2004+16T - $225
9 replies to this topic
#1 volvoluvin
  • 669 posts
  • Interests:Lots
Posted 14 November 2009 - 08:21 AM
SOLD
Unknown mileage
I bought it a year ago and put 10000kms on it
Pulled 248whp @16psi with various other mods on my 850
Very little shaft play, overall decent shape.
Was working fine before accident, no smoke.
Comes without cooling lines shown in picture
"Yarth" - 95 T5-R(m) - 18t,r-mani, 3" custom DP, EST 2.5 Cat back, IPD Stage III tune, MBC @ 17psi, RIP Kit, Sconeman Post Maf goodness, IPD plug wires, MSD ignition,IPD Short Ram intake, IPD Sways, Koni FSD's with Eibachs, 18" pegs, M56H with Quaife LSD and short shifter plate
#2 Spanky
    Has a boner for Adam's Dad
  • 1,533 posts
Posted 14 November 2009 - 11:12 AM
This is a good deal!! The turbine housing on this year should already be ported out from the factory in comparison to the older angled housings.
Contact me for turbos, turbo parts and rebuild kits
#3 AverageVolvo
  • 1,634 posts
  • Interests:Woman,Cars,Guns, Sex, Music.
    And making $$$ to fund the above.
Posted 15 November 2009 - 10:33 AM
If you look closely at the exhaust housing, the last number is 7 which indicates that it's a 7cm(larger ported outlet)
I have a 16t from a 04 s60 and it definitely came with the 7cm
This can be used for 850's etc... but you have to tap one hole and block another.
96 850 (412) wagon W/2 racing seats no rear seats, ..Converted to M56h with Quaife. R clutch,Kw v2 coilovers, qbm end links,Ipd sways,strut and shock braces/ Front/rear lower Ultra racing chassis braces. Team Dynamic 17in rims 17lbs .Poly mounts on trans, engine and firewall.Porsche Bbk, Ss lines, Super Blue Ate.5mm Spacers,Rolled Fenders,R Manifold, T04E 50 trim @18psi. Divorced WG and BOV ,3in Downpipe, gutted 3in cat,2.5 tme/Ipd catback Gizzmo Ebc, 1 gallon Aem progressive Meth Injection kit. Walbro 255. Na mani W /960 plate and Na Silicone Tb hose. Boost/egr/wideband gauges dash mounted. Double Din touchscreen Nav. 12in Fosgate p3 and 2 Alpine amps/ + Cf spoiler+ V70 stuff.
#4 volvoluvin
  • 669 posts
  • Interests:Lots
Posted 15 November 2009 - 04:57 PM
I was using this on my 850 as it currently is, no tapping required. It's ready to go on an 850, but you will have to modify your lines to fit.
Here is the thread that covers the swap - It was a bit of a pain at the time because we understood it to be a direct swap, but it wasn't as I said:
http://volvospeed.co...1
For those not wanting to read the entire post:
"oil feedline on the 16t would need to be swapped with the 15g one, and that driver side coolant line would have to be swapped from the 15g to the 16t and a longer rubber coolant line adopted, and have an 1" cut out of the steal portion of the feed in order for it to clear the engine mount...Also needed to bend the 16t's passenger side coolant line to meet up with the original location"
#5 Wajad
  • 0 posts
  • Interests:Family, friends, fishing and Volvo Cars.
Posted 15 November 2009 - 05:14 PM
Hi,
I would like to know if you will accept $200. for it, if so I will take it now. I will also want you to ship it to Scarborough Ontario M1X 1K3.
Thanks Wajad
View PostWajad, on 15 November 2009 - 05:13 PM, said:
Hi,
Thanks Wajad
#6 volvoluvin
  • 669 posts
  • Interests:Lots
Posted 15 November 2009 - 05:43 PM
$225usd is pretty low as it is, so that's what I'm looking for, but I'll do 225cdn for a fellow Canadian.
#7 Black Betty
  • 6,899 posts
Posted 15 November 2009 - 06:06 PM
This is a great deal. I sold my 16T for 250 usd.
#8 Wajad
  • 0 posts
Posted 15 November 2009 - 06:28 PM
Hi,
I would take it for the $225CDN. How can I make the payment
#9 volvoluvin
  • 669 posts
  • Interests:Lots
Posted 15 November 2009 - 06:46 PM
PM'd
#10 volvoluvin
  • 669 posts
  • Interests:Lots
Posted 21 November 2009 - 06:01 AM
Sold...
IPD
