Rica Tune = Huge Boost Leak And Low Power
27 replies to this topic
#1 L8 APEKS
  • 760 posts
  • Interests:I LIKE TO RIP PEOPLE OFF.
    http://volvospeed.com/vs_forum/index.php/topic/135080-wheres-l8-apeks/
  • Crew:LBC
Posted 16 November 2009 - 03:27 AM
Ok...borrowed a RICA 18psi tune from Aquitas to test it out.
My car was pretty strong in stock form - you could hear the "hissing" sound of boost pressure faintly on the driver's side of the car, but power was strong and consistent so I wasn't fully convinced it was a boost leak. I figured it was normal.
I installed the RICA tune, took it for a spin. At part throttle the first couple times, I'd get a strange whistling sound. Couldn't tell if it was wastegate flutter or something else. Then, I decided to try a WOT pull off the line. That faint "hissing" sound from the driver's side got 3x as loud, and it was then slower than stock.
It *almost* sounds like it's on my side of the firewall, behind the cluster - but that could just be my imagination? Is it common for the line to the "Turbo" gauge in the cluster to leak or pop off? And does anyone have a photo of where this line originates under the hood?
Any ideas on where to look first? I will post a video later tonight - so please check back and let me know what you think it might be.
Thanks!
#2 ryan850-t5
  • 1,055 posts
Posted 16 November 2009 - 03:38 AM
that's exactly what happened to me yesterday.
I had a vac/boost leak somewhere and found that 1) the boost line in the engine by was very brittle (its located underneath the throttle cable) and 2) right at my gauge the line had creased and created leak in the line.
what is your hg at?
Ryan
'97 854 T5
Garage
#3 lookforjoe
  • 7,812 posts
  • Interests:Making Stuff
Posted 16 November 2009 - 03:59 AM
Thanks!
Check the IC plumbing. Typical splits occur in the hose to TB - splits under IAC hose. Hose down by distributor/airbox inlet hose splits vertically. Either one can open up under boost, seal under vacuum. Mine didn't open until 10psi boost was reached. You may be experincing worse performance precisely because it can boost higher, and one of the hoses is opening even more than it did on your stock setup.
1998 V70 XR M66 10cm2Hotside/Garrett 60-1 Built T5 Motor '03 Ported Head EnemY21Cams TurboTuner 710cc Inj, DP back Dual Magnaflow 14834's May 2011 355WHP(@6400rpm) 347WTq(@4400rpm)@22psi Now with LGSpeed Header & Custom Intake Manifold! BIG 31x12x3"FMIC Currently sporting a vented piston!!!
#4 L8 APEKS
  • 760 posts
  • Crew:LBC
I would try sticking my finger into a vac port to measure my vacuum, but uh...I should probably just buy a gauge. :P
I have one sitting here, but it's digital...I either have to install a MAP sensor to run the gauge or just buy an analog and run that for the time being.
Going out to make the video now...be back in a bit.
#5 L8 APEKS
  • 760 posts
  • Crew:LBC
Posted 16 November 2009 - 05:35 AM
Link to video:
I'll check the boost hoses in the morning. Drives just fine when not under boost. <_<
#6 Wagoneer855
  • 3,185 posts
  • Crew:ECC
Posted 16 November 2009 - 05:56 AM
That sounds nasty.
Have fun with the troubleshooting.
'97 855 - Build in progress
#7 Aequitas_Veritas
    Blue Calipers&Balls
  • 7,586 posts
Posted 16 November 2009 - 05:58 AM
cant you rev it while someone looks for the leak under your hood? Typically they arnt very hard to find.
40+ mods and counting...
#8 Bah
  • 1,452 posts
  • Interests:Money, 850's, Computers, Women.
    Computer Engineering at University of Florida. Dig it
Posted 16 November 2009 - 06:08 AM
Thats about as much as i boost on my R...
Unforuntately i'm still stage 0'ing and upgrading at the same time lol...
Figure stock hoses with 130k+ are toast haha
I do not get that sound though...i just get normal turbo sound =p
1996 850 R - My Love, Suwanee
VS for life
#9 gotboost
  • 689 posts
Posted 16 November 2009 - 06:12 AM
Holy boost leak batman!
1998 S70 T5 SE 5-speed: Angled flange 18T, RICA tune, 3" DP, 2.5" Exhaust, R Manifold, IPD HD TCV, MSD coil, Turboxs BOV, Eurosport Intake, 2.75" Sconeman MAF-turbo pipe, Stylin' Motors hoses, 850R clutch, Sconeman short shift kit, IPD 25/28mm Sways, IPD HD endlinks, H&R springs, Koni Yellows, IPD poly mounts, OMP Strut Brace, HID E-codes and HID fogs, E-code turn signals, XC70 grill, CF OEM valve cover, CF throttle cover, Polished intake manifold, UK-spec S70R cluster, '04+ V70R steering wheel, V70R seats, Blue LED dash lights, 302mm Zimmerman cross-drilled front rotors, Brembo cross-drilled/slotted rear rotors, IPD SS Brake lines, PBR Ultimate Ceramic brake pads F&R, Kevlar timing belt
And Now: 1998 V70XC: EST intake, EST RIP kit, MSD coil, Inmotion tune, IPD poly mounts, 17" Titans, 302mm brakes, E-codes, Hella 500s, V90 rear wiper.
#10 ryan850-t5
  • 1,055 posts
Posted 16 November 2009 - 07:54 AM
well if its that loud i would suspect it would be in the cabin.
do you have an aftermarket gauge? I would check those connections first.
Ryan
'97 854 T5
Garage
#11 L8 APEKS
  • 760 posts
  • Crew:LBC
Posted 16 November 2009 - 08:23 AM
No gauge. I'll look behind the cluster first, then follow the line out and look under the hood. I have to replace the ODO gear anyway.
#12 Spanky
    Has a boner for Adam's Dad
  • 1,533 posts
Posted 16 November 2009 - 09:51 AM
Homemade boost leak tester
Can give you some ideas to test the whole system with pressure. I usually try to fart in one end right before I used compressed air, makes it a bit easier to find the leaks.
Contact me for turbos, turbo parts and rebuild kits
#13 washdup
  • 769 posts
  • Interests:Surf, swim, family.
    OMC
Posted 16 November 2009 - 03:00 PM
Did you try capping off at the vacuum tree the line leading to the boost gauge?
1998 V70 T5m
2004 V70R 6m--SOLD 9/29/08
#14 troyhyde
  • 973 posts
Posted 16 November 2009 - 03:06 PM
Might check the brake booster hose. It is situated fairly close to the driver and is the only thing that will leak that much boost.
Could be a loose or split hose right off the turbo. Thats a big leak, it won't be hard to find.
#15 dublin14
  • 2,519 posts
  • Interests:Track events in NASA/ProAutoSports and dumping money into old Vulva. And one of the VS mods on here put that comment above. Dam kids these days lol
Posted 16 November 2009 - 03:07 PM
If you have as leak, smoke test it!
#16 L8 APEKS
  • 760 posts
  • Crew:LBC
Posted 16 November 2009 - 05:34 PM
Thanks for the ideas guys.
I think I found my leak...the hose clamp on the turbo's outlet (turbo to upper IC pipe) wasn't even tightened down. The PO must have been driving this way for some time. Some things had been replaced in that area of the car; I guess they forgot to tighten that clamp.
My question is...how the heck do you get down there to tighten that thing?! I now see why redblock guys don't like the FWD cars - the turbo is impossible to access. I also see that it's damn near impossible to remove the CBV as well.
Stubby screwdriver, carpal tunnel syndrome, and some choice curse words? Am I missing anything? I don't know how I'm gonna reach that POS. lol.
Oh...also...I'm probably running lean under boost. The vac line to the bottom of the FPR blows out; this would mean I'm not getting the step-up in fuel pressure with boost (it would stay at the static pressure...are these 3.0 bar or so?).
I gotta get that sorted out too. Looks like a trip to the Stealership for some decent vac line and an 8V intake mani gasket for my grandma's 740.
#17 L8 APEKS
  • 760 posts
  • Crew:LBC
Posted 16 November 2009 - 06:55 PM
Wow...car pulls like a freight train now! Drive it a couple miles to test it out. Although, it's getting ping on 91. I think I only went WOT once for a couple seconds. :( Methinks 18psi is a little too much.
Ordered the MAP sensor for my boost gauge. Should have it installed Thurs or Mon.
#18 lookforjoe
  • 7,812 posts
Posted 16 November 2009 - 07:53 PM
Good to hear.
You fixed the FPR vacuum?
W/O that, you're stuck @ 3bar. over 10psi boost, should be closer to 4bar, under vac, 2.5bar
#19 L8 APEKS
  • 760 posts
  • Crew:LBC
Posted 16 November 2009 - 08:01 PM
Yeah, fixed em both. :)
Stuff is too hard to reach on these engines. FPR included. lol. :blink:
#20 ryan850-t5
  • 1,055 posts
Posted 16 November 2009 - 08:04 PM
ratchet wrenches are your friend :)
Ryan
'97 854 T5
Garage
IPD
