Dry Sump Kits For The 5Cyl Finally
Posted 16 November 2009 - 10:17 PM
http://forums.turbob...d=1#post2775316
Projekt R-Megasquirt, gt28, 3in turbo back, kw v2 coilovers, fmic, 8 point roll cage, corbeau seat/harness, gutted to hell, solid bushings, F/R sways, walbro 255, 450cc injectors, NA cams, willwood brakes, port/polished head, rsi rods/pistons, tubular exhaust mani, adjustable control arms, adjustable strut top mounts, adjustable sway bar links... etc etc
NOT FINISHED, BUT GETTEN CLOSE
Posted 16 November 2009 - 10:38 PM
Posted 17 November 2009 - 02:37 AM
not sure if it's really worth the $$$$, but it would solve my crankcase pressure issues
Posted 17 November 2009 - 02:59 AM
lookforjoe, on 16 November 2009 - 09:37 PM, said:
Now that you mention that, it certainly would. And you could plumb the vent from the head down into the drain for the catch can, since there will be vacuum on that, and it will remove any positive pressure up top without having to deal with a catch can, no?
Hm, I guess that wouldn't really work, since anything leaking past the rings or valve seals has to go somewhere, and the sump pump isn't going to magically make it go away
Posted 17 November 2009 - 03:10 AM
Figure ON THE CHEAP, 300 for the oil tank, 300 for a manifold and 3-4 stage pump, 200 in lines and fittings, and another 200 in misc hardware.
If you driving it, I drove it. If you got it, cause I sold it
Posted 17 November 2009 - 03:54 AM
If I could find one for that price I would consider it but for 1200 and a pump and tank needed no thanks.
Posted 17 November 2009 - 08:22 PM
dongle, on 17 November 2009 - 02:18 PM, said:
500-700 is not a bad price persay, but pan is only like 1/4 the total price of dry-sumping an engine.
Posted 17 November 2009 - 09:52 PM
Che, on 17 November 2009 - 04:13 PM, said:
yeah at first I was like
In your opinion for the basic build most people on here do, ported manifolds, ported head and gt35r is this even necessary? Eventually I'd like to go with a similar build and I'm not tracking the car. So I dont believe i'd ever see a high enough g force to cause oil starvation. But I haven't investigated much either. I dont suppose baffles could be used like in gas tanks?
Posted 17 November 2009 - 10:25 PM
Che, on 17 November 2009 - 05:17 PM, said:
1. Ground Clearance
2. More HP
And would be best suited for those who can get their hands on a custom transmission that allows them to drop the engine a few inches without making a retarded angle on the CV joints, and don't mind much longer oil warm-up times. Daily drivers need not apply here
How much does it take to starve the stock oil pump in a properly filled FWD whiteblock anyway?
#14
Posted 18 November 2009 - 12:37 AM
More Gs than your tires will handle
H&R springs + Bilstein HDs <!--coloro:#FF0000--><span style="color:#FF0000"><!--/coloro-->(thinking about selling dampers if you want them)<!--colorc--></span><!--/colorc-->
Blue LED cluster and switches (Working on S70 cluster), Black Microsuede Headliner, Stylin' Motors Vacuum, Odyssey PC1200MJT
Custom V70R lower front valance <!--coloro:#FF0000--><span style="color:#FF0000"><!--/coloro-->(WTB: x70R fogz)<!--colorc--></span><!--/colorc-->
Custom 2.5" Catback Magnaflow: 1 cat -> 2 muffs in series
"Wrinkled" Rebuilt Head, Japan Manifold
<a href="http://www.publicons.de/" target="_blank" rel="nofollow"><img src="http://www.publicons.de/my/pub_Lakers%202009%20-%20Lights%20out_40,621,120,41,504,134,554,601,619,759,697,10,802,334,806,497_1.png" border="0" class="linked-sig-image" /></a><img src="http://i69.photobucket.com/albums/i41/cal3thousand/VSRiddle75.jpg" border="0" class="linked-sig-image" />
Sign In
Register
Help
MultiQuote
