1996 850R Bleeding Brakes Problem
Started by 850Boyo, Nov 22 2009 02:12 AM
9 replies to this topic
Posted 22 November 2009 - 02:12 AM
Right front and left rear calipers bleed wonderful. Left front and right rear calipers have a never ending air supply apparently...any suggestions? I've put more than a quart through just the rear right.
Posted 22 November 2009 - 02:25 AM
Sounds to me like you might have been braking with only 2 for a while lol....
I dunno what order you bled your brakes, but..it might have something to do with it? I cant remember if its start at the front left, move back, go to top right and then the rear right?
The order is important i believe so that the air is constantly moving back, instead of just hanging in the middle..
Someone should have the proper order..its been a long whiles since i did it.
Otherwise, did you notice fluid leaking out everywhere???
1996 850 R - My Love, Suwanee
VS for life
VS for life
Posted 22 November 2009 - 02:33 AM
no fluid leaks, but the front left and rear right calipers bubble like they are filled with nothing but air, barely get any fluid out. I bled according to volvo's specs.
Posted 22 November 2009 - 02:45 PM
Bleed sequence is:
Rear 1st in either order, followed by the front right then the front left.
How are you bleeding it, are you usung a power bleeder or just gravity bleeding?
DAVE
96' 850R
96' 850R
Posted 22 November 2009 - 02:57 PM
Actually let's start with why your bleeding it?
Did you have the system open somewhere or did you replace something?
"SMOKE TROUT NOT CRACK"
Posted 22 November 2009 - 05:15 PM
Dave 54, on 22 November 2009 - 02:45 PM, said:
Bleed sequence is:
'96 NA 855 | 207 k | wrecked, body not fixable, runs and drives like a (slow) top
'96 NA 855 | 92 k | daily driver
Posted 22 November 2009 - 05:18 PM
erikv11, on 22 November 2009 - 05:15 PM, said:
Actually, and I have no idea why, Volvo's recommended bleed sequence is just the opposite, from closest (driver's front) first to farthest (passenger rear) last. But many people don't follow that recommendation, and use the "standard" order instead (farthest first, closest last).
DAVE
96' 850R
96' 850R
Posted 22 November 2009 - 06:35 PM
850Boyo, on 22 November 2009 - 06:20 PM, said:
Replaced front right and rear right calipers, once again, new front one bleeds dandy. I'm using the partner on the pedal, and me with a hose and a wrench and a jar technique.
I used a power bleeder from Motive and highly recomend it, made things 100x's easier, or you can use a hand held vac. pump attached to the caliper bleeder to help pull it through the line.
DAVE
96' 850R
96' 850R
