Manual Trans Input Shaft Seal
Posted 02 December 2009 - 09:56 PM
My m56H has 120k on it.
Thanks.
Posted 02 December 2009 - 10:31 PM
I would definitely put it in a new one if it looks jarred or worn down. It's an $11 piece and comes in 2 sizes, order both sizes and use whichever one that fits and then never worry about it again
IPD Stage III + Meth/WI MT ----- 18T angled ----- 350cc white injectors ----- s60R manifold ----- 3" OBX angled dp ----- Magnaflow HFC ----- 3" Magnaflow exhaust ----- FMIC ----- 3" open element CAI ----- 2.75" Sconeman pipe ----- 150psi 250cc Meth/WI ----- MSD Blaster SS ----- Kingsborne 8.5mm spark wires ----- Forge BOV ----- Greddy Profec B spec II EBC ----- AEM Uego Wideband ----- m56H manual ----- R clutch ----- Koni Yellow Struts/shocks ----- IPD 1.75" springs ----- IPD 25mm/22mm sway bars ----- HD endinks ----- OBX v2 Strut bar ----- 302mm BBK ----- stainless lines ----- Knocksense ----- ADR RS Mase 17"
Posted 02 December 2009 - 11:08 PM
Seriously though don't skimp, you will regret it. 11$ is worth peace of mind.
Posted 03 December 2009 - 12:10 AM
Posted 03 December 2009 - 12:22 AM
I will warn you there are two seals and it's a bitch to figure out which one you need.
Posted 03 December 2009 - 12:24 AM
Posted 03 December 2009 - 01:13 AM
I think I changed my mind then. The reason I am so hesitant is because I don't want to put the new seal in incorrectly. That happened with my RMS and I had to get that replaced. I'll check for signs of leakage, and if I don't find anything I think I'm going to leave it.
Posted 03 December 2009 - 01:37 AM
Better safe than sorry IMO
1 of 1 - '97 427 854R - 110k
Posted 03 December 2009 - 02:04 AM
Don't listen to Dave, he doesn't know an M56 from a turd.
Leave well enough alone, they were fine on the sedan at 260K and the wagon at 85K. I highly doubt you'll have issues with yours.
MY97 855 Manual swap, Porsche Brakes, 16T on LPT block and plenty of IPD parts
Posted 03 December 2009 - 03:48 AM
Thanks for your input, Matt.
Posted 03 December 2009 - 04:52 AM
I've never replaced one (or ever seen one leak). I'd say if it ain't leaking don't touch it.
Alex
