Adhesive Wheel Weights
Posted 06 November 2009 - 07:56 PM
'00 S40 1.8t - summer green/gray leather - 97,000 miles.
Posted 06 November 2009 - 08:03 PM
I have personally never noticed a difference in ride between the two different types of weights
the stick on weights work fine, and should NOT cost more money
be sure to request the stick on ones as if you don't you'll wind up with the hammer on type
Posted 06 November 2009 - 08:05 PM
The sticky weights are more likely to go out of balance than the clip on weights. When you drive you heat up the wheels and the adhesive also heats up and thus can more easily loosen. It is also a little more of a challenge to balance some times. Never the less I still use the sticky weights on all my wheels. When you buy your tires make sure they include a lifetime balance this is good for both sticky weights and clip on weights.
You can also cheat and do whats called static balance. What this is supposed to do is place one sticky weight on the middle of the barrel. Instead of one weight on either edge. I consider cheating using this balance setting but putting a clip on weight on the back edge.
Whatever balance you choose make sure the operator has it set to that setting. The balance's are slightly different. It should not cost more at all. If you have large spoked wheels like pegs or titans you can actually hide the weights behind the spokes if the operator is experienced.
When you go to get these weights CLEAN your wheels very very well. You do not want some tire monkey dragging your rim out placing it face down on the concrete and cleaning it himself. The weight will not stick to anything but clean metal so it must be clean. Brake build up sucks,and usually in this case I will just use a wire wheel to clean a inch ring all around the barrel.
Posted 08 November 2009 - 06:16 AM
S70 T-5R
FMIC | Koni Sport & Kilen | LOLtune | 302JV Brake Kit | OBX(TBA)Magnaflow Catback | Gold Canistos | 6K Projector lows, 4.3k Fogs | T-5R Two-Tone interior | Red LED swap
LED's for X70's
Posted 08 November 2009 - 08:03 AM
T5Power, on 08 November 2009 - 06:16 AM, said:
False I would still smack a hammer on weight if you brought it to me. If you asked then obviously I'd do it then. Point is they are tire monkeys and will do anything as easy as they can. sticky weights take twice the time if you do it right 50% more if you half ass it.
Posted 08 November 2009 - 09:24 AM
Posted 08 November 2009 - 09:33 AM
tomcat, on 08 November 2009 - 09:24 AM, said:
If your paint peeled because of a sticky weight you didn't prep right. Did you want that monkey to not balance your wheel? If you painted them right then you wouldn't have a problem...I seriously hate when I spend an hour mounting someones tires and they try to blame their laziness on me. I cant even count the number of customers who blame curb rash on me. But when I point out that all my tools are plastic they STFU.
I've refinished plenty of wheels if you dont do it right sure its a PIA to do it right but in the end its worth it.
Posted 08 November 2009 - 01:53 PM
You can dynamic balance to the inside, not just static. If you are really that anal just get a dynamic on car balance. If you just want the best looks tell who ever balances your tires to balance to the inside and you will not even see wheel weights.
Volvospeed On Google+
Posted 09 November 2009 - 04:54 AM
MN CREW | T.A.P.
1998 SAFFRON V70 R | 1998 Black V70
Former Rides:
Have I Mentioned Recently that I despise Best Buy?!?
Posted 09 November 2009 - 09:03 AM
Che'_Moderator, on 08 November 2009 - 01:53 PM, said:
Thats what I said I considered cheating its not the best balance but it will work and it gives you the look you want. FYI alot of VW wheels don't have the back lip to do this.
Posted 09 November 2009 - 10:16 AM
No, they where prepped right, they just were not baked afterwards (did them at home) 2k paint is still quite soft for a good few months after spraying, he was told this and still went at it like a bull in a china shop. Moreover if the monkey fitting the tyres hadn't put one on back to bloody front then there wouldn't have been a problem, the rest turned out fine. I too have refurbed many wheels and I've been spraying for years so I certainly know what I'm doing.
Posted 12 November 2009 - 10:04 PM
Posted 13 November 2009 - 01:30 AM
the commissar!, on 12 November 2009 - 10:04 PM, said:
Not that I have heard. Most likely the wheels weren't cleaned properly. The sticky weights stick on like crazy if the wheel is clean.
#14
Posted 13 November 2009 - 02:01 AM
I've definitely had bad luck trying to use the wrong type of hammer-on weights.
if applied to a clean section of rim, a sticky weight will never fly off.
#15
Posted 13 November 2009 - 03:45 AM
We use them in racing with no problems. Centrifugal force alone will hold them on if they are applied correctly. Valve stems on the other hand will rip out if not supported.
#16
Posted 13 November 2009 - 06:01 PM
Black Betty, on 13 November 2009 - 01:30 AM, said:
I was trying to say the sticky part stuck to the wheel and the weight came off the sticky part...the sticky part is still well hung to the wheel and the weight is nowhere to be found.
#17
Posted 15 November 2009 - 12:44 PM
the commissar!, on 13 November 2009 - 06:01 PM, said:
wow. those are garbage weights...
