Electronic Boost Controller - Gizzmo Ibc
Posted 01 November 2009 - 01:13 AM
http://volvospeed.co...ost-controller/
I fixed the burnt wire (cut that section out and re-soldered the wires) so it should be ready to go.
Never tried it out but it seems to be a pretty solid piece of kit and it has a LCD digital boost gauge built in.
My linhttp://www.gizzmoelectronics.com/Product_IBC.htmlk
From their website
"The Gizzmo IBC (Intelligent Boost Controller) represents the ultimate in Accurate, Simple to operate, and Easy to install Computerised Boost Controller. Because all the thinking is done inside the IBC,you will not require an Engineering Degree to operate or fit it. With the Gizzmo IBC's precision 29Lb MAP sensor, High speed RISC processor and Powerful MOSFET solenoid driver, and the fastest, most powerful solenoid you can assured that your Gizzmo IBC has the Quality, Resolution and Accuracy that you need for your Turbocharged vehicle"
Four Boost Memories
Adjustable up to 2bar (29lb)
Fast RISC Processor Technology
Real Time Digital Boost Gauge
Extruded Alloy case
Simple 2-wire installation
Suits internal or External Wastegates
$125 US + shipping ( I'm in Toronto, Canada - Postal code M5T2C2 )
'00 S70 SE (slow/sold)
Posted 01 November 2009 - 01:24 AM
00 Olive V70R -- 98 S70 T5M
Posted 01 November 2009 - 01:31 AM
Somebody on this site would know.
Posted 01 November 2009 - 01:35 AM
Posted 01 November 2009 - 03:16 PM
'96 855, Koni yellows, ipd springs, TT-USB
Eagle H-beams, Weisco pistons, custom cams
GT3071R, 60lb/hr injectors, Ported R Mani, W2A intercooler
m56h, 707 clutch, P&P'd head, CAI,
Posted 01 November 2009 - 03:24 PM
I would assume $30 for another carrier.
Posted 03 November 2009 - 12:36 AM
Please close thread.
Posted 03 November 2009 - 12:37 AM
Posted 03 November 2009 - 12:51 AM
1991 244 NA - M47
