Volvo Dealership Stressin Me Out!
Posted 28 January 2010 - 06:51 PM
They gave me a list of problems that are becoming an issue of concern, 1) bevel gear is leaking and looseness between gears, rear diff is leaking and looseness between gears; to fix this issue they quoted $7k 2) Front spring seats are torn, front struts are leaking due to torn spring seats quoted $2k to fix 3) I had brakes done by someone I trust(ed), front brake rotors are wrong size, needs pads and rotors; which I am going to talk to the person who did them for me.
They told me the issue was probably caused because I have 3 old tires on the car and one new one. Now this has only been since the first Saturday of 2010, I had a tire get shredded from a pot hole, took it in to get 2 new tires the had to order one in and I was planning on having it put on this weekend. I find it hard to believe this issue has developed over the past 3 weeks.
Now when I talked to the person in the service department at the dealership he didn’t even say anything about having it get repaired there, he just told me “to be honest, I would get rid of the car asap!” But is this honest opinion coming from him knowing the cost or the mechanic who is trying to earn a buck? I have had friends told this before by dealers and their car has lasted 5 more years. I am just stuck in this decision situation and it is stressing me out. I am going to get a second opinion probably even a third. I love the car and can’t tell any difference in the driving. I would hate to part with it but can’t lose out on that much money.
Also are there any things I should watch for. I mean I park it in the same place on a consistent basis and there no leak spots and everything seems to run smooth? Any help would be great and any mechanics in Northern Utah you would recommend would be awesome. Let me know if you need anymore info.
Posted 28 January 2010 - 07:08 PM
86 Kawasaki Gpz900R Ninja
Posted 28 January 2010 - 08:27 PM
The brakes on this car are unique to the R so a jack leg mechanic may not know that. I would suggest ONLY Volvo products.
Leaking struts due to torn spring seats sounds like a wash. If the struts are in fact leaking they are very costly to replace and there are no aftermarket substitions, but at that mileage it would be quite unusual. Actually broken spring seats at 35k sounds like complete bullshit. If they are torn you would hear noise in the front.
Where are you located? Maybe a local member can point you in the direction of a good Indy shop. You can always check out the dealer reviews section for your state, located at the bottom of the main forum.
Posted 29 January 2010 - 12:33 AM
1) fixing rear diff is $7k? Have you looked under the car to see how bad it is?
2) My strut mount bushings cracked as well ($400 quoted from Volvo, I replaced for $70+front end alignment). As you are not a do it yourselfer--2K sounds outrageous. Struts failing because of it? Sounds weird. How bad is the rattling sound due to bad bushings?
3) brakes by others. Did your pal really replace the rotors? (I'm guessing you are at 50K miles? this doesn't sound right). Volvo will of course claim it's done wrong and want to redo on their terms.
What prompted a visit to the repair shop? Leaks on the driveway, poor stopping power, rattling front end, routine maintenance. Something is really fishy here. I would do yourself a favor and do a bit of research (look under your car, were the rotors really changed, bla bla bla.). Also I hope you didn't start your line with Volvo like you did here "hey Volvo, I'm no car buff, but something's wrong...guarentee they will take that hook"
So... 7K + 2K + brakes (let's say 500) + tires (let's say 500) = 10K. Is your car really that bad?
Posted 29 January 2010 - 02:58 AM
The rear diffs on pretty much all Volvos retail for about 3600 USD now (they went up by 100% or more in the last two years for reasons I don't know). The angle gear costs in the realm of 1500 (assuming you can't just reseal it like most of us do when they leak) so that's 5100 in parts and the rest is labor. It still sounds steep to me, but you do have a lot of work to get the rear differential R&Red...15-20 hours of labor though is excessive.
I also doubt that your struts are leaking at such low mileage.
2nd opinion time as mentioned above.
Me: "Yea."
Posted 29 January 2010 - 05:18 PM
Ihatespeedbumps-that is the weird thing about the whole situation. I have not noticed any difference in the car. No noises or no different feel to the handling. The car has been awesome, that is why I was so blown away by all of this. I am going to go to the guy I had do the brakes and see what he says. Also on another forum I got contact info for an independent Volvo mechanic that is fairly close to me so i am for sure going to get the second opinion.
mustang-1)I honestly would not even know what I am looking for? And that is what they quoted me after it is all said and done.
2)I have been told by some they are related and by others they are not related and there is absolutely no noise coming from my car. Since this has all happened I have drove around with out the radio just trying to hear something and haven't yet.
3)I had the brakes done at about 55k and I am at 68k right now. The brakes they were the most pushy on getting done by them. I am going to check back with the mechanic I know plus have them check the brakes at my second opinion.
I just took my car in for regular maintenance, I have taken it in before and they never said a word about any of this. The car has been phenominal thay is what is so mind blowing to me. This came like way out of left field. And I didn't let them know anything about my un-car savvyness.
Posted 29 January 2010 - 06:34 PM
Posted 30 January 2010 - 02:40 PM
Fudge_Brownie, on 28 January 2010 - 07:08 PM, said:
4C Chassis struts welcome to the R club.
Posted 31 January 2010 - 03:49 PM
dealers stick together, if you take it to another one they'll bring up your VIN # and see the last report. thats how they keep there doors open and try and get you to buy new car..
just my 2 cents.
Posted 05 February 2010 - 06:59 PM
Posted 05 February 2010 - 08:48 PM
ross84volvo, on 05 February 2010 - 06:59 PM, said:
These aren't Fords and that statement is retarded. Have you ever seen how vehicles are assembled? It's nothing like how they are repaired.
Posted 05 February 2010 - 10:37 PM
Ihatespeedbumps, on 05 February 2010 - 08:48 PM, said:
Posted 06 February 2010 - 12:04 AM
cookiemonstar, on 28 January 2010 - 06:51 PM, said:
The leaky struts always make me laugh. 35k come on...
You do want to get that odd ball tire off there though.
#14
Posted 06 February 2010 - 12:48 AM
ross84volvo, on 05 February 2010 - 10:37 PM, said:
bwhahahaha! I'd love to meet you in person.
If you don't like this site, why do you keep coming back?
Time for another time out
#15
Posted 06 February 2010 - 02:14 AM
i thought the asshats were on swedespeed? why does he keep coming back here then?
#16
Posted 06 February 2010 - 10:48 PM
I'd be interested to hear how you come out on this.
Previously: 1996 850 wagon, 2000 S70, 2001 V70 2.4T
#17
Posted 07 February 2010 - 01:54 AM
#18
Posted 07 February 2010 - 06:24 AM
MrWinkey, on 07 February 2010 - 01:54 AM, said:
Mr. Winkey, I can I get tickets to this event???? While Ross84 makes the realization that the manufactures can train a monkey to assemble the car, it's because the engineering upstream was done properly and the procedures they wrote were such that even a dipstick like Ross84 could do it (the reality is a 3rd grader could be trained to do it too). Trust me, I design ejection systems for military aircraft, and I have to write procedures to that level for the initial assembly! Repairing those systems is an entirely different situation, and it takes a skilled individual, not the monkey that assembled it. The real skill it knowing what is broken, not just guessing and replacing parts, and then replacing parts, and then replacing.......... This is what defines a really good mechanic.
Ross84, do you you really think the assembler can work at this level?????
Jerry
73 P1800ES 370K miles (RIP)
73 145 about 320K miles (when gone with the "X")
#19
Posted 07 February 2010 - 08:21 AM
I do have to say you are kind of shooting yourself in the foot so to speak by not knowing what too look for (that's what we're here for though
#20
Posted 07 February 2010 - 04:35 PM
A gave him a couple of weeks in the corner to think about it
