Hello, I just picked up a 1995 850 turbo and one of the service records indicates that it needs a new cat. Now i'm not sure which way to proceed with this. I wanted to put a higher flow system on the car, but absolutely hate the sound of wide pipe exhausts. So I'm optimally looking for what I should get to get a higher flow rate but as close to stock sound level as possible.
Would it be possible to just replace the cat with a high-flow cat and leave the stock muffler? Or get a high flow, stock sound muffler with the new cat? Would I also need a new wider down-pipe?
I saw FCP has some supposedly bolt-on OEM quality cats with down pipes on them, but it seems a bit pricey to be back at stock flow but with aftermarket parts instead.
Thanks.
New Cat
Started by bergmjs, Nov 21 2009 08:44 PM
No replies to this topic
Posted 21 November 2009 - 08:44 PM
'95 854 T5M 175k - Koni Yellows, IPD Strut Brace, IPD CAI, IPD 25mm front sway, IPD Poly Upper, M56H, NA TB+Mani, Japanifold, OBX exhaust w/ angled housing, IPD springs, 2.25" Plumbed FMIC, 18T, ARD Blue
