Dsm Bov On A Volvo?
16 replies to this topic
#1 z31jaime
  • 940 posts
Posted 09 November 2009 - 04:19 AM
ok well i have been thinking about doing a BOV vs hd CBV in my last few threads. well i started looking in my box of parts and i found an old BOV from a 1g eclipse i remember i got it to but on my 98 eclipse and ended up selling the car and never used it. its use from a junk yard and i think they crushed (dsm cheap mod) but i see sti's and other cause using this so im guessing for a volvo it would be just a matter of adding the flange on the pipe?
#2 sacrifice
  • 805 posts
Posted 09 November 2009 - 05:18 AM
i hear of people using 1g eclispe bovs on a bunch of different cars, what makes a volvo different?
#3 magicaljake
  • 4,451 posts
  • Interests:woman, booze, karaoke, volvos, fresh nikes,
Posted 09 November 2009 - 05:42 AM
and you need to blank off the stock CBV on the turbo itself...
long live vanessa 2.0!
#4 z31jaime
  • 940 posts
Posted 09 November 2009 - 05:44 AM
yea i know thats not hard. i was just wondering about maybe the spring rate being different? you know but ill figure it out. hey its free.
#5 Dave 54
    Old Man Crew Pledge
  • 4,902 posts
Posted 09 November 2009 - 12:06 PM
You'll need to have a flange welded onto the pipe for it to work. Should work just fine though, reason the 2nd gens upgraded to the 1st gen is cause the 2nd gen housings were made from plastic. And the mod they do is to take a punch and slightly "crush" the top, I ran a Greddy BOV on my DSM, but my friend is still running his stock BOV on his DSM with 20psi and hasn't had to do the crush mod yet.
DAVE
96' 850R
#6 dongle
  • 2,147 posts
  • Gender:Not Telling
  • Interests:Being Awesome.
Posted 09 November 2009 - 04:51 PM
We seem to be overlooking the fact that w/o plumbing it back in(post maf) the valve will be open under vac and the car will stall.
#7 Dave 54
    Old Man Crew Pledge
  • 4,902 posts
Posted 09 November 2009 - 05:26 PM
DSM's are plumbed back in post MAF!!!
DAVE
96' 850R
#8 dongle
  • 2,147 posts
Posted 09 November 2009 - 06:17 PM
Well, I don't think were modding DSM's. So, the point I'm trying to make is:
It is not as easy as just adding a blanking plate and welding a flange. He will have to either mod the intake tube or fab one with a 25mm inlet to recirc the charge OR... It will vent to atmosphere under vaccuum and the car will stall.
#9 Dave 54
    Old Man Crew Pledge
  • 4,902 posts
Posted 09 November 2009 - 09:22 PM
Really, then why did the Forge that I had in which does not recirc. back work fine? Just wondering here.
DAVE
96' 850R
#10 mikus
  • 147 posts
  • Interests:FAP FAP FAP
  • Crew:ECC
Posted 09 November 2009 - 09:53 PM
ok I try to leave this topic alone, because you guys sure seem to love BOV's and it doesn't stall up your car like it does on others with pullthrough MAF's - but:
- post-MAF air is metered, and
- losing air after the MAF and before combustion changes your A/F, thus
- venting BOV to atmosphere after MAF is fail. (pppppsssshhhhtfail)
DSM's and Volvos both require recirculation to maintain an accurate A/F ratio. Just because your car can run with a BOV doesn't mean it's right. You can piss in your master cylinder and your brakes will still stop your car.
Soapbox aside - a 1G DSM BOV will work good as any, and they're well made. Their design allows them to 'push' open though, and this typically happens ±18psi. You can check it with a boost leak test, some do hold out higher than that. The "dodge garage" mod will correct this as well, google it.
98 V70 GLT • 16T on R ecu • MBC to 12psi
#11 Naughty33W
  • 1,646 posts
  • Interests:workin on my S60 and getting a divorce
Posted 09 November 2009 - 09:57 PM
i'd recomend an adjustable bov , that way as you mod ur car and tune you can adjust the vent psi accordingly
2003 Volvo S60 2.4T --- Favorite VS quote - "28 psi boost spike = ... fu** me lol" - by: 83' Turbo
18x8" OZ Wheels in Black , Gutted Interior , Smoked Windows , And Yes ... Hood Pins ...
Engine Build: 16T + Garrett WGA + Mishimoto FMIC + 3" Catless (Meow) TurboBack Exhaust + Tweaked ST 17psi Tune
#12 TyConn
    Delta Bravo
  • 816 posts
  • Interests:Wings 'n Things
Posted 09 November 2009 - 11:27 PM
+1
actually +200 if i could
so true, and it made me lol
1998 V70 T5 M
1994 854M Silver on Black
1998 Black on Black S70T5
1998 S70 GLT
1990 245 DL M47
...RIP at 320K
#13 Man_Love
    LongBeach
  • 17 posts
Posted 10 November 2009 - 01:04 AM
I have a ghetto HKS type BOV thats not Recirc on my 855 with 19t and it runs like a champ...I have never stalled my 855
<- longbeach
#14 dongle
  • 2,147 posts
Posted 10 November 2009 - 05:24 PM
Do you have the DV004? You probably do as it's the one that everyone around here gets.
The DV004 is a dual piston valve. It has one that clamps shut even under vac to prevent metered/unmetered air from leaking.
The sequential valves are designed the same way. This is why they say "FOR CARS WITH MAF/MAS" in the description. :rolleyes:
Fuck it. Vent to atmosphere on a MAF car.
#15 WayAway
  • 1,145 posts
  • Interests:Bewst, Beer, Women, Towers
Posted 12 November 2009 - 11:45 PM
Im about to do this same thing on my 850r, with a greddy type s. it seems there are arguments back and forth with this stalling subject. i have heard of alot of people running full atmospheric bov on these cars and not have problems. well either way im gonna install it tommorow and see how she goes from there...
96 854R Black IPDStage III, Winter (M56, 99T5 motor, 18T) 19psi, Whites, OBX, Eibach springs, SSQV, Exhaust Cutout, Aem UGO, 17" Peggs etc...
98 V70R Saffon FWD, Porsche BBK, RICA 18psi tune, Sconeman intake pipe, Mufflers Delete,IPD springs, CX Racing FMIC, Hillman MBC @ 18psi, VR Charcoal Swap, Cai, Gready Type S, Projectors, 18" Peggs
#16 z31jaime
  • 940 posts
Posted 13 November 2009 - 02:50 AM
ok well i just went with my CBV and skipped the entire modding pipes and what not.
#17 WayAway
  • 1,145 posts
Posted 13 November 2009 - 07:25 PM
cutting the pipes isnt too bad. just make correct measurements, and get silicone couplers, and your good to go
IPD
