Tryin To Finsih The Build But Need Some Ideas
21 replies to this topic
#1 cr854r
  • 894 posts
  • Interests:Club Racing, Auto X, Volvo
Posted 11 November 2009 - 05:27 PM
Ok so im goin to try to finish my build by the end of next summer, but need to know what else to do to make it the best track car it can be (reasonably) engine performancewys i think im set i dont really want any more power than i have, but should i still build the motor (rods/pistons) to be safer?... i kno i still need to add a bit more to the cage, an get a steering wheel.
but what should i do mostly suspensionwys... I have kw v2 coilovers an qbm endlinks already.. look at my sig to see what is already done with it.... Here we go.
solid motor mounts? (what are the downsides?)
Sway bars? where to get like a 28mm (can it be made?)
tyres (what should i go with?)
Brakes (do i really have to spend 3k on the brembos or will the 800 dollar wilwoods be ok?)
Aerodynamics, with my care fully gutted the a$$ end is really light an josh said i will need a wing (what kind should i go with?)
and what else should i do if i wanted to have this fully built?
thanks so James
Projekt R
-Megasquirt
, 18t, 3in turbo back, kw v2 coilovers, M56H, fmic, 16 point roll cage, corbeau seat/harness, gutted to hell, *solid bushings, *F/R sways, walbro 255, 450cc injectors, NA cams, willwood brakes, port/polished head, *rsi rods, *R mani, adjustable control arms, adjustable strut top mounts, adjustable sway bar links... etc etc
#2 7 VII 7
  • 22,324 posts
Posted 11 November 2009 - 05:31 PM
Do you have a EBC yet?
1 of 1 - '97 427 854R - 105k
#3 ErikS
    99.9%
  • 4,918 posts
Posted 11 November 2009 - 05:34 PM
I don't think you want willwoods for the track, street yes, track no.
1995 854 T5M Click for Mods
2005 S60 2.5 T
2010 XC60 T6 AWD
#4 Jaxx
    Sandy Orangina
  • 9,065 posts
  • Interests:big red bricks
Do you want to run street tires or not?
Nadine | ME7 S70 T5 601
#5 cr854r
  • 894 posts
Posted 11 November 2009 - 05:37 PM
I dont have an ebc yet, should i get it? (why) controll spikes?
So do i have to go with the brembos probably?
No i dont plan on running street tyres, although i have been doin research on track tyres and am in between Dunlap and Nittos or am i wrong.
Projekt R
-Megasquirt
#6 Hanks
  • 3,272 posts
Posted 11 November 2009 - 05:42 PM
Dont go WW!
My brembo BBK front was 500$ for the calipers 150$ for the adapters, 90$ for the pads 120$ for the rotors
so front was 860$ total
the rears i got the calipers for 300$ the rear adapters are ~140 iirc and you will need pads and rotors... havent finished up the rear yet.
but total is def less than 3k ;) more like 1500$ for a complete Brembo setup.
PM Gary about china fronts... he may have a connection.
#7 Jaxx
    Sandy Orangina
  • 9,065 posts
Posted 11 November 2009 - 05:45 PM
As I understand Toyo R888s are pretty much the standard competition R Compound, which I believe they run in spec Miata and spec E30. The R888 line has a very large range of tire sizes.
#8 shanehutton
  • 947 posts
Posted 11 November 2009 - 06:22 PM
You really need to look at the rules for the class you want to run in to make sure they don't have issues with various mods.
Tires - You will probably want to go with an R compound. The R888 is not great and they are bringing back the RA1 so if you have time to wait then I would do that. If you MUST go with street tires then look at the RE-11 as it seems to be the best of the uber streets. Keep in mind, we don't have much room for wide tires so it is pretty easy to overheat streets. Try to put them on the lightest wheel you can find while you are at it.
Brakes - The most important factor is pads. With a stripped out car even a 302 set-up with a legit track pad will do well. In fact, it will be far better than a set of brembos with street pads. Good track pads will be a couple of hundred dollars a set but they will take the heat and last FAR longer than street pads will. As for the Brembo vs. Willwood debate, I would go with the option that has the cheapest track pads available. If you really want the best set-up then look for a 2 piece rotor as that will probably give you a bigger benefit than more expensive callipers.
Other - Look into solid subframe mounts before solid engine mounts. Keep your eyes peeled as some of us are looking into Derlin ones from Europe and keeping our eyes peeled for other options. You should also make sure that the rest of the rubber bits are in great shape (don't forget the rubber in the rear arms).
'00 S70 SE (slow/sold)
#9 dublin14
  • 2,519 posts
  • Interests:Track events in NASA/ProAutoSports and dumping money into old Vulva. And one of the VS mods on here put that comment above. Dam kids these days lol
Posted 11 November 2009 - 06:28 PM
View PostHanks, on 11 November 2009 - 05:42 PM, said:
Dont go WW!
Can still use the E-brake with the Brembo rears?
#10 Hanks
  • 3,272 posts
Posted 11 November 2009 - 07:00 PM
the ebrake is a completely separate system than the actual brakes...it does not use the calipers. fyi, you should not be using the ebrake while driving.
#11 socal850tuner
  • 1,238 posts
  • Interests:cars....
  • Crew:SCC
Posted 11 November 2009 - 08:33 PM
Poly bushing in the front control arms and subframe will be a major improvement along with upgraded sway bars. As for brakes, a 2 piece rotor and track pads will help the most (as previously stated). This does not mean you won't feel a improvement with better calipers but the pads and rotors will provide more braking then just calipers. For keeping the rear end planted try softer settings for your KW's in the rear. with a rear wing you will probably need to support it with bracing the trunk lid to get the full effect of the downforce. Other then that a serious tire will be the biggest improvement all around
'97 850 T5; K&N cone filter, IPD Sway Bars, Powerslot Slotted Discs, Strut Brace, IPD Poly upper engine mount, Voodoo mbc, MSD Blaster SS, Magnecor Spark plug Wires, Autometer Boost gauge on A-pillar, Pioneer Head unit, pioneer 5 1/4" up front and pioneer 6"x9" in the back, Rockford 450w amp, ~600 MTX 10" Sub, pioneer back door speakers, and 3.5"clarions in the dash
projects: Porsche 2.8 race, Porsche 2.0 race(complete), Porsche 3.2 street (complete), Porsche 3.4TT street(complete), Porsche 3.0 street (complete), Porsche 3L twin-plugged carbed street rocket(complete)
2K Motorsports
#12 7 VII 7
  • 22,324 posts
Posted 11 November 2009 - 08:43 PM
EBC will make your pants tighter
#13 EricF
    tbricks spy
  • 4,159 posts
  • Crew:LBC
Modify an oil pan with better baffling and/or trapdoors and/or more capacity...
Oil level being even a little low can result in oil pressure drops on hard left hand corners.
#14 gmsgltr
  • 3,228 posts
Posted 12 November 2009 - 05:25 AM
you ran a 12.9 @ 110mph!?!?!?!?
I must have missed that! Awesome
- Greg - 96 Red/Tan 855 R 96k miles -
#15 OniFactor
  • 482 posts
Posted 12 November 2009 - 05:48 AM
when you say track, do you mean drag car, or road course?
#16 Jaxx
    Sandy Orangina
  • 9,065 posts
Posted 12 November 2009 - 06:50 AM
turns, of the left and right variety.
#17 dublin14
  • 2,519 posts
Posted 12 November 2009 - 09:53 AM
lol why would i use the e brake when driving? I was just wondering is there any issiue with going to the Brembo Calipers/R rotos and being able to use the e-brake, the way its setup in stock form?
#18 cr854r
  • 894 posts
Posted 12 November 2009 - 01:48 PM
Dont go WW!
im sorry... whats garys username?
Projekt R
-Megasquirt
#19 7 VII 7
  • 22,324 posts
Posted 12 November 2009 - 01:49 PM
Yellow95
#20 gmsgltr
  • 3,228 posts
Posted 12 November 2009 - 06:19 PM
so......................
IPD
