S80 Transmission Dead
21 replies to this topic
#1 BostonCow
BostonCow
  • 24 posts
Posted 19 November 2009 - 10:45 PM
so my tranny started to slip a couple days ago and then this morning, there it goes, dead. wont shift below or above 3rd and is basically done for. i don't have the money to replace it with a rebuilt or a new one...any suggestions?
'00 IPD Stage 1 S80 T6
#2 Ihatespeedbumps
Ihatespeedbumps
    The Pied Piper
  • 3,480 posts
  • Gender:Not Telling
Posted 19 November 2009 - 10:49 PM
Junkyard units will be hit or miss at best. You can probably part the car out and make more money than selling the whole car.
98 S70 T5M
#3 Crito
Crito
    Rusty Shackleford
  • 182 posts
  • Interests:AIPAC
Posted 19 November 2009 - 11:14 PM
Add a bottle of Lucas Tranny Fix and do a hard reset (disconnect battery and cross wires).
#4 BostonCow
BostonCow
  • 24 posts
Posted 19 November 2009 - 11:16 PM
^are you serious?
#5 MyCarIsRed
MyCarIsRed
  • 1,526 posts
Posted 19 November 2009 - 11:29 PM
View PostBostonCow, on 19 November 2009 - 11:16 PM, said:
^are you serious?
sounds like a hail mary to me... but hey, nothing to lose? Have you had a shop check it yet?
#6 BostonCow
BostonCow
  • 24 posts
Posted 19 November 2009 - 11:32 PM
yeah that's why i'm like "really?...no can't be" yeah volvo dealership said 4400 for a rebuilt installed. I can't afford it.
#7 Crito
Crito
    Rusty Shackleford
  • 182 posts
  • Interests:AIPAC
Posted 20 November 2009 - 12:43 AM
There's something in that Lucas stuff that makes the bands swell and a hard reset will get you out of limp home mode.
#8 Guest_Crito_*
Guest_Crito_*
Posted 20 November 2009 - 12:55 AM
While you're at the auto store get a small funnel that fits in the transmission dipstick tube, if you don't already have one. That Lucas Trans Fix stuff is thick and takes a long time to go down. And don't worry about overfilling, there's room in the GM tranny for an extra quart or two.
#9 MyCarIsRed
MyCarIsRed
  • 1,526 posts
Posted 20 November 2009 - 04:27 PM
Should be able to get it done for less, maybe find someone to rebuild yours?
#10 swedishiron
swedishiron
  • 367 posts
Posted 20 November 2009 - 10:00 PM
I would try the Lucas as the other guys recommended or drain and refill with Mobil 1 ATF and see what happens after doing a reset;
If that doesnt work buy a 940 (or 1990+ 740 if you cant find otherwise) - you can probably get one for less than $1500 easy. maybe up to $2K for a 940 for a daily driver until you decide what to do with the S80.
#11 CJones16
CJones16
  • 568 posts
Posted 20 November 2009 - 10:01 PM
Its a GM Tranny.. So that being said any back yard shop that can rebuild a GM 4T65-type transaxle can rebuild it
Also with it being a GM 4T65... there are rebuild kits and beefier upgrades
So its not a total loss
Chris
02 S60 T5M
#12 CJones16
CJones16
  • 568 posts
Posted 20 November 2009 - 10:06 PM
Also here,
If you want to rebuild it with beefier clutch packs - http://www.transmiss...CFchn5QodJ2l0pg
Chris
02 S60 T5M
#13 JVC
  • 7,610 posts
Posted 20 November 2009 - 11:17 PM
Talk to Osineo if you want to build it, he's working with Triple Edge Performance that specializes in this trans, he's doing some build work but supposedly there are minor differences between the volvo version and the straight GM version that don't allow certain upgrades.
-John
#14 Korruption
Korruption
  • 1,836 posts
Posted 21 November 2009 - 01:37 AM
If you should decide to not fix the car, I'm looking for a T6 donor motor for my project car. :ph34r:
1991 244 NA - M47
#15 S8ET6
S8ET6
  • 928 posts
Posted 21 November 2009 - 02:37 AM
TripleEdge is having their annual sale from now thru 12/30 - 15% off.
The high performance rebuiild should fullfill your needs.
click here
My Garage
"One is greater than Two"
Ive done my research and my math shows that this will work! - Binsky3333
#16 BostonCow
BostonCow
  • 24 posts
Posted 21 November 2009 - 01:48 PM
click here
works for me! thanks.
#17 BostonCow
BostonCow
  • 24 posts
Posted 21 November 2009 - 10:38 PM
so service transmission light went off today, CEL is still on, going to run it tomorrow, she still slips sometimes but not as bad. computer problem or what? its confusing me now.
#18 JVC
  • 7,610 posts
Posted 21 November 2009 - 11:46 PM
click here
damnit... if only I had the money...
#19 S8ET6
S8ET6
  • 928 posts
Posted 22 November 2009 - 12:38 AM
I know, right.
I'm half way tempted to buy several kits, and resell them later as people post about their dead 4T65Es
between here and SS, I'd make a mint Posted Image Posted Image
My Garage
#20 Crito
Crito
    Rusty Shackleford
  • 182 posts
  • Interests:AIPAC
Posted 26 November 2009 - 07:18 AM
Get the codes read. Those transmissions are designed to slip a little to make shifting smoother. Uses data from the front O2 (lamdba) sensors to retard timing at that precise moment too. If you read VADIS the communication process between ECM and TCM is actually fairly complex. Even a clogged oil trap puking into the intake can screw with it, making it seem like a transmission problem when it really isn't. I bet 75% or more of the GM transmissions that were declared dead were actually OK, which also explains why so many people continue to have problems after they're rebuilt. They're actually pretty tough and were even used in cop cars like the 3.8L supercharged Impala.
http://www.chevy-wik...hevrolet_Impala
If I ever buy another Volvo it'll be a stick shift.
