M66 Driver Side Axle
14 replies to this topic
#1 volvotech97850
  • 3,194 posts
Posted 18 November 2009 - 01:33 AM
For the left axle, it should be fine to use the 850's, correct? Drove the car today, but driver side is leaking from the transmission. Went ahead and ordered a new axle seal, but I thought I should ask if it's better to run the XC axle on the driver side too. Thanks for any input.
#2 lookforjoe
  • 7,810 posts
  • Interests:Making Stuff
Posted 18 November 2009 - 03:11 AM
I'm using the autoaxles - until I get my M58 axles ready. The only difference is the OD of the outer shaft.
1998 V70 XR M66 10cm2Hotside/Garrett 60-1 Built T5 Motor '03 Ported Head EnemY21Cams TurboTuner 710cc Inj, DP back Dual Magnaflow 14834's May 2011 355WHP(@6400rpm) 347WTq(@4400rpm)@22psi Now with LGSpeed Header & Custom Intake Manifold! BIG 31x12x3"FMIC Currently sporting a vented piston!!!
#3 Chilled Man
    MILFSPEED
  • 29,896 posts
  • Gender:Not Telling
Posted 18 November 2009 - 03:14 AM
99 and older axles will work till the CV joint then you will have to use a shaft to the hub on the 850 .
#4 volvotech97850
  • 3,194 posts
Posted 18 November 2009 - 04:25 AM
Just making sure it was the bad seal, not an axle problem. Thanks guys.
#5 tonyt-5
    I <3 The Yellow Peril, and it's owner, Russ.
  • 77 posts
Posted 18 November 2009 - 11:10 PM
Has anyone done a "how to" on this subject yet?
#6 Hanks
  • 3,272 posts
Posted 18 November 2009 - 11:28 PM
im pretty sure scott was using a stock 850 axle on the drivers side with no problems.
#7 volvotech97850
  • 3,194 posts
Posted 19 November 2009 - 12:08 AM
That's what he told me, but I thought I'd double check. He said the V70 AWD axle looked about right for the passenger side, which turned out to be wrong...anyway, seal should go in tomorrow so I'll know for sure soon enough. I don't anticipate any real problems.
#8 Chilled Man
    MILFSPEED
  • 29,896 posts
Posted 19 November 2009 - 12:15 AM
I can if needed
#9 Hanks
  • 3,272 posts
Posted 19 November 2009 - 12:46 AM
ya we looked for a part number and he couldnt remember 100%...it wasnt an 850 axle though.
#10 lookforjoe
  • 7,810 posts
Posted 19 November 2009 - 03:03 AM
The 98 AWD right side axle didn't work for you? That doesn't make sense. The offset/spacing from trans to engine support to hub is the same for 850 as V70....
#11 Chilled Man
    MILFSPEED
  • 29,896 posts
Posted 19 November 2009 - 12:58 PM
Agreed .
I am using for my M56 on the P2
850 to CV joint then P2 out
#12 volvotech97850
  • 3,194 posts
Posted 19 November 2009 - 07:25 PM
No, the '98 XC70 axle is perfect. I was talking about the '00+ V70 AWD axle.
#13 Chilled Man
    MILFSPEED
  • 29,896 posts
Posted 19 November 2009 - 11:55 PM
acutally the 00 should work also its the same minus the cv join out into the hub from cv joint to tranny its the same unless it was a 5 speed ?
#14 volvotech97850
  • 3,194 posts
Posted 20 November 2009 - 10:30 PM
Yeah, it was 5-speed. Anyway, the car's running!
#15 Chilled Man
    MILFSPEED
  • 29,896 posts
Posted 21 November 2009 - 12:11 AM
Ahh thats the reason it didnt work the the 5 speed autos are different then the 4speed autos and manuals wich are the same.
IPD
