Volvospeed Forums: Possible Fuel Leak? - Volvospeed Forums
Possible Fuel Leak? 2002 C70
#1 User is offline   Logan2224 Icon
  • Level 1 Member
  • Group: Members
Posted 02 November 2009 - 02:59 AM
Went to Orlando today for the IKEA show, left from Jacksonville. I filled up before I left.
When I got back to school after the show, I noticed that there was 1/3 of a tank left, which is exactly twice the amount of fuel it used last time I made that trip. No CEL, and there doesn't appear to be a leak in the tank. Any ideas? Should I be worrying?
2002 C70 Coupe, silver on silver, 48,000 miles.
Upgrades: all IPD poly engine mounts, Volvo OEM strut brace, IPD HD TCV, VDO boost gauge (haven't installed yet)
0
#2 User is offline   Logan2224 Icon
  • Level 1 Member
  • Group: Members
Posted 03 November 2009 - 01:09 PM
Anybody?
0
#3 User is offline   Crito Icon
  • Level 1 Member
  • Group: Members
  • Interests:Zionist Mafia Busting
Posted 03 November 2009 - 02:28 PM
You could try the top-up method to double check your mileage: fill up before and after driving a known distance and use the gallons on the pump to do your calculations. Helps to know how many gallons the tank hold too. So if the pump says you used half a tank and the gauge reads empty the problem becomes readily apparent.
2003 S80 2.9L non-turbo with 136,000 miles and original GM transmission
The hoofprints of WTC7 http://www.youtube.c...h?v=lESol88wOi0
Connecting the dots http://www.youtube.c...h?v=DtorXLa2JrE http://www.youtube.c...h?v=AQKnErKX2ho http://stopaipac.org/spystory.htm
0
#4 User is offline   DouginDenver Icon
  • Level 1 Member
  • Group: Members
Posted 03 November 2009 - 09:59 PM
Probably would smell a leak that big I would think.
View PostLogan2224, on 03 November 2009 - 06:09 AM, said:
Anybody?
'99 C70 LPT convertible - nautic blue/tan - all stock - 42,000 miles.
'00 S40 1.8t - summer green/gray leather - 97,000 miles.
0
#5 User is online   tchnprgrmr Icon
  • Level 1 Member
  • Group: Members
Posted 04 November 2009 - 01:55 AM
I meant to ask you about your gas mileage. That sounds about right though. I has 16 gallons when we began and had only 4 when I returned. So I used 12 gallons, and if you filled up then you used right about the same amount of gas as I did.
The entire trip was 287 miles, not including local driving around. So roughly an average of 24 mpg. Depending on the amount of city driving maybe more on the highway. If you only used 1/3 of a tank for the same trip, then 287/6 gallons = about 48mpg.
It might be 1-4 mpg less than it should be, but not that bad, as long as we are talking about round-trip for the gas usage.
PM me for my cell if you want to talk more about it logan.
#6 User is online   tchnprgrmr Icon
  • Level 1 Member
  • Group: Members
Posted 04 November 2009 - 02:10 AM
also, just FYI
on an 02 2.3 coupe
Motortrend shows 21-city 27-hgwy mpg
fueleconomy.gov shows 18-city 26-hgwy mpg
#7 User is offline   Logan2224 Icon
  • Level 1 Member
  • Group: Members
Posted 06 November 2009 - 03:50 AM
Hmm I guess you're right Jeremy. Something just still seems off to me, and I'm not sure what. I'm driving to Tampa tomorrow, so I'm gonna fill up before I leave, and keep a real close eye on it.
0
#8 User is online   tchnprgrmr Icon
  • Level 1 Member
  • Group: Members
Posted 06 November 2009 - 04:38 AM
Not quite as accurate as a direct miles, but you can always reset the total mpg and the car will recalculate it for you.
I've found it to be overly optimistic though. It said I averaged 26.5mpg on the total drive to ikea and back, it was probably closer to 23.5.
#9 User is offline   Logan2224 Icon
  • Level 1 Member
  • Group: Members
Posted 06 November 2009 - 05:08 AM
Yeah mine said 26 as well.
Idk, I'll reset it once I refuel, and I'll let you know how it goes once I get down there.
0
Fast Reply
