Uh Oh..Detonation
33 replies to this topic
#1 850 LongBeach
    Cpt. Facepalm
  • 442 posts
  • Interests:Making Volvospeed fun and interesting, while at the same time getting banned for things I didn't do! Going 95+ in packed residential areas, and turbos that bend stock rods
Posted 21 October 2009 - 10:49 PM
Well I just recently changed my spark plugs to the same exact kind Champion Copper RC12YC I gapped at .025 I believe my old ones were gapped at .026
Im running about 17-18 psi
My first run after I changed the plugs it hauled crazzzy ALL GLORY TO THE HYPNOTOAD at 18 psi with no detonation at all, but then hours later It started detonating
AF/R's are in 11-12s
At anywhere above 12-13 psi I start to detonate
Anyone have any reccomendations?
Im thinking maybe bad gas? I just spent about 15$ at a mobil about 3 hours before the first run,but there was still gas in the tank ,
91 is all we get in cali but It usually does fine...Im thinking maybe a switch to chevron might do my car good.
Please shed your ideas thanks guys
: InMotion 17psi stage 2 : 19T Angle Flanged : 3 Inch Turbo Back No Muffler/Cat : IPD SRT5 Intake : HKS EBC IV : MSD Ignition + IPD Coil : HKS Type BOV : IPD Reverse Intercooler Piping Kit : More :
#2 850 LongBeach
    Cpt. Facepalm
  • 442 posts
Posted 21 October 2009 - 11:04 PM
Admin I have moved to fwd, please delete
sorry guys
#3 PsychoWagon
  • 831 posts
Posted 21 October 2009 - 11:11 PM
You shouldn't have to gap @ 17-18psi on a 19t. I've said it many times, use oem plugs it will probably fix your problem, secondly, if you are going to gap, .025 is way too small. .027-.028 on oem plugs with the 19t and have a nice day. Take your plugs out and take a look at the electrode on the plug be all melted away :P
1998 S70 Automagik - M56 Swap - RSI Rods - OS2 Pistons - 440cc injectors - 19T Hybrid - 21psi after engine break in
FOR SALE: Automatic Transmission 94-98 850/X70 - 260000km 3 synthetic flushes
98 T5 Engine - 265000km 155psi across board
#4 Cal3thousand
  • 2,065 posts
Posted 21 October 2009 - 11:14 PM
Agreed,
you shouldn't be gapping down unless you had spark blowout. In fact, you should use the widest gap that won't blowout at your boost level.
But, there are plenty that gap down lower... But in the end, a 15G tune on a 19T... what would you really expect?? what injectors are you running?
1994 854 Turbo
#5 850 LongBeach
    Cpt. Facepalm
  • 442 posts
Posted 21 October 2009 - 11:21 PM
YOU ARE 100% RIGHT, I had the other plugs in for only about 2k-3k miles and the the contact arm was all white and blistered but the electrode was fine
View PostCal3thousand, on 21 October 2009 - 11:14 PM, said:
Agreed,
Whoa dont say that, It has been running nothing but good lately, this is user error,
im going to fix the gap before I go to school today, im letting the engine cool down...
Let you know what happens later for sure
Oh and stock oranges
The Champion RC12YC is listed in Haynes manual as OEM as well :monkey:
#6 PsychoWagon
  • 831 posts
Posted 21 October 2009 - 11:23 PM
Quote
Haynes is the other problem :P
If the plugs are already screwed regapping may not do anything. I would get new plugs and go to 0.028 and see from there.
#7 850 LongBeach
    Cpt. Facepalm
  • 442 posts
Posted 21 October 2009 - 11:30 PM
I havent looked but they have only been in for one day so im not planning on buying new ones :rolleyes:
#8 HayaCruza
  • 138 posts
Posted 22 October 2009 - 12:10 AM
Everyone keeps saying use OEM plugs but look at your owners manual, what does that say:
My 1997 850 owners manuals says:
For Turbocharged - Champion RC7GYC (or equivalent)
Notice that it does not say Volvo PN XXXXXX, it actually says CHAMPION! :ph34r:
#9 Black Betty
  • 6,899 posts
Posted 22 October 2009 - 01:17 AM
I have coppers gapped to .022 I doubt the gap is the problem, the only "problem" I have is a backfire whenever I push it
#10 Fake-R
    Rarest Member Ever
  • 2,124 posts
  • Interests:Pushing envelopes.
Posted 22 October 2009 - 01:20 AM
I'm using OEM plugs, gapped to .25, with no issues. Watch that detonation, that will kill your rods.
-1996 850 Turbo
-2007 XC90 V8
#11 Black Betty
  • 6,899 posts
Posted 22 October 2009 - 02:43 AM
+1 figure that shit out LB as much as I hate it make me look like an idiot and keep your rods straight sounds like you actually found a setup that works well with the 19t
#12 lookforjoe
  • 7,810 posts
  • Interests:Making Stuff
Posted 22 October 2009 - 03:21 AM
Are you sure you don't mean blowout?
Detonation would probably have killed your motor by now, at those boost levels.
1998 V70 XR M66 10cm2Hotside/Garrett 60-1 Built T5 Motor '03 Ported Head EnemY21Cams TurboTuner 710cc Inj, DP back Dual Magnaflow 14834's May 2011 355WHP(@6400rpm) 347WTq(@4400rpm)@22psi Now with LGSpeed Header & Custom Intake Manifold! BIG 31x12x3"FMIC Currently sporting a vented piston!!!
#13 shaun
  • 542 posts
Posted 22 October 2009 - 03:57 AM
that is a cold plug. my car ran like stuff on 9y when I could not get 7y in a pinch. 12y could foul quickly. you said you are not willing to by new plus since these are new. 10 bucks? really? you car is super rad but the right temperature plugs are really important. are you sure you took out 12s?
1995 olive green 855 t5r 152,000K 97.024% stage 0- the usual stage 1.5 ish mods.
#14 850 LongBeach
    Cpt. Facepalm
  • 442 posts
Posted 22 October 2009 - 05:54 AM
I live in a different climate than you...Im running a different turbo on a different set up and yes im sure I took out 12's
#15 Zaitz
  • 1,829 posts
Posted 22 October 2009 - 06:31 AM
That's what I was thinking.
#16 Boost3237
    Went Full Retard
  • 2,322 posts
Posted 22 October 2009 - 12:32 PM
I'm still on the fence here, I was gapped at .025 for a long time, then I backed off to .028 and I honnestly did not notice a difference.
Engine build is still up for sale PM me for details.
#17 PsychoWagon
  • 831 posts
Posted 22 October 2009 - 11:23 PM
Quote
climate has nothing to do with plug heat range... the temperature in the combustion chamber has everything to do with it. whether it be +40c or -40c outside, your combustion temperatures don't vary all that much.
#18 ozzimark
  • 4,295 posts
Posted 23 October 2009 - 12:01 AM
How come you're the only one without a -1 or -2 in this thread right now? :lol:
Also, manual calls for 7 I believe. You put in 12. 12 is a much higher heat range than 7, thus the plugs will run much hotter. Gap isn't the issue, your spark plugs are turning into glow plugs, thus the detonation.
#19 shaun
  • 542 posts
Posted 23 October 2009 - 04:11 PM
I gave up when sunset climate zones came into the conversation, but FYI the tempo range numbering system on plugs is counter intuitive. The higher number is colder
http://www.gsparkplu...ras/heat_range/
http://www.nagca.com...arkplugheat.htm
the OP might benefit from from a plug one step colder or something with his mods, but not 5. Seems to me like 5 steps colder would foul quickly, and that would very likely cause weak, none, or blown out spark as lookforjoe stated. If it were my car with those plugs and that problem i would get the right plugs in it. The owners manual states y7.
#20 ozzimark
  • 4,295 posts
Posted 23 October 2009 - 07:15 PM
Champions are backwards from NGK. Higher = hotter. Same with Bosch
http://www.champions...yImages/722.jpg
Just checked my manual, which may be different from LongBeach's car, but I doubt it. It calls for a Bosch 7 or Champion 9. 12 is WAY too hot for a turbo whiteblock application, no matter how you look at it.
IPD
