in case u have no idea what my car is, its a 95 volvo 850 turbo 854 body, 76k original miles,
this is my last attempt to fix this car,
today i installed new coil, i got spark, changed the ecu, and now i have fuel,
so i cranked it and it started up real quick, and then died, so i thought cylinders were flooded. and they were , only 2 cylinders were dry after ignition.
cranked the car for a half hour or so, tried to start it with starting fluid no luck, my dad says, lets ee if it has spark, pull the plug on the 5th cylinder, and agan NO MORE SPARK from the coil..
why is my coil burning out?
Tech Help
Started by Быстров, Nov 16 2009 08:13 PM
5 replies to this topic
Posted 16 November 2009 - 08:13 PM
Romans 1:16
16) I am not ashamed of the gospel, because it is the power of God for the salvation of everyone who believes: first for the Jew, then for the Gentile.
Posted 17 November 2009 - 01:34 AM
For some reason, I would suggest you check that the CPS (crank position sensor) is OK. Just a thought.
'98 S70 NA Silver Stock 220K
Toronto CAN A DA.
Toronto CAN A DA.
Posted 17 November 2009 - 01:47 AM
DAVE
96' 850R
96' 850R
Posted 17 November 2009 - 05:55 AM
Oem ecu oem coil oem wires oem crank and cam sensors.
Romans 1:16
Posted 18 November 2009 - 12:45 AM
check the FI relay.
(If you haven't noticed, I use this as my fall back NO SPARK "reason" whenever the OP says he replaced everything else
1994 854 Turbo
