Drive By Cable Retrofit
Posted 11 November 2009 - 02:28 PM
2000 V70XC (converted to fwd)
1988 Schwinn Traveler
Posted 11 November 2009 - 02:48 PM
I think it would be a good amount of work, and possibly needing an ECU retune. You wouldn't be able to use cruise control, and the ECU that wants to control the throttle couldn't, causing error codes and a bunch of potential problems. And there is the entire mounting issue. The drive by cable has the throttle mounted in a different area, so you might need to swap the entire intake manifold. The actual pedal stuff wouldn't be as hard, simply swap it in.
Just my thoughts on the subject.
1999 C70 2.4 LPT Convertible
19T, 0.5 bar actuator, 3" turbo back exhaust, InMotion tune, fmic with 2.5" piping, ME7 NA intake manifold, snabb IM spacer, ebay BOV, catch can, japanifold exhaust, EBC, weitec lowering springs, euro plate, no cat, single dual output muffler, e-code headlights, dual transmission coolers, polyurethane mounts, front strut bar, Innovate wideband
Posted 11 November 2009 - 03:10 PM
New ECU, they are completely different between 98-99
New Engine wiring harness
New Body Wiring harness
Intake manifold
t-body
Intake plumbing
Gas pedal
Throttle cable
That's all I can think of right now. But to answer your question, sure it's possible but how much time and money are you going to spend before you realize it would have been easier to buy a new car.
Sonic Shenanigans
Posted 11 November 2009 - 03:59 PM
Intake manifold
t-body
Intake plumbing
Gas pedal
Throttle cable
Posted 11 November 2009 - 04:16 PM
I've only done one and here's what it took and what I found;
Parts:
Intake manifold w/throttle body
Accelerator cable
Gas pedal
Intercooler piping from intercooler to Tbody
Associated gaskets and some tubing
What it takes:
Install all the components, leave ETM connected and relocated somewhere in engine bay. You'll also need to connect the POT box from the orignal 'gas pedal' to the new gas pedal so ETM/ECM/TCM still gets an input.
What you give up:
No cruise control, No tracs control (also means you can smoke the tires all you like so maybe not such an issue).
Under normal driving it works find and you don't even notice there is a difference with the exception of better throttle response however if you start getting into throttle and the ECU or Tracs tries to pull some throttle back (to prevent wheel slip) and sees it isn't happening you will get a CEL. Also helps if you have a stage upgrade with torque limiting removed (Prevents power pull back via ETM from early torque development).
So not the best solution, but I'm paid to try this stuff out so I thought I'd share my findings...
Posted 12 November 2009 - 12:06 AM
Sonic Shenanigans
Posted 12 November 2009 - 12:07 AM
Posted 12 November 2009 - 12:11 AM
The bigger issue here for me is that these cars are can be had pretty inexpensively now, so unless you have a free (or close to it) donor car it dosen't make much sense. Ohh and you save yourself lots of work
Posted 12 November 2009 - 12:28 AM
Posted 14 November 2009 - 12:55 AM
