Endlinks
Posted 28 September 2009 - 01:33 AM
2007 Electric Silver S60R-------105.5k
Posted 28 September 2009 - 01:36 AM
Posted 28 September 2009 - 01:37 AM
http://www.ipdusa.co...51-693-655-856/
Same part #'s so yep should work just fine.
96' 850R
Posted 28 September 2009 - 04:53 AM
98 S70 GLT.
Posted 02 October 2009 - 06:30 AM
afcoracing.com for rods
midwestcontrol.com for rod ends
built mine on the cheap
Posted 02 October 2009 - 11:57 AM
Pictures of how you did it possibly? Would you consider building them for sale?
Posted 03 October 2009 - 02:02 AM
Mine are 12" rods (5/8" thread), 5/8"x5/8" rod ends, and 5/8" to 1/2" reducing misalign spacers.
oops... 10" rods
not 12"
Posted 04 October 2009 - 02:20 AM
B Mac, on 02 October 2009 - 11:57 AM, said:
It's nice because I was able to make longer links for my lowered car to keep the swaybar in the right spot... but the joints don't last that long unless you find a good way to seal them up, which I didn't.
Posted 04 October 2009 - 02:46 AM
Posted 04 October 2009 - 01:47 PM
http://www.midwestco...hort.php?pg=561
So I guess the next set I make will have a threaded rod and female rod ends
There is also this though..
http://www.midwestco...hort.php?pg=230
But I'm not sure how well it'll really hold up compared to the full boot, since the back of the rod end won't be sealed properly.
Posted 05 October 2009 - 04:21 AM
Posted 05 October 2009 - 05:47 AM
B Mac, on 05 October 2009 - 04:21 AM, said:
#14
Posted 05 October 2009 - 01:30 PM
00' V70 NA 15XK Miles
84' 242 shell at the moment
#15
Posted 05 October 2009 - 04:33 PM
fenwick253, on 05 October 2009 - 05:47 AM, said:
The hard part is figuring out which endlinks you want and how to seal them
#16
Posted 06 October 2009 - 05:34 AM
If you could make a parts list that would be great. I have the qbm's version 1, but would love some aluminum ones like what you have. Also if you ever find a way to seal them pleas let us know. Maybe you can build something very similar to what you have now, but use the female ends so that you can use the rubber boots on that site. Then use a threaded stud for between the spherical ends and aluminum rod with two locking nuts.
If what I said above works, and you can make a parts list I know myself and others on this site would be very thankful.
I just put on qbm's gen one end links and I know they wont last long since I can't find a way to seal them. I will either keep buying new spherical ends every few years or find a way to seal them. I also don't like that they are heavy.
Something else to think about. Aluminum is more rigid so it is not only lighter, but better for this application.
-pinky
strut brace,sway bar endlinks 20mm
Daily driver
#17
#18
Posted 06 October 2009 - 04:53 PM
ozzimark, on 06 October 2009 - 10:34 AM, said:
true, not wanting to argue, but will say. The link posted by you shows a cost of rods rather cheap in comparison to other alternatives I have looked at. Also we are talking about performance in the performance section, so using materials that will give you better performance but wear out quicker is a norm, i.e. running more boost on motor. Also lighter so you can even go as far to argue that while being stiffer and harder on suspension it is also lighter and therefore slightly less stress on suspension components. One other thing, the failure rate is not not drastically high in my opinion. Again a trade off for higher performance.
Big picture, cheap relative to qbm's or other alternatives I have been looking at. Not to mention better performance.
I might have time this week to try to put together a parts list and post it here so you guys can look it over to make sure I have it all right.
-pinky
Daily driver
#19
Posted 08 October 2009 - 07:32 PM
#20
Posted 06 November 2009 - 04:10 AM
How did these hold up? You made them early in the year, right?
I'd still like the parts list if you don't mind sharing; I have IPD links now, but homemade suits me better
