Lower Shores Performance Mbc
6 replies to this topic
#1 T5Manual850
  • 170 posts
Posted 22 October 2009 - 04:59 PM
I just bought a EBC, so now i don't need this. Selling this for $35 shipped :) CONUS, It will hold whatever boost you want!
850T
IPD Stage III + Meth/WI MT ----- 18T angled ----- 350cc white injectors ----- s60R manifold ----- 3" OBX angled dp ----- Magnaflow HFC ----- 3" Magnaflow exhaust ----- FMIC ----- 3" open element CAI ----- 2.75" Sconeman pipe ----- 150psi 250cc Meth/WI ----- MSD Blaster SS ----- Kingsborne 8.5mm spark wires ----- Forge BOV ----- Greddy Profec B spec II EBC ----- AEM Uego Wideband ----- m56H manual ----- R clutch ----- Koni Yellow Struts/shocks ----- IPD 1.75" springs ----- IPD 25mm/22mm sway bars ----- HD endinks ----- OBX v2 Strut bar ----- 302mm BBK ----- stainless lines ----- Knocksense ----- ADR RS Mase 17"
#2 ozzimark
  • 4,295 posts
Posted 22 October 2009 - 05:07 PM
I can support that. I have one and it works great, even has a hose fitting for the bleed so you don't bleed air to the atmosphere. :ph34r:
#3 Aequitas_Veritas
    Blue Calipers&Balls
  • 7,585 posts
Posted 22 October 2009 - 05:26 PM
you bought an EBC eh?
40+ mods and counting...
#4 gotboost
  • 689 posts
Posted 22 October 2009 - 05:36 PM
I'll take it. I need one for my 240 build.
1998 S70 T5 SE 5-speed: Angled flange 18T, RICA tune, 3" DP, 2.5" Exhaust, R Manifold, IPD HD TCV, MSD coil, Turboxs BOV, Eurosport Intake, 2.75" Sconeman MAF-turbo pipe, Stylin' Motors hoses, 850R clutch, Sconeman short shift kit, IPD 25/28mm Sways, IPD HD endlinks, H&R springs, Koni Yellows, IPD poly mounts, OMP Strut Brace, HID E-codes and HID fogs, E-code turn signals, XC70 grill, CF OEM valve cover, CF throttle cover, Polished intake manifold, UK-spec S70R cluster, '04+ V70R steering wheel, V70R seats, Blue LED dash lights, 302mm Zimmerman cross-drilled front rotors, Brembo cross-drilled/slotted rear rotors, IPD SS Brake lines, PBR Ultimate Ceramic brake pads F&R, Kevlar timing belt
And Now: 1998 V70XC: EST intake, EST RIP kit, MSD coil, Inmotion tune, IPD poly mounts, 17" Titans, 302mm brakes, E-codes, Hella 500s, V90 rear wiper.
#5 greekone
  • 3,033 posts
Posted 22 October 2009 - 07:00 PM
I'll take it if it's still available, PM sent.
1998 S70 T5M
1996 854R
#6 T5Manual850
  • 170 posts
Posted 22 October 2009 - 10:23 PM
yeah i bought a greddy profec b spec 2 :), gonna install this at the same time as the WI, and also i just bought the pipe/hoses to fab the intake pipe, just gotta make the hole for the ptc nipple.
oh and this is sold!
850T
#7 magicaljake
  • 4,451 posts
  • Interests:woman, booze, karaoke, volvos, fresh nikes,
Posted 22 October 2009 - 10:48 PM
+1 for buying a nice mbc....
do it once and do it right...
long live vanessa 2.0!
IPD
