 19T, over the 18T. I know the flow isn't that much different, but it still flows better than the 18T.
I'm really impressed by your WHP, personally. Considering I have many of the same modifications, and a little more, I'm curious to know what I'm putting down.
-1996 850 Turbo
-2007 XC90 V8
#13 Snabb T5M
  • 8,278 posts
Posted 21 September 2009 - 05:31 PM
My only concern with the 19T is getting a tune for it. With the 18T I can get the IPD tune, but guess I could use the IPD 18T tune for the 19T.
#14 Fake-R
    Rarest Member Ever
  • 2,124 posts
Posted 21 September 2009 - 05:33 PM
I'm going to be running the Stage III tune with my setup. Like I said, the flow isn't that far off, and it's certainly better than running the 15G BSR tune I'm running now. It's ultimately up to you though, but considering you already have a built block, I'm go big, or go home, haha.
-1996 850 Turbo
-2007 XC90 V8
#15 Snabb T5M
  • 8,278 posts
Posted 21 September 2009 - 06:02 PM
ok, here's the AFR chart, didn't notice it the first time.
AFR
#16 Mesoam
  • 18,303 posts
Posted 21 September 2009 - 06:03 PM
you have a built bottom end, go get a manual boost controller and watch your peak torque go up a nice bit
96 854 R, CLICK ME
The Jeep
#17 Snabb T5M
  • 8,278 posts
Posted 21 September 2009 - 06:20 PM
I'm hestitant to get a MBC because of the uncontrollable factor of having the boost come on too fast in 1st gear and having to feather the gas in 1st. I like the idea of the dual stage MBC, but at the drag strip not sure if I can act quickly enough and be consistent all the time to throw the firing switch for high boost. I like the idea of the HKS EVC and letting it do all the low to high boosting automatically for me. I'm really anxious to see what the EBC will do to these charts after installation (like smoothing everything out).
#18 7 VII 7
  • 22,324 posts
Posted 21 September 2009 - 06:26 PM
but you have a built bottom end................
#19 Snabb T5M
  • 8,278 posts
Posted 21 September 2009 - 06:32 PM
:huh: I understand that and I understand I can run a bit more boost, but my problem is wanting to be able to control that boost in 1st gear at launch. What am I not understanding from this?
#20 FCP Groton
  • 1,838 posts
Your numbers look really good for your setup. The HP and Torque look on the money. I would be very happy with those numbers.
Andrew Owendoff
IPD
