I have a co-worker who owns a S60 (T-2.5) and wants to know how difficult it might be to change the automatic transmission fluid on this model car? I personally own a 1995 850 and know it isn't a problem to do it yourself in the driveway with 15 qts. of fresh fluid and a 5 gallon bucket. Please inform as to the difficulty level for the S60.
Thanks!
Page 1 of 1
S60 At Fluid Change..............
Posted 31 October 2009 - 12:17 PM
Thanks!
Thanks!
Use the same method as your 850
98 S70 T5M
94 850 Turbo
94 850 Turbo
Posted 31 October 2009 - 05:56 PM
yes, go to ipdusa.com and buy the kit trust me it's worth replacing the o-rings. They will leak if you reuse them. And you only need 12qts for the s60, also buy the fluid at either ipdusa or avlube
3" DP & back | ipd sways and links | ipd TCV | Bilstein & Eibach sport | R - BBK | B&M Cooler | 19T | Walbro FP | ipd CBV
Posted 01 November 2009 - 04:37 AM
<--Current:
96 850 Turbo 60,000 miles on new engine
Previous:-->
96 850 GLT 60,000 before it died...
Posted 01 November 2009 - 06:54 AM
i've got my ipd change kit, and a case of 3309.
i thought that i was supposed buy a couple extra quarts of dino ATF and run that through first?
but my buddy pointed out to me that it would never be completely out of the system. I guess my big question is, is 12 quarts enough to completely flush the system? and just out of curiosity what is the actual capacity of the transmission? assuming an 01 S60 2.4t
Posted 01 November 2009 - 01:30 PM
you better be using a very good synthetic oil or kiss your tranny goodbye! and flush with the good stuff so none of that junky dino gets stuck in there.
1998 S70 Automagik - M56 Swap - RSI Rods - OS2 Pistons - 440cc injectors - 19T Hybrid - 21psi after engine break in
FOR SALE: Automatic Transmission 94-98 850/X70 - 260000km 3 synthetic flushes
98 T5 Engine - 265000km 155psi across board
Posted 02 November 2009 - 01:04 AM
12qts is plenty for your s60.
Posted 02 November 2009 - 09:17 PM
Misinformation: The volvo fluid is NOT synthetic, and the Mobil 3309 (which is the exact same stuff just rebadged) is NOT synthetic.
Using the Toyota T1V fluid is also Mobil 3309. Other than those three you will be chancing it as they are all three approved as meeting JWS 3309 oil specification.
Even doing drain and fills is okay. The important thing with these tranny's is to refresh the friction modifiers every couple of years.
Page 1 of 1
Sign In
Register
Help
Start a new topic
Add Reply
MultiQuote
