Parting 98 Xc, Grey
22 replies to this topic
#1 DHV70
    Deadbeat, owes people money Derrick Hendrickson 860-841-0504
  • 576 posts
  • Interests:Derrick Hendrickson
    39 olde hall rd.
    Hebron, CT 06248
    Cell Phone: 860-841-0504
    Home phone: 860-530-1325
    Mom's Work phone: 860-486-4120 You may get results with her. who knows.
    Derrick's email: DHendrickson117@gmail.com
Posted 27 September 2009 - 11:50 PM
Quote
The timing and serp belts are LITERALLY brand new, and the tires have ~ 10k on them, with very little wear at all.
New headlight lenses and turn signals, as well as foglight bulbs. Eurofog relay conversion has been done. The intake manifold, engine cover, intercooler pipping and the fuel rail have all been painted, and the outside of the car has been meticulously taken care of since I got it. The grey trim was re-sprayed black, as have all the grills and the roof rails. As mentioned before, the engine and turbo were replaced with a 98R setup, and the angle gear was replaced with one of hussien's. The SAS has been removed and welded shut, and the car is currently FWD (by choice). The driveshaft is in perfect condition, and will be reinstalled upon request - otherwise, it will be included. The PCV was done while the engine was out, and the plugs were replaced with NGK copper plugs gapped to .26. It was filled with Castrol GTX High milage oil, and a can of 6 Cylinder Restore (the cans are different sizes for each cylinder number). The oil filter is a Mobil 1 filter, and the transmission was partially flushed today. There is a boost guage installed in the dash board, where the auxiliary ports for the rocker switches belong. The only thing on the car that does not work is the flasher switch, which tends to have a mind of its own. There are still red injectors on the engine, but it has a 98 T5 ECU in it. The trunk panel has been repaired with the iPd kit, and the car has been debadged (except for the "xc"). All the badges are with the car, as is the owners manual and correct radio code. The shifter light has been replaced with blue led's ('93 Dave's custom setup) and looks great. All dash lights are in working order, except for a few radio bulbs. All window switches have been replaced, including the driver's master switch. The gas cover clip has also been replaced with the FCP Groton replacement piece, as the original one broke off. The turbo vac lines have all been replaced with iPd's silicon lines, and routed to a manual boost controller that works great, and is good for up to 30PSI without having to drill a 1/32" hole in the side of it. Pictures will be available when it stops raining, and any specific ones are available upon request. I'll gladly ask any other questions you have for me. I'm asking $2600 OBO as is, or $3200 if I need to bring it to a shop before you buy it. Again, feel free to contact me about anything.
The transmission is officially dead, and I can't afford to fix it.
SO, a list ensues:
Doors - 200 a each, including hatch (fixed trunk panel)
Hood - 200 sold
Bumpers - 150 each - Front is sold
XC grill (painted BLACK, not crappy gray) - 150 sold
2.3L 98 R motor - 450 (180K)
16T - 200 (180K) sold
Wood grain steering wheel (cherry) - 175 sold
Wood grain shifter (cherry) - 35
Entire wood grain trim, perfect condition dark burl - 130
Tan Seats - 75 for each front, 100 for rear seats, great condition
Speakers - 40 a piece
Dash tweeters - 25 a piece
Tan Dash Pad - 80
Black Dash Pad - 80
Tan Dash (excluding cover) - 90
Stock Head Unit - 60
Wheels (15" Stock, new tires) - 350
Angle Gear - 250
Axles - 35 Each
Drive Shaft - 100
Suspension - 175
Switches - 5 each, No flasher.
Info / Dimmer Switches - 15 dollars
Cluster - 100
Summer Floor Mats - 125 for the set
XC Lower Fog Grills - 25 each (painted BLACK, not grey)
XC Fogs - 55 Each, 100 for the set
Head Lights, perfect condition - 75 each passenger side sold
Upper Tails, perfect condition - 50 each
Lower Tails, perfect condition - 50 each
Interior Xenon bulbs from EST - 25 for the set
The T5 ecu is not for sale, it belongs to another member. The stock xc ecu is 50
Turn Signals - Sold
All Other Parts Upon Request
Pictures will be provided upon request, although all parts are still on the car
Shipping will be discussed, most likely included
Larger items will go to those who pick up first
The entire car goes for 2200
-Derrick
Deadbeat, owes people money.
39 olde hall rd.
Hebron, CT 06248
http://volvospeed.co...0
#2 DHV70
  • 576 posts
    39 olde hall rd.
    Hebron, CT 06248
Posted 28 September 2009 - 12:32 AM
I forgot to mention, there's only 40k on the front bumper, pass. side fender, and headlights. The driver side turn signal only has 15k on it.
Both turn signals go for 20, 35 as a pair.
39 olde hall rd.
Hebron, CT 06248
#3 Tom.
    LONGTOM
  • 2,852 posts
Posted 28 September 2009 - 01:13 AM
poor dolly :( oh well a saff R is better... ;)
gl with the parting! hahah
00 Olive V70R -- 98 S70 T5M -- 99 Silver V70R - FOR SALE! - CLICK!
#4 Korruption
  • 1,455 posts
Posted 28 September 2009 - 01:28 AM
You has PMs :)
98 V70 R AWD - M66 - 2.5T
91 244 NA - M47
98 V70 XC AWD - 218K 96 960 RWD - 226K
#5 Ghost Shadow
  • 2,826 posts
  • Interests:testing
Posted 28 September 2009 - 01:50 AM
did i miss where you posted what color the interior and exterior was?
edit: read the tittle says grey.....would help to have pictures
2003 Nautic Blue XC90 T6 3rd tranny - 162k Modded http://tinyurl.com/74pwukq 2001 Nautic Blue C70 T5 Manual - 92k Not stock at all http://tinyurl.com/75zhepq SOLD 1998 Olive Green V70 T5 Manual - 155k Awesome stock car http://tinyurl.com/85mh7z3
#6 Tom.
    LONGTOM
  • 2,852 posts
Posted 28 September 2009 - 01:54 AM
the int is tan.
#7 DHV70
  • 576 posts
    39 olde hall rd.
    Hebron, CT 06248
Posted 28 September 2009 - 01:55 AM
The interior is tan, I didn't think to post it up after the list containing so may tan items.
The black dash was supposed to be the beginning of my two-tone swap.
Pictures are available upon request...
But like I said, its pouring outside, you wouldn't get any good ones lol
39 olde hall rd.
Hebron, CT 06248
#8 TyConn
    Delta Bravo
  • 816 posts
  • Interests:Wings 'n Things
Posted 28 September 2009 - 02:23 AM
I hate you so much -_-
Ted is gonna kill you...
1998 V70 T5 M
1994 854M Silver on Black
1998 Black on Black S70T5
1998 S70 GLT
1990 245 DL M47
...RIP at 320K
#9 greekone
  • 3,033 posts
Posted 28 September 2009 - 03:04 AM
+1
1998 S70 T5M
1996 854R
#10 volvorecycle
  • 19 posts
Posted 28 September 2009 - 12:32 PM
what i need is the hood latch assembly, turn signal switch, and the driver's door speaker cover and i will pay for the whole door panel and your time to take off the cover. doesnt matter on the color. PM me with a response because it is easier for me to get the message
78 242 GT 600,000km
81 244 Turbo Restored
82 242 GLT My baby
www.volvorecycle.com
#11 --Aaron--
    douche bag
  • PipPipPipPipPipPip
  • 12,543 posts
  • Gender:Female
Posted 28 September 2009 - 10:14 PM
Int. color code?
#12 shreksbrother
  • 10 posts
  • Interests:Cars, R/C Helicopters, R/C Cars, Weather, Emergency Medicine, oh and Family ;)
Posted 28 September 2009 - 10:28 PM
Willing to ship front seats? Zip 36107
#13 greekone
  • 3,033 posts
Posted 29 September 2009 - 02:06 AM
View Post--Aaron--, on 28 September 2009 - 10:14 PM, said:
Int. color code?
3980
1998 S70 T5M
1996 854R
#14 DHV70
  • 576 posts
    39 olde hall rd.
    Hebron, CT 06248
Posted 29 September 2009 - 02:56 AM
View Postgreekone, on 29 September 2009 - 02:06 AM, said:
3980
Thanks Billy ;)
39 olde hall rd.
Hebron, CT 06248
#15 blu92in99
  • 201 posts
Posted 29 September 2009 - 02:27 PM
PM sent.
-Justin
'83 242Ti - FOR SALE!
'71 142E - mostly stock, new DD.
#16 Big Will
  • 2,174 posts
Posted 29 September 2009 - 04:29 PM
For Purposes of the angle gear: What is the chassis number of your XC so we can know up to what car your angle gear and other AWD parts fits.
Also, what condition are the fog lights in? Thanks!
Me: "Yea."
#17 DHV70
  • 576 posts
    39 olde hall rd.
    Hebron, CT 06248
Posted 29 September 2009 - 06:31 PM
Chassis number = early 98, lol
The fogs are pretty pitted, but I'll refinish the glass for anybody who wants them :)
39 olde hall rd.
Hebron, CT 06248
#18 DHV70
  • 576 posts
    39 olde hall rd.
    Hebron, CT 06248
Posted 30 October 2009 - 12:57 AM
this thread just went bump in the night. :P
I need this stuff goneeeee, make me an offer for anything and I'll probably take it..
39 olde hall rd.
Hebron, CT 06248
#19 303jrodt5
  • 565 posts
Posted 30 October 2009 - 02:22 AM
will the rear mudflaps fit an S70 bumper? if so how much shipped to 57103.
#20 greekone
  • 3,033 posts
Posted 30 October 2009 - 02:36 AM
1998 S70 T5M
1996 854R
IPD
