No Spark! Wtf?
Posted 05 October 2009 - 09:51 PM
Posted 05 October 2009 - 11:30 PM
edit: retard here should have read the whole post, forget the ecu. check the plug that goes to the coil like i said.
JVC, on 13 March 2012 - 05:56 AM, said:
Posted 05 October 2009 - 11:35 PM
Posted 05 October 2009 - 11:39 PM
Point I am getting to is maybe its something simple
Have you used a spark tester to confirm no spark?
Chris
Posted 05 October 2009 - 11:43 PM
Posted 05 October 2009 - 11:50 PM
Hoosier Daddy, on 05 October 2009 - 11:43 PM, said:
The halfmoon can be rotated 180deg (Well mine would but maybe mines just messed up)
Inst the strut tower painted tho? I mean not good enough ground? You can also put the spark plug/wire on a bare metal surface in the engine bay to check spark (with the lights off in the garage its pretty cooool)
I think if the cams were f'ed then it would either run bad or you would bend a valve?
Posted 05 October 2009 - 11:51 PM
Posted 06 October 2009 - 07:12 PM
Posted 06 October 2009 - 07:14 PM
trust me I spent a whole day testing crap on a car to find out the batterie had died since I removed it from the car.
Posted 06 October 2009 - 07:35 PM
you are checking for sprak from the coil wire and not just a spark plug lead correct?
and you dont have the crank or cam sensor plugged into something else right? there is one plug that is around that area that i belive will interchange with either the cam sensor or crank sensor(cant remember)
Posted 06 October 2009 - 10:37 PM
Posted 06 October 2009 - 10:40 PM
Hoosier Daddy, on 06 October 2009 - 10:37 PM, said:
turn the ignition on and check the plug that goes to the cam sensor, you should have a ground, a 12v and a 5v, do you?
Posted 06 October 2009 - 11:41 PM
#14
Posted 06 October 2009 - 11:55 PM
Hoosier Daddy, on 06 October 2009 - 11:41 PM, said:
weird, check the brown/black wire that goes into that plug and see if it is a good ground.
do you have an analog volt meter? (old school with a needle)
#15
Posted 07 October 2009 - 12:16 AM
#16
Posted 07 October 2009 - 01:55 AM
should give you a signal like this
#17
Posted 08 October 2009 - 06:26 AM
#18
Posted 08 October 2009 - 06:35 AM
Hoosier Daddy, on 08 October 2009 - 06:26 AM, said:
let us know what you find!
#19
Posted 08 October 2009 - 10:41 AM
93 Jaguar XJ6
87 Volvo 360
#20
Posted 10 October 2009 - 07:06 AM
