Mbc
25 replies to this topic
#1 z31jaime
  • 939 posts
Posted 08 November 2009 - 07:39 AM
ok well im going to be starting my Turbo rebuild. and first on my list is the MBC. i see them @ all prices. from the wright up i seen on how to make your own they all seem to be more or less the same idea....so im wondering should i just get whatever is cheap or is there a reason to get a high end one?
most specifically i was looking @ this....
http://cgi.ebay.com/...sQ5fAccessories
it seems to be all over ebay and gets good reviews from all the buyers i have seen.
#2 L8 APEKS
  • 760 posts
  • Interests:I LIKE TO RIP PEOPLE OFF.
    http://volvospeed.com/vs_forum/index.php/topic/135080-wheres-l8-apeks/
  • Crew:LBC
Posted 08 November 2009 - 08:25 AM
Hallman Pro.
I can't tell you how many people I read about on forums who just had to go ghetto cheap on a boost controller (but they'll spend $1000 on bling bling rims), and all the while they complain about boost spikes. Splurge the $65 or so on a decent controller.
I spend $120 on trans fluid - what's so bad about $65!?
#3 z31jaime
  • 939 posts
Posted 08 November 2009 - 09:00 AM
also just to add.....would and "in cabin MBC" be prone to more boost spike? i understand that it would be extending the vac lines....and i would assume as such would take a little longer to respond......
#4 mrbrightside2009
    I eat rice for breakfast
  • 1,144 posts
Posted 08 November 2009 - 09:06 AM
i had this boost controller, its retarded because it is two pieces, i don't know if it would take longer to boost, i just felt it was very cheap, i then went with the nxs boost controller, one piece, but its under the hood, feels stronger though, also probably has a bigger spring. its around $20 and has great reviews.
what do you have a glt or t5?
1998 s70 glt t5 converted - 16t, t5 ecu, white injectors, nxs mbc @ 11psi, cone filter, magnaflow muffler, 3in. DP, high flow cat, full 3in. exhaust, hd wg, na tb, ipd turbo hoses, 6000k hids, black mesh grille, columba wheels, glowshift boost gauge, white interior leds, stage 0 complete
#5 z31jaime
  • 939 posts
Posted 08 November 2009 - 09:24 AM
t5.
my only issue is i really want something i can do IN CABIN. i know some of you guys will think its stupid but thats what i want to do. sooooo if i can do NXS and just extend the lines that would be what im looking for...suggestions on what to use.
#6 L8 APEKS
  • 760 posts
  • Crew:LBC
Posted 08 November 2009 - 09:29 AM
I would only do an EBC for in-cabin; but I've never had a car where I've adjusted boost enough to really need it in the cabin. I only raised the boost when I went to the track. Yes, the longer the vac lines, the higher chance of spikes.
#7 mrbrightside2009
  • 1,144 posts
Posted 08 November 2009 - 09:31 AM
View Postz31jaime, on 08 November 2009 - 09:24 AM, said:
t5.
yea you could just do longer vac lines into the car
just make sure you do stage zero and make sure the wastegate rod is extended before adding a mbc, otherwise you may have problems with it hesitating under boost.
#8 Black Betty
  • 6,899 posts
Posted 08 November 2009 - 09:38 AM
If you want in Cabin go with an EBC other wise get a GOOD mbc. The link you posted can't even spell properly I mean come on what do you think their customer service is like? Spend some extra $ and get a good one. Your car is not something you cheap out with...especially the engine. If it was something small and insignificant sure go cheap, but boost spikes are bad...
Here's my advice get a 2 stg mbc they are around 150 all you do is set a low stage and a high stage. At a flip of a switch you can change it and then you can change the pressure in the cabin. Most likely you'll want two settings one low and one high. Then you'll be able to change it from the cabin and it will still look decent in the cabin.
#9 Pops Racer
    Old Man Crew Leader
  • 4,686 posts
  • Interests:Playing my violin around fires
Posted 08 November 2009 - 02:26 PM
Hallman Pro RX, they have an in cabin kit.
$17.95? Get what you pay for. 3bar racing/ Dawes device would be my "cheap" choice.
"Property is the fruit of labor...property is desirable...is a positive good in the world. That some should be rich shows that others may become rich, and hence is just encouragement to industry and enterprise. Let not him who is houseless pull down the house of another; but let him labor diligently and build one for himself, thus by example assuring that his own shall be safe from violence when built." - Abe Lincoln
#10 z31jaime
  • 939 posts
Posted 08 November 2009 - 04:49 PM
ok maybe im retarded?????????????????????????????????????????
internally they should all be the same....ball, spring, screw that adjust spring........yes or no?
i see the point of different springs and ball combination's.... but i still don't see the point in spending almost $200 for 1 MBC vs a $20 mbc. IF they are the same internally then im spending a bunch of money on the name brand?
#11 gilber33
  • 9,391 posts
  • Interests:you
Posted 08 November 2009 - 05:06 PM
http://www.streetuni...intercooler.htm
Same in-cabin mbc as the the one in the link you posted except it has a turbosmart sticker on it, and it's only 130 dollars more.
94 850 T5M - RICA Stage III - 19T - I like boobies
PM me for "Gabe Approved" pricing quotes today!
#12 7 VII 7
  • 22,322 posts
Posted 08 November 2009 - 05:10 PM
www.3barracing.com
Hybrid for under $60... great stuff!
sorry but maybe I did not see it but what car is this going in?
1 of 1 - '97 427 854R - 105k
#13 z31jaime
  • 939 posts
Posted 08 November 2009 - 06:02 PM
linky no work.
View Post7 VII 7, on 08 November 2009 - 05:10 PM, said:
www.3barracing.com
95 850 t5.
you gotta be kidding me? i could build the same one they sell for under $10 @ home depot.
#14 gilber33
  • 9,391 posts
  • Interests:you
Posted 08 November 2009 - 06:07 PM
Try that one? I'm copying and pasting it. Weird, maybe it's a sketch site or something. Anyways, exact same one that was in your link, but has turbosmart sticker on the side. They're all probably coming from the same place, kinda makes me question the quality of it.
That one doesn't work either. I suck.
streetunit.com
4th one down in the MBC section. Directions are just as good as links. :lol:
#15 Pops Racer
    Old Man Crew Leader
  • 4,686 posts
Posted 08 November 2009 - 06:09 PM
View Postz31jaime, on 08 November 2009 - 06:02 PM, said:
linky no work.
95 850 t5.
Hey, then there's your answer. Do it. $10 MBC is yours.
#16 7 VII 7
  • 22,322 posts
Posted 08 November 2009 - 06:16 PM
hahaha... I was waiting for that
Please close thread!
#17 z31jaime
  • 939 posts
Posted 08 November 2009 - 06:18 PM
streetunit.com
nice find! your right it is identical. so the question is are they just making a $100+ profit on the cheapo ebay ones, or are they really that good?
#18 L8 APEKS
  • 760 posts
  • Crew:LBC
Posted 08 November 2009 - 06:27 PM
I've seen the answer to that personally on friend's cars a couple of times. That's why I would never use a "Home Depot" controller.
Time for you to roll the dice trying to save ~50 bucks and find out for yourself! That $50 bucks won't go very far replacing a HG or a rod though.
Good luck!
PS...I don't think they are making $100+ profit on a $60 to $79 item, unless they found a way to bend the space-time continuum or something. :P
#19 z31jaime
  • 939 posts
Posted 08 November 2009 - 06:39 PM
Good luck!
ummmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm i have no idea what your talking about. streetunit.com is selling for $140 a MBC that on ebay is selling for $20 shipped. so thats well over a $100 profit.
everyone seems to say get the more expensive ones but no one yet has explained why. i understand that extending the line might cause me to spike so im going to consider a normal mbc, that being said i dont really see whats the difference between.....
this...
this
this
or this
other than the way you adjust the boost, they all seem to have the same design. so someone please explain to me why one is inferior to the other? thats what i want to know.
k thanks bye
#20 gilber33
  • 9,391 posts
  • Interests:you
Posted 08 November 2009 - 07:37 PM
I say get a cheap one find out if there is a difference. I really like that last one there. It seems like you can get the convenience of an in cabin MBC with out the supposed boost spikes.
IPD
