This ECU was removed from a '95 850 Turbo. Last three digits of the part # are 072. $60 shipped CONUS.
850 Turbo Ecu (072)
Started by gotboost, Nov 12 2009 04:09 PM
Posted 12 November 2009 - 04:09 PM
1998 S70 T5 SE 5-speed: Angled flange 18T, RICA tune, 3" DP, 2.5" Exhaust, R Manifold, IPD HD TCV, MSD coil, Turboxs BOV, Eurosport Intake, 2.75" Sconeman MAF-turbo pipe, Stylin' Motors hoses, 850R clutch, Sconeman short shift kit, IPD 25/28mm Sways, IPD HD endlinks, H&R springs, Koni Yellows, IPD poly mounts, OMP Strut Brace, HID E-codes and HID fogs, E-code turn signals, XC70 grill, CF OEM valve cover, CF throttle cover, Polished intake manifold, UK-spec S70R cluster, '04+ V70R steering wheel, V70R seats, Blue LED dash lights, 302mm Zimmerman cross-drilled front rotors, Brembo cross-drilled/slotted rear rotors, IPD SS Brake lines, PBR Ultimate Ceramic brake pads F&R, Kevlar timing belt
And Now: 1998 V70XC: EST intake, EST RIP kit, MSD coil, Inmotion tune, IPD poly mounts, 17" Titans, 302mm brakes, E-codes, Hella 500s, V90 rear wiper.
Posted 13 November 2009 - 09:26 AM
heredity, on 13 November 2009 - 07:57 AM, said:
How much to have it chipped?
depends on where you send it, anywhere from $325-$1000 depending on what u want
96 850R autotradgic. Custom TD04 Billet turbo. ST custom tune. OBX. Japanifold. AEM ebc. MSD. Kingsbourne Wires. IPD Intake Spacer and SR5T. Bilsteins. B&G Springs. Forge BOV.
98 S70 GLT.
98 S70 GLT.
