midlman, on 07 December 2009 - 02:46 AM, said:
Numbers look good. Is yours still an automatic transmission? If so, what gear did you run in and how did you keep it from kicking down to a lower gear?
The air/fuel looks good on the blue run, but seems the richer red run got you some extra power and torque. Intersting..
Yes, 200k auto trans. 3rd gear. Slowly accel up to 3rd (with the selector in 3) and then quickly roll into full throttle at around 60mph. No downshift.
TLAO - thelostartof from turbobricks.com. His name is Mike. He also has LH2.4 chips, and should have LH2.2 chips if he doesn't already.
I think there's more to it than just the fueling - unfortunately I didn't have my OBDII scanner going so I couldn't see the ignition advance.
Both AFR tables are good, so I'm actually taking the wideband out and putting it in another car. I've always kinda thought that as trendy as widebands are, they really aren't necessary when you're just running off the shelf tuning parts that hundreds of people have already used, and you know what the AFR's are going to be anyway. If the fueling is significantly off, you'd know it.
I'm not messing with big turbos or 30psi, so for me with just intake, tune, exhaust...a wideband really isn't necessary.
