Door Panel Repair
5 replies to this topic
#1 Rsterns
Rsterns
  • 949 posts
Posted 22 November 2009 - 01:59 AM
A while back, I had the good fortune of obtaining a panel insert kit which Volvo no longer provides. It didn’t have any directions so I’ve been winging it.
Here is what I’ve done so far.
Here’s the age old problem…
The toughest part was removing the plastic inserts for the window switches…
The trick is to use a heat gun to loosed the hot glue they use in assembly.
Cut around the old insert, and peeled it off…
Then with a wire brush, I removed all the remaining foam backing.
Posted Image Posted Image
Applied adhesive to both parts
And pressed them together.
Seems to be a perfect fit, I’ll let it set over night to cure, then cut out the pockets and reverse the assembly process. The kit came with glue sticks, but I used a different adhesive, as what was in the kit had long ago expired.
'98 V70 T5 (Auto) At 280,000 fresh rebuild with port and polish ;Cryo treated everything, IPD Stage III w/ IPD Intercooler and TME cat back exhaust,Koni FSD/ Eibach springs, IPD sways F/R, IPD HDEndlinks, IPD BBK; Slide Show of build: http://rides.webshot...563883893OGxoym '96 965 A sweat find with 30K miles on it! http://rides.webshot...myd?vhost=rides
#2 ozzimark
ozzimark
  • 4,352 posts
Posted 22 November 2009 - 02:40 AM
Looks great so far man. What glue did you use, and how much does the kit cost? :D
#3 Rsterns
Rsterns
  • 949 posts
Posted 22 November 2009 - 02:57 AM
Thanks, the kit was free; got if from a Volvo tech who was a pack-rat and told to clean up...I was at the right place at the right time. I used a Loctite product called stik'n Seal. It's supposed to stay flexible, which was one of the properties of the expired stuff in the kit. This was a one part adhesive.
#4 (n)A-GAME
(n)A-GAME
  • 7,288 posts
  • Crew:ECC
Posted 22 November 2009 - 02:32 PM
Awesome! I'm going to use this writeup when it comes time to reupholster in microsuede.
2011 Volvo S60 T6 AWD
#5 CJones16
CJones16
  • 568 posts
Posted 22 November 2009 - 03:26 PM
Just looked up a part number for the kit (no particular color), but its around $350!
You should leave it shaved
02 S60 T5M
#6 Rsterns
Rsterns
  • 949 posts
Posted 22 November 2009 - 08:56 PM
And here is the final product......
