Oil And Gas Additives
51 replies to this topic
#1 Crito
    Rusty Shackleford
  • 182 posts
  • Interests:AIPAC
Posted 21 November 2009 - 09:24 AM
Couldn't find a topic on this here, but there were a couple threads about products like Royal Purple in this forum, so I believe this is the right place for it. Anywho...
So I know a lot of people think additives are snake oil. And I'm inclined to agree that the most expensive ones are a complete waste of money, some of them being nothing more than colored mineral oil. Others with Teflon in them might actually clog up your motor and do more harm than good over the long-run. But I've also found a few that I really like. Here's my list, feel free to add yours.
Lucas Trans Fix: Makes the bands swell, thickens the fluid and stops leaks. If you're getting clunking sounds and slipping, a bottle of this might save you from having to rebuild the tranny, for a while anyways. The automatic in my old Bronco was hard shifting and this made the problem go away for 30,000 miles. Eliminated the slipping problem with the GM automatic in my S80 too. I've never used it in a manual/stick shift though.
Bar's Rear Main Seal Repair: Contains esters commonly used as plasticizers, the stuff you lose when seals and gaskets get stiff and brittle. Also contains a fairly strong detergent though, so I'd recommend using it when you're down a quart before an oil change, not for a whole change cycle.
STP Oil Treatment: Thickens the oil and has a bunch of zinc in it. I sometimes put one of these in when I'm little low as it restores viscosity, especially in the hot summer months.
Gunk Motor Flush: If your motor is really sludged up, this will definitely strip it clean. Follow the instructions though and leave the drain plug out for a while to remove as much residue as possible, or do the next oil change sooner than usual. You don't want to leave any of that stuff in there.
My problem with products like Seafoam is all the smoke they produce. I'm afraid all that soot will clog up the little holes in my O2 sensors and the catalytic converter, which would be an expensive mistake. I'm sure it's great at cleaning deposits out of the combustion chamber but a good gas -- Shell V-Power and Amaco/BP Invigorate are my favs -- does that too, granted much more gradually. I'm also wary of fuel injector cleaning products for the same reason. I hardly ever put anything in my gas, occasionally a little Marvel Mystery Oil if my plugs feel dirty, but that's about it.
Posted ImagePosted Image
#2 waldendan
  • 186 posts
Posted 21 November 2009 - 12:14 PM
BG products all the way (yes I drank the Kool-Aid) B)
How much fun is too much fun???....Just ask your mom!!....Ohhhh snap!!! :)
D s50r Tech Support!!!
#3 Naughty33W
  • 1,646 posts
  • Interests:workin on my S60 and getting a divorce
Posted 21 November 2009 - 03:34 PM
my favorite add-in is lucas motorsports 3X octane booster - you can FEEL the difference
2003 Volvo S60 2.4T --- Favorite VS quote - "28 psi boost spike = ... fu** me lol" - by: 83' Turbo
18x8" OZ Wheels in Black , Gutted Interior , Smoked Windows , And Yes ... Hood Pins ...
Engine Build: 16T + Garrett WGA + Mishimoto FMIC + 3" Catless (Meow) TurboBack Exhaust + Tweaked ST 17psi Tune
#4 ozzimark
  • 4,295 posts
Posted 21 November 2009 - 03:37 PM
Just unbolt the downpipe before running the seafoam :lol:
#5 Dave 54
    Old Man Crew Pledge
  • 4,902 posts
Posted 21 November 2009 - 04:21 PM
+1, been using there stuff for a long time
DAVE
96' 850R
#6 Crito
    Rusty Shackleford
  • 182 posts
  • Interests:AIPAC
Posted 24 November 2009 - 08:08 PM
Back in the day there was a product I used that you poured straight into the carb. I forget the name now, but it worked really well and smoked up the whole neighborhood in the process. Actually saved a Subaru I had after someone poured a bottle of soda pop in the tank -- I had already drained the tank obviously but having run the motor a even little before that had mucked everything up. That was before oxygen sensors and catalytic converters though.
Anywho, the Marvel Mystery Oil might just be the placebo effect but seems like my car starts a little quicker after using it. When I notice it taking longer than usual I pour some in the tank. Might go from like 7 turns before it catches to 5 or something like that. I never use it in my oil though.
#7 Crito
    Rusty Shackleford
  • 182 posts
  • Interests:AIPAC
Posted 29 November 2009 - 04:26 PM
A good thread about the zinc in STP Oil Treatment:
http://board.moparts...&fpart=all&vc=1
Including one from the Interweb famous "Bob the oil guy" forum:
http://www.bobistheo...=476445&fpart=1
Note they also say it'll turn 10W-30 into 10W-40 so maybe that's why it seems to help in high mileage vehicles. Like I said before, I really only use it in the summer when I'm down about half a quart. Hate having half a bottle of oil in the car and the summer heat seems to break down the viscosity so for under $2 I think it's a pretty good deal.
#8 Crito
    Rusty Shackleford
  • 182 posts
  • Interests:AIPAC
Posted 07 January 2010 - 03:27 AM
Turns out zinc damages catalytic converters, which is why ZDDP is being phased out of engine oils.
Quote
The zinc bonds to the metal catalyst beads inside the converter, which undermines their purpose.
SOURCE: http://www.mustangmo..._oil/index.html
I've heard molybdenum has similar antiwear properties so might give a "moly" additive a try. There are even some German motor oils that come with it in the bottle.
#9 Jaxx
    Sandy Orangina
  • 9,065 posts
  • Interests:big red bricks
Posted 07 January 2010 - 03:55 AM
used motor flush 1 time. I can't remember what car it was though. basically "meh."
However, I've used seafoam 2 or 3 times, and while it might not be doing anything, i enjoy the smoke show.
Nadine | ME7 S70 T5 601
#10 v4lve
  • 1,467 posts
Posted 07 January 2010 - 04:06 AM
I don't think i've ever used an oil additive, makes me nervous :ph34r: As for Gas, I've used seafoam - definitely had better results via intake though
'98 Shit70 T5 http://www.drbrendan.com - Discounted iPhone/Mac repairs & mods by yours truly
#11 socal850tuner
  • 1,238 posts
  • Interests:cars....
  • Crew:SCC
Posted 07 January 2010 - 05:39 AM
Lucas oil powersteering fluid/additive. cured my noisy steering within the first drive.
'97 850 T5; K&N cone filter, IPD Sway Bars, Powerslot Slotted Discs, Strut Brace, IPD Poly upper engine mount, Voodoo mbc, MSD Blaster SS, Magnecor Spark plug Wires, Autometer Boost gauge on A-pillar, Pioneer Head unit, pioneer 5 1/4" up front and pioneer 6"x9" in the back, Rockford 450w amp, ~600 MTX 10" Sub, pioneer back door speakers, and 3.5"clarions in the dash
projects: Porsche 2.8 race, Porsche 2.0 race(complete), Porsche 3.2 street (complete), Porsche 3.4TT street(complete), Porsche 3.0 street (complete), Porsche 3L twin-plugged carbed street rocket(complete)
2K Motorsports
#12 Che'_Moderator
    Monkey Master
  • Admin
  • 23,936 posts
Posted 07 January 2010 - 05:48 AM
Its a little misleading. A healthy converter will have no problem handing ZPPD as zinc has a melting point low enough not to be an issue. The bad rap is more a function of EPA fears. MMT and PTFE are still very common and pose a much larger risk of clogging a converter.
#13 Boglin
  • 242 posts
Posted 07 January 2010 - 04:20 PM
BG MOA is the greatest IMO, my T5 has 320,000kms and still putting down 13's in the 1/4 and the engines never been apart!
1998 S70T5 SE,Full Stage Zero,IPD Boost Gauge Pod Kit, 18T, S60R Mani, EST 3inch DP,Unorthodox Racin UDP, EST Catback, IPD RipKit, IPD SR5T intake,Rica 16T tune, Forge MBC 17psi,HID kit, Urethane engine mounts,Stylin Motors Silicone hoses,Marangoni Verso's,Xenon RetroFit,13.82@101.71 mph
#14 TurboedVolvo
    Power Bottom
  • 141 posts
  • Interests:Volvos, Turbos, Computers, Disregarding posted speed limits.
Posted 07 January 2010 - 06:38 PM
B) Toulene.
B)
Gofast Juice.
1998 Volvo S70 T5 MODDED
12.6 @ 103 mph
#15 L8 APEKS
  • 760 posts
  • Interests:I LIKE TO RIP PEOPLE OFF.
    http://volvospeed.com/vs_forum/index.php/topic/135080-wheres-l8-apeks/
  • Crew:LBC
Posted 07 January 2010 - 10:15 PM
#16 gotboost
  • 689 posts
Posted 07 January 2010 - 10:31 PM
Can't say that it was necessarily the additive that did it, but my dad bought a brand new BMW 318i back in 1984 that made it to 550k on the original motor. Both he and I ran Dura Lube in it every oil change from like 1993 or so to 2002. I inherited the car as my first car back in 1998, and I can say that the car even at 500k, which is when I got it, still ran really strong. It probably would have made it to 650-700k on that original motor I'd imagine had I not loaned the car to my brother one weekend who got rear ended by an F150, thus killing the little bimmer. Still 550k miles is amazing for a BMW. I haven't really used it in any of my Volvos, due mainly to the fact that I run synthetic oil, which I think is good enough.
1998 S70 T5 SE 5-speed: Angled flange 18T, RICA tune, 3" DP, 2.5" Exhaust, R Manifold, IPD HD TCV, MSD coil, Turboxs BOV, Eurosport Intake, 2.75" Sconeman MAF-turbo pipe, Stylin' Motors hoses, 850R clutch, Sconeman short shift kit, IPD 25/28mm Sways, IPD HD endlinks, H&R springs, Koni Yellows, IPD poly mounts, OMP Strut Brace, HID E-codes and HID fogs, E-code turn signals, XC70 grill, CF OEM valve cover, CF throttle cover, Polished intake manifold, UK-spec S70R cluster, '04+ V70R steering wheel, V70R seats, Blue LED dash lights, 302mm Zimmerman cross-drilled front rotors, Brembo cross-drilled/slotted rear rotors, IPD SS Brake lines, PBR Ultimate Ceramic brake pads F&R, Kevlar timing belt
And Now: 1998 V70XC: EST intake, EST RIP kit, MSD coil, Inmotion tune, IPD poly mounts, 17" Titans, 302mm brakes, E-codes, Hella 500s, V90 rear wiper.
#17 Wagoneer855
  • 3,185 posts
  • Crew:ECC
Posted 08 January 2010 - 01:18 AM
it's called a few liters of 108octane into a tank of 94.
:ph34r:
'97 855 - Build in progress
#18 Fudge_Brownie
    Hippie Exterminator
  • 8,062 posts
Posted 08 January 2010 - 01:50 PM
http://volvospeed.co...e_boosters.html This seems relevant.
86 Kawasaki Gpz900R Ninja
#19 L8 APEKS
  • 760 posts
  • Crew:LBC
Posted 09 January 2010 - 10:37 PM
Due to the price of Toluene, I have a new favorite which I just purchased:
Toluene was $54 out the door.
The Methanol was $21.
(per 5 gal drum)
#20 ryan850-t5
  • 1,055 posts
Posted 09 January 2010 - 11:10 PM
where did you get the 5 gal drum?
Ryan
'97 854 T5
Garage
IPD
