Bov Vs Hd Cbv?
18 replies to this topic
#1 z31jaime
  • 939 posts
Posted 07 November 2009 - 09:33 PM
ok from what i understand they both do the same thing.....
so which is better? i know the BOV gives you that cool WOOSH sound....but its almost 2x the money as an HD CBV.
is there any real performance gain for the BOV vs the CBV? I'm gonna be rebuilding my turbo and want to know what would be my best option. if its just a sound issue i guess ill go with the CBV cause i already have a cone filter and the WOOSH sound.
now if the BOV has some kind of performance added to it i might consider it.
car is a 95 850 wagon
plans for it...if they matter.
turbo rebuild with porting
tune
3"dp (already has 2.5" catback)
MBC
#2 Chilled Man
    MILFSPEED
  • 29,896 posts
  • Gender:Not Telling
Posted 07 November 2009 - 09:35 PM
sound
#3 Iloveboost
  • 510 posts
Posted 07 November 2009 - 09:36 PM
^ +1 sound is the only difference. There is a thread on this on the posted threads in the performance section.
Underhill, VT 2002 S60 T5 5 speed. 2000 Honda CBR 929RR
#4 z31jaime
  • 939 posts
Posted 07 November 2009 - 09:55 PM
ok well from what i see, reading that post (thanks)
the BOV seems to be a more solid part not as prone to breakage. my current CBV has a small hole in it.
can anyone tell me if they have had issue with the HD CBV and what PSI its running?
i seen the kits IPD sells i think had a 20psi+ spring? so im guessing i should be fine with just my cbv replaced?
my worries is that i will replace the CBV and then it will break and then i will have to replace it again which will be = to buying 1 bov kit.
#5 Iloveboost
  • 510 posts
Posted 07 November 2009 - 10:08 PM
The HD CBV will handle any PSI your car is going to put out. Not sure quite how the springs work but i believe there is 3. Maybe someone else can chime in but i know you cant just put in the stiffest spring or it will restrict boost i believe.
#6 magicaljake
  • 4,450 posts
  • Interests:woman, booze, karaoke, volvos, fresh nikes,
Posted 07 November 2009 - 11:24 PM
+1 to bov sound!!
woooooo---psh!!
long live vanessa 2.0!
#7 Iloveboost
  • 510 posts
Posted 07 November 2009 - 11:36 PM
View Postmagicaljake, on 07 November 2009 - 11:24 PM, said:
+1 to bov sound!!
woooooo---psh!!
lol jake, i take it your liking yours?
#8 TryingBe
  • 345 posts
Posted 07 November 2009 - 11:46 PM
If you worry about CBV breaking, get the BOV and be done with.
#9 z31jaime
  • 939 posts
Posted 08 November 2009 - 12:03 AM
well thats what im asking...should i be worried about it....?
#10 ozzimark
  • 4,294 posts
Posted 08 November 2009 - 12:10 AM
IMO, no. I'd only go with a recirculating BOV if I went to a new turbo that didn't have the CBV built in like the stock mitsus.
#11 pwebb
  • 707 posts
Posted 08 November 2009 - 12:32 AM
the stock CBV is recirculating. if you want a BOV, keep it recirculated.
94 854 turbo - 160k - red on black
#12 Naughty33W
  • 1,646 posts
  • Interests:workin on my S60 and getting a divorce
Posted 08 November 2009 - 02:51 AM
+1 ----- best answer
you dont have to have a bov vent to atmosphere (the air) - you can have it setup to pipe the air back in just like a cbv (or do both) - except the bov is more durable and less prone to failure (unless you get an ebay cheapo - then its hit or miss) then the cbv
but keep in mind that a bov thats venting to atmosphere is releasing metered air - the car has already added fuel in relation to that measured amount of air and will therefor get real rich for a second when the bov vents - cranking it up to redline then taking your foot off the gas might result in an overly rich condition and cause a stall - however flooring it through the gears works just fine ;) , lol
2003 Volvo S60 2.4T --- Favorite VS quote - "28 psi boost spike = ... fu** me lol" - by: 83' Turbo
18x8" OZ Wheels in Black , Gutted Interior , Smoked Windows , And Yes ... Hood Pins ...
Engine Build: 16T + Garrett WGA + Mishimoto FMIC + 3" Catless (Meow) TurboBack Exhaust + Tweaked ST 17psi Tune
#13 cheapwagon
  • 2,180 posts
  • Interests:LED Retro's
    VolvoSpeed
    Long walks on the beach
  • Crew:ECC
Posted 08 November 2009 - 04:05 AM
Just get an open intake style air cleaner setup ... you can hear the CBV just fine. Not as load as a BOV but is still can be heard.
I like beer.
#14 ryan850-t5
  • 1,055 posts
Posted 08 November 2009 - 05:51 AM
Where do you recirculate the air back in?
Ryan
'97 854 T5
Garage
#15 HeavyIron
  • 568 posts
Posted 08 November 2009 - 05:54 AM
With IPD's Short ram intake my CBV is bordering on retarded loud. BOV's take the retardation to a ricer level. <_<
1998 S70 T5 SE SC901 Dynaudio,Dolby Pro, IPD sways & HD endlinks, Koni Yellows, H&R springs, BBS Tritons, IPD upper engine mount and lower tranny brace, QBM firewall mount, 302mm brake conversion, SS brake lines, Zimmerman cross drilled F & R, IPD cold air intake, MSD 6AL Ignition box, MTE 25psi tune, IPD intercooler, RIP kit, Built engine, 19T, Custom Forge WG actuator w/18lb spring and other good stuff
XS Energy Click the link to the left for the best energy drinks on the market.
#16 z31jaime
  • 939 posts
Posted 08 November 2009 - 06:09 AM
sorry forgot to add already have the cone filter deal, so i know how loud the CBV is. thats why im going back and forth between it and the BOV, other than the whistle some of them make i wasn't understanding the point on spending $195 on a BOV kit when a $60 CBV seems to work the same. i know about the venting to atmosphere and the fuel mix thats also why i was not understanding the BOV thing. your going to mess with your air/fuel just for a cool sound??????????
i guess i was over thinking...i kept saying there had to be a reason other than sound that people went with BOV. i guess not.
#17 pwebb
  • 707 posts
Posted 08 November 2009 - 01:08 PM
between the MAF and the turbo inlet.
http://www.1st-racin...m/bov/bov_1.gif
#18 Naughty33W
  • 1,646 posts
Posted 08 November 2009 - 05:29 PM
its sound plus durability - not to mention that with the right bov it can handle 10psi , 20psi , 30psi and up - even if they make a cbv that can handle 30psi+ i would pick the bov of the two options strictly for duribility reasons - its up to you bro - but if you want the bov but DONT want the whoosh you can always port and polish the exhaust port on the bov and then vent it somewhere where the sound wont be as noticable (only works on bovs with the little horns for venting)
personally - once my boost levels break 15psi on my S60 , i'll be swapping to a bov (prolly a forge)
#19 ryan850-t5
  • 1,055 posts
Posted 08 November 2009 - 08:49 PM
thanks pwebb
Ryan
'97 854 T5
Garage
IPD
